Question about Maxtor MaXLine Plus II 250 GB Hard Drive
Hi my problem is i have maxtor maxline plus ii 250gb i put it like external hard disk but its not not recognized, i try with some tools to fix it because some answers say its mbr its the probleme of that itry to fix it but nothing so i hope to help me of that and thanx for all ur jobs u do.
  • Maxtor Master
  • 27,725 Answers
Restart your computer with the XP Setup disk in the CDROM drive. If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer. Enter your Administrator password. If you don't enter the correct password, you cannot continue. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed. Your damaged MBR will be replaced with a shiny new one, and you should then be able to boot your system normally. In some cases, you may need to repair the boot sector in addition to the MBR. If your system still doesn't boot properly, repeat the steps above, but issue the fixboot command instead. Hope this helps
Posted on Mar 28, 2011
Will not recognize sata drive need to know necessary connections
There are only two connectors on a SATA drive, namely POWER and DATA.
Check that both cables are securely connected.
Try the disk-drive in some other computer.
Nov 02, 2010 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
I would like to reformat my drive to zero is there a program that i can download to do so,i have a 200G DiamondMax Plus 9 from Maxtor
yes ther is...low lever format tools...u can find them any were in the web, **** manufactures usualy have there own tools and recomend them for there own drives...like the maxtors low level format tool is in "hirens boot cd"......
and ther is also some old bioses that include such option/tool.
the idea is to fill all the hard disk sectors with zero...u can even do it urself ;)
Dec 30, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
I can't access the hard drive
You will need to initialize it from the Disk Management. To do this, right click your My Computer and choose Manage. At the left panel click on the Disk Management. The list of available drives will show on the right.
Right click on the drive and a window will popup. Select create partition (primary partition). After you've selected your partition , now you need to format the hard drive. Choose quick format. Right click again on the partition you've just created, now select "Format" and select NTFS. Click ok and it will guide you until it is finished.
If you need further assistance, just let me know.
Oct 03, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
I need to set jumpers on hard drive Maxtor Maxline plus II y653z5le as a secondary drive. How do i do that?
on the drive there should be a diagram for how to set the jumper settings. you want to set it to slave.
Jun 13, 2009 | Maxtor MaXLine Plus II 250 GB Hard Drive
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Hard drive wont show up
change the jumpers to slave if it is on the same cable as the master should show up
if it is set now on master it wont show up
Feb 23, 2009 | Maxtor MaXLine Plus II 250GB 7200 RPM...
Unable to see the 250Gb external drive shown on 'my computer' when plugged in
Hi - thanks for your quick response, much appreciated .........I will try again to explain!!
We have purchased a 250Gb Maxtor portable hard drive which I was told was plug and play. We have followed the instructions for connection but no drive letter is showing up and the external drive is lit up and making a constant beeping noise. The computer doesn't seem to be recognising that an external drive has been connected.
To test our computer out I have connected an 8Gb memory stick to the processor and it shows up as drive H immediately.
FYI - we have XP running on our machine.
Hope you can help!! Thanks
Oct 25, 2008 | Maxtor MaXLine Plus II 250GB 7200 RPM...
Can't format or create partition......
It maybe that your motherboard bios cannot support 250GB and needs an update, but caution applies here. The other problem maybe that you need to use the hardrive on the 'CS' (Cable select setting). Lastly if you already have a pc running, use this drive as the slave the go to the Maxtor website to make use of the diagnostic/formatting and partition tools.
Feb 27, 2007 | Maxtor MaXLine Plus II 250 GB Hard Drive
you can try an FDISK form a windows boot disk, but you may need to read up a little on how to use it. or maxtor has a program available on their web sit called powermax that can try to find & repair possible problems. powermax may be the best & easiest way to go. good luck.
Maxtor MaXLine Plus II 250 GB Hard Drive Logo
79 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
