Question about Jandy Laars Lt 400,000 Btu Heater
Laars 400-LT: Do I need to remove the rear panel of the housing in order to replace the igniter ? How do I remove the back panel (it is up against the wall with only 6-8 inch clearance). I can not see but two Phillips screws at the bottom of the panel. I have tested the igniter from the front side leads with ohm meter and it reads zero. Can not see how to remove the igniter which in the manual exploed view seems to be at the back above the center gas tube. IF I must remove the back panel I will need to disconnect both the gas and water connections and rotate unit about 45 degrees. PJ
  • 310 Answers
THe ignitor is right inside the front cabinet 2/3 of the way up from the bottom. It uses 2 wires and can be easily accessed in a matter of minutes.
There are no repairs short of a ful heat exchanger replacement that will ever require you to access the rear panel.
http://www.jandy-downloads.com/pdfs/LXandLT_H02140B.pdf
ABove is the link for the LT manual which shows where to find the ignitor.
The ignitor is part number 44 in the list.
Posted on Mar 29, 2011
On the jandy 400 lt its displaying the AGS code... what does that mean?
Per your owner's manual:
AGS
(automatic gas shut-down)
1. Oscillating pump pressure.
1. Clean filter or identify and repair cause of pump oscillation.
2. Low gas supply pressure.
2. Identify and repair incorrect supply pipe size or pipe line blockage.
Refer to qualified service personnel.
3. No flame at burners.
3. No flame at burners. 3. Identify and correct loose wiring connections, or problems with igniter, flame sensor, gas valve, or ignition control.
For more info the manual is here:
John
May 03, 2011 | Jandy Laars Lt 400,000 Btu Heater
Inside Walls of Pool Heater are broken
u can find fire brick at stores that sell fireplaces,boilers,woodstoves or on line places such as hi temp refractories manufacture all different sizes and shapes,or can notify laars at 1800 900 9276 ext 4 they dont sell to consumers but can advise of a laars distributer near u who can order replacement brick liner
Jul 19, 2010 | Jandy Laars Lt 400,000 Btu Heater
I have a Laars Lite2 gas spa heater. I just replaced the Fenwal Electronic Eignition. When I turn the power on it starts the start-up process, the gas starts to flow, but no clicking of the igniter, just...
Check and make sure there is nothing fallen on the igniter or spider webs on it. Anything touching it can cause a problem. Make sure wire is not burnt going to igniter. Gas Valve will lock out after a time period if no Ignition.
Jun 20, 2010 | Jandy Laars Lt 250,000 Btu Heater
How do i change a brake light bulb on 2000 vw jetta?
Removing:
  • Switch off all electrical consumers, switch off ignition key and remove ignition key.
  • Remove rear luggage compartment side panel trim (left or right).
  • Remove 3 nuts, arrows, and remove housing.
  • Remove bulb holder.
Installing:
  • Install bulb holder.
  • Insert housing into body opening.
  • Tighten nuts.
  • Install applicable rear luggage compartment side panel trim.
Rear Light Bulb Holder Removing And Installing:
Removing:
  • Disconnect electrical connector.
  • Depress retainers, arrows, and remove bulb holder.
98971817.gif Installing:
  • Install in reverse order of removal.
And the Center Mounted Brake Lamp.
High mount Brake Light Removing And Installing:
The high mount brake light is installed in the rear shelf.
98971288.gif Removing:
  • Disconnect electrical connector from high mount brake light.
  • Remove rear shelf
  • Un-clip high-mount brake light from rear shelf, arrows.
NOTE: The bulb holder base plate contains soldered- in light emitting diodes (LEDs) that are not replaceable. In the event of LED malfunction, replace complete bulb holder.
Additional
Mar 13, 2010 | 2000 Volkswagen Beetle
Pilot will light but heater will not ignight
You may need to replace the Ignition Module. Have someone check to see if it is sending power. I have the same problem and need to replace the Fenwal automatic ignition system. The part cost $390 - check inside the heater for the model #
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Need to replace socket in Hi hat ceiling fixture
Do you have a discription? In order to get to the main wires of a flush mount fan turn off power to fan, remove Lt kit if applicable, Take off blades. Does this sound right ?
Nov 13, 2008 | Electrical Supplies
Jandy Laars Lt 400,000 Btu Heater Logo
220 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
