Question about Car Audio & Video
I have a Mutant MT1105USB Stereo it did work correctly until i conected and disconected my fone now wen i try to use my sd card it says error 12
I have downloaded the f secure to my mobile phone and locked my phone by mistake. now i can't unlock my phone because i don't have the default password.
Had same problem with Nokia N8. I removed SIM card & held on/off button & menu button(bottom right hand corner front of fone) for about 15secs until fone switched off. I then reinserted SIM card, switched on fone, entered my SIM (not F-secure) password & haven't had a problem since ! P.S. I also removed the micro sd card til fone was working correctly so as not to risk losing any data. Hope this helps...
Dec 21, 2010 | F-Secure Anti-virus Client Security...
How to format a micro sd memory car in a lg xenon
To format the card go to Options Advanced Options Memory Card. Press the scroll wheel and select Format Card.
Jan 04, 2010 | LG Xenon GR500 Cell Phone
Card error when i did not chcarge it for 3 days
for card error on sl75 ,,,, format your fone... go to file setting then format.. do it quickly coz the fone will display,,, card error...
dn let it off for several times or days,,,, on and off,,, i think thats the key to kill the virus,,,, until such time that your fone will work,,, but still it will display card error but you can now use your fone longer time.......
Nov 21, 2009 | Cell Phones
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Memory Card dnt work ? how do i fix it ?
hi..there may be a problem with your mobile phone micro-sd slot
or their might be a problem with ur micro-sd card. u can also do
one thing just take the micro-sd card and clean the pins of micro-sd
card with spirit,aftershave lotion, isopropyl or body spray. just take
the above mention chemical in a soft cotton cloth and then try to
clean the pin of sd card by rubbing the cloth on it.
try this out..
thank u..
rate me..
Apr 12, 2009 | Motorola Mobility E770 Cellular Phone
How can i format my phone memory
try the format option wen u right click on fone in my computer
or run a virus scan on fone wen conect
Feb 16, 2009 | Sony Ericsson K750i Cellular Phone
LAN not conecting
remove ur lan card and clean it and install it
Jan 21, 2009 | Acer 91.AB370.001 Network Adapter
Memory card
you should reflash the phone
Jul 02, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Microsd trouble
Either the card needs formating again, or you are still sending files to the onboard memory, in the pictures or sound menu, you have to switch the storage device to the sd card because it is not automatic; by pressing the button for options and then select switch storage device
Apr 26, 2007 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
Car Audio & Video Logo
388 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
