I have a whirlpool lxr7144eq1. It seems like the motor is running but doesnt spin.
Check under the machine. you may have broken one of the belts that turns the tub and agitator
Posted on Mar 28, 2011
My Inglis by Whirlpool washer doesnt spin. Its a Direct drive unit so Im guessing that the clutch is bad?
does the motor run when its supposed to spin? if not its probebly a lid swich problem. if the motor runs it may be a coupler or poss. cluch. sometimes a sock in between the tubs.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
May 07, 2014 | Whirlpool Inglis IP4400 Washer
Whirlpool lxr7144eq1 why did my washer quit agitating and spinning what would cause this ?
Check the motor coupling to make sure it isn't broken.
And also check to see if something has clogged the water pump
Apr 27, 2014 | Washing Machines
Tengo una lavadora Whirlpool modelo LXR7144EQ1 que al exprimir la ropa no gira la tina si me pueden Ayudar de una Resolución de este problema
tengo una lavadora whirlpool, el problema es que no gira para exprimir, todo lo demás funciona, el motor recibe la señal para la función exprimir, sin embargo la transmisión no funciona.
Jan 09, 2010 | Whirlpool Washing Machines
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Whirlpool washing machine model number LXR7144EQ1...machine will run, but agitator will not engage.
Had a similar problem. What you need are new "dogs" inside the agitator cone. "Agitator Repair Kit"
Parts found here: http://www.partselect.com/PartDetail.aspx?Inventory=334622&SourceCode=6
Guarantee this will fix the agitator not spinning/working, unless the entire spindle isn't going back and forth.
I ordered this kit from these good folk and it arrived in 3 days.
All you need to replace these parts is a 7/16" socket with a 6" or longer extension & socket driver.
10 minutes, you can do this!
Hvae fun!
Jun 16, 2009 | Washing Machines
Loud while agitating
CHECK COUP-LER BETWEEN MOTOR AND GEARBOX.if coupler good,then gearbox bad.
Feb 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer
pull cap off top of agitator remove round cover underneath remove bolt in middle holding agitator down pull agitator up and out pull top portion off by holding bottom half down and pulling top part straight up in center of top part are what are known as agitator dogs either black or tan replace them they are probably worn whirpool part #80040
Aug 28, 2008 | Whirlpool Washing Machines
Whirlpool Washer wont spin or drain
check your run capicitor
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 01, 2008 | Washing Machines
Whirlpool top loader model 3LS C8255EQ1
if the motor is running during the time its supposd to be agitating and the motor is running during the time its supposed to be spinning. then you need to replace the motor coupling. it connects the motor to the transmission it is broken and the is no connection anymore. the motor coupling is only about 10 bucks.
Feb 16, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
