Question about Gaggia Titanium Espresso Machine
My gaggia titanium says fill water tank, i fill it and the message won't go away. therefore no coffee
  • 100 Answers
Tank sensor water level on bottom, check it.
Posted on Apr 02, 2011
Gaggia Titanium SUP027 YDR Syptom: Displays Fill water tank even though the water tank is full and freezes the operation of the coffee machine
Be sure to check the float in your water tank. It looks like this: http://www.cerinicoffee.com/item.asp?PID=1318
If the float is not floating then you need to replace it.
Jun 05, 2011 | Gaggia Titanium Espresso Machine
My Titanium keeps saying "fill watertank" I have filled the tank, switched the machine off hoping it would reset but same message!!
See if the small black float is able to move up and down in the water tank. You have to clean the water tank every so often, it will get slimey in the tank and it's possible some build up is preventing the float from moving up and down.
The float is dark in color and about 1 inch by 3 inches by 1/4 inch rectangular shape. It is magnetic and works a magnetic switch that is inside the machine.
Oct 13, 2010 | Gaggia Titanium Espresso Machine
Cannot solve "Ventilate" problem - weater circuit is broken
Turn the knob on after you press the hot water button, run the cycle until the message is gone takes a few seconds or about 2 ounces of hot water.
May 02, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium SS. I get a constant ventilate request, but water comes out a drop at a time. First time it came up a few coffee grounds came out of the steam/water wand. But now just a few drops of...
HI If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds will get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water needed to spin the turbine wheel to send impulses to the computer. You get the ventilate message. One thing to remember is when you are working on the water system (have the water tank off) do not fill the bean hopper and visa versa. Keep them covered when working on the other. Cross contamination will damage a machine fast
Feb 01, 2010 | Gaggia Titanium Espresso Machine
My Gaggia Titanium machine says ventilate
Run about an ounce of hot water from the wand.
Nov 10, 2009 | Gaggia Titanium Espresso Machine
Fill water tank message appear even when tank is full
Check the float in the water tank,it can stick or leak water and sink to the bottom.
Jul 17, 2009 | Gaggia Titanium Espresso Machine
Decalcify
Did you use the auto descale or the manual descale.
If you did it the manual way, then fill tank with water and press the Double elipse button(left of menu button) that will run the auto descale and clear out the message.
Mar 02, 2009 | Gaggia Titanium Espresso Machine
Fill Water Tank But Water Tank is Full
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Jan 14, 2008 | Gaggia Titanium Espresso Machine
Grinder spins but won't grind coffee
You have fill a water in your coffee grin
Jun 19, 2007 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
677 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
