Question about Sony VAIO PCG-7Q1L Series Laptop Charger (1300666LMD0011958)
We have a Sony Vaio PCG-7Q1L at home, since few years. It has started to present frequent freezing, likely due to overheating. As we turn it off for few hours, and turn it back on, it works fine until this happens again. Is there any software fix cure, as I could see there is for some other Vaio model? Or else then, what should be done? Thanks in advance.
    Scholar:
  • 84 Answers
If the problem is truly overheating, then your fix is better cooling.
Usually the cause of overheating on a laptop is that the ventilation slots are clogged with dust so in most cases, just taking a can of compressed air and using it to blow the dust out of all the slots can be enough to restore proper ventilation to your machine. You should be able to pick up a can at any electronics or department store. Use it to blow out all the slots on the side and the bottom of your machine. Make sure to pay special attention to those slots that have a fan attached.
If that doesn't work and you still suspect that it's because it's overheating, you can look into buying cooling trays specifically made for laptops. Something like this: http://www.everythingusb.com/belkin_laptop_cooling_pad_13845.html
Hope that helps.
Posted on Mar 28, 2011
Find driver webcam ?
look up driver for make of web cam download and install
Jul 30, 2014 | Sony VAIO PCG-7Q1L Series Laptop Charger...
Sony vaio PCG-7142L keeps freezing
Can check if the battery is low ... or is not (or cannot) holding a good charge ... when you unplug it (from the charger) ... when this happens ?
If that is the case, it may "freeze" while it is busy trying to store the contents of your memory before it shuts down (or hibernates). Does it shut down (or goes into hibernate if you let it continue to "freeze") for a while ? If so, then it's your battery.
If the battery doesn't hold a good charge, the laptop will run only a short time (while unplugged) before it has to shut down due to low battery. And if this is the case, consider getting a replacement (new) battery. And follow the initial charging instructions (for a new battery) to lengthen the life of the battery.
Apr 03, 2014 | Sony VAIO Computers & Internet
Sony vaio PCG-61211M wont turn on and the power button starts flashing on and off
This can be a sign of a discharged battery, and this may be due to a faulty adapter or the connection in the laptop.
Dec 13, 2013 | Computers & Internet
I have a Sony VAio, Model PCG-7Q1l. The fan is noisy and to remove the back, I need to remove the DVD player. I took out the screw and while the player is loose, it won't come out. I don't see
PCG-7Q1L is the Chassis number.
VGN-FJxxx should be the model number.
Ummm, VGN-FJ350
There is a semi-metallic rubber band, holding the DVD drive from the inside, and.............
NO! I'M JUST KIDDING!
It's a little green Martian man, tugging back from the other side.
After you remove the Philips head screw, tap the DVD drive's tray release button.
Ease the tray all the way out to the extended position, and then gently pull on it.
Pull DVD drive out of laptop.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 24, 2013 | Sony VAIO Computers & Internet
Charging or power problem
check the cpu and that is shortage.., check the other power ic something bad ic need to replace..
Sep 07, 2009 | Sony VAIO PCG-K35 Notebook
My Sony Vaio laptop turns off constantly. It
When it is running I need to know if the air coming out of the vent slats is hot or just warm. It sounds like the laptop is overheating and shutting down so it doesn;t burn itself up. Get a can of compressed air they sell at office supplt companies and use short bursts of air in the vent slots and fan housing. If there is an access panel on the bottom that allows access to the processor and heatsink, blow that area out too. Then check the Sony support site and see if they have a BIOS update for that model computer. Some manufacturers are writing new BIOS instructions for their laptops for the fans to run longer and faster to take care of heat issues.
Sep 06, 2009 | Sony VAIO PCG-K35 Notebook
I want to Down DRIVERS for Sony VAIO Version PCG-7L1M
Is it VGN-NR310E/S?
if so go to:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNNR310ES&LOC=3
All the drivers for XP as well as Vista Home Premium are there.
Hope this helps.
Bastian
Jun 02, 2009 | Sony VAIO VGN-NR310E/S Laptop
Sony Vaio
If you get the initial Sony screen, then this is a hard drive crash, and the drive will need to be replaced. If you do not get the initial screen, then it a failed motherboard component. Either way,, you have a hardware issue, and there's no simple fix. I hope your parents will be away for a while. If you need anything else, just ask, and good luck.
Aug 21, 2008 | Sony VAIO PCG-K35 Notebook
Sony VAIO PCG-7Q1L Series Laptop Charger (1300666LMD0011958) Logo
216 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
