My Napoleon NPS40 pellet stove's exhaust motor is running continuously and the ignitor won't heat up. I've cleaned the stove and look at the reset button, all seems fine.
    Brigadier General:
  • 4,736 Answers
Check the door gasket material. If it's worn, it's allowing air from the room to be pulled in and has fooled the exhaust motor into thinking it needs to run more. Or the fan ON/Off sensor has failed.
Posted on Mar 28, 2011
My napoleon pellet stove npi45 will not start up when power button is pushed the light lights up and fan starts but then the forth light blinks on off
check your auger motor if it is plugged up it will not start
if you need help just call me 705-286-6130
my name is dave
Sep 25, 2014 | Napoleon Fireplaces NPI40 and NPS40...
Why is my reset switch popping after 10 minutes when I try to to start the pellets.
I would suggest contacting Napoleon directly at 1(800) 461-5581 and ask for a registered Napoleon service dealer in your area. You can also go to this website http://www.napoleonfireplaces.com/find-a-store/ and ask them if they have a service technician if you are in the United States. Pellet stoves are extremely temperamental and can be a real bear to try and diagnose. Honestly, leave the diagnosing and troubleshooting to guys that have meters and gauges to properly diagnose the issue. I hope this helps.
Aug 02, 2014 | Napoleon Fireplaces Napoleon NPS40 Auburn...
I have a quadra-fire 1100-i and I can not get power to the ignitor
Be careful how you read the voltage on the ignitor, as it has a low resistance and may not show a voltage across it. As is the case with most parts, you can use a line cord to hot wire the device to test it. Remember, the stove has a 10 minute exhaust fan timer when its first plugged in, so the ignitor will not light until this has timed out.
Nov 25, 2012 | Napoleon Pool & Spa
NPS40 blower and ignitor always on - did i cross wires
i would suggest you call the manufacturer and ask for tech help asap
ask for them to send you the wiring diagram, it also should be on one of the covers or lid for the back of the unit. OR
http://homeappliance.manualsonline.com/manuals/mfg/napoleon_fireplaces/nps40_1.html?p=30
Jun 07, 2017 | Napoleon Auburn Pellet Stove Heater
I need to find an ignitor for my kovi pellet stove, part number KPELES01
Expensive
APR Industries Ltd.
1354 Waverley Street
Winnipeg, Manitoba
R3T 0P5
CANADA
http://www.kozistoves.com
e-mail: mail@kozistoves.com
Nov 03, 2011 | Napoleon Auburn Pellet Stove Heater
Quadra Fire Pellet stove-will not ignite
I own a Quadrafire pellet stove. I have had this thing for 10 yrs. It seems every year at the start of the season I have some kind of problem. I clean it at the end of the season completely. First couple of burns are fine then get a good cold day and it doesn't work. All the gaskets, the exhaust blower, ignitor, glass front, and exhaust piping have had to be replaced. Now I have a blinking red light in the control box and cannot find anything on line to help. Does anyone know why this red light blinks 3 times every 10 seconds inside the control box? It's not the call for heat light. Think I may change to a wood burning stove to many headaches.
Oct 20, 2011 | Napoleon Auburn Pellet Stove Heater
Our napoleon stove barely heats the room it is in and it is new first year used,,
Try this....before starting the stove, place a handful of pellets into the burn pot. Start stove with feed rate about 2-3. Let the pellets ignite fully, then turn pellet rate to about 5, less then max. Let a good flame develop for 5 minutes or so, then turn on the fan. I set the fan at about 3-4 as advised by the tech. Reduce feed rate to about 4. I keep my damper on 2 1/2 to 3 to supply air intake. Napoleon is not the greatest stove, and I'm having an issue with mine after 3 years, but hopefully this helps. It will never give the heat of a wood stove, but get a strong fire going first, then tune it down after the room gets warm.
Jan 16, 2011 | Napoleon Auburn Pellet Stove Heater
Smoky smell from Napoleon pellet stove.
it over fueling at low setting this is a comon problem and will do exsaclly what you have said
Dec 30, 2009 | Napoleon Auburn Pellet Stove Heater
5510 king pellet stove exhaust problem?
Mine does the same thing too-what I do is shut it off and put it on again then it works fine.
Nov 22, 2009 | Napoleon Auburn Pellet Stove Heater
Purchased a used Earth stove mp240 pellet stove and the auger does not move. we are looking for a manual or information on this stove it is an older stove we just don't know how old. Thank You
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
Jun 10, 2009 | Napoleon Auburn Pellet Stove Heater
Heating & Cooling Logo
231 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
