I have an emerson ld195emx television. it has a dvd stuck in it and it will only show the extract and retract signs on the tv. it will also show the play sign, but it will not play any thing what is the problem
  • 11 more comments
  • Vernon Johnson
    Vernon Johnson Mar 28, 2011
    it is stuck and will not come out
  • Vernon Johnson
    i got the back off and pulled the dvd out. i see the lens part just keeps going back and forth. it will not go all the way back and it just keeps hitting up against this motor.
  • Vernon Johnson
    it seems as though the lens is sitting on the dvd. when i try to put the dvd in it will not go in unless i push it. the lens seems to be on the dvd when i do this
  • Vernon Johnson
    no it does not spin
  • Vernon Johnson
    where is this switch located
  • Vernon Johnson
    the switch i believe is two white knobs sticking up and they run across a rail. i got them b ack in place and the disc tray did start to lift up but the disk still does not load or unload. it just continue to go back and forth. i have notified that my tv was dropped and that is when it started to do this.
  • Vernon Johnson
    i will be talking back with you later my internet connection is going out. i am sorry. i have to keep turning it on and off in order to continuously talk
  • Vernon Johnson
    Vernon Johnson Mar 30, 2011
    i have the dvd and i place it inside the player but it pulls the dvd half way in and kicks it back out why is this
  • Vernon Johnson
    man, you are pretty fast!!!! when it loads it seems to want to load but it pulls the disk a few times before it ejects. it pulls it in halfway and then it seems that there is something keeping it from fully loading and it ejects back out.
  • Vernon Johnson
    i had not taken it apart, but when i did i see a plastic piece was loose and moving around inside when i leaned it backward. it looks like a horshoe it is not broken but it is a loose from something. it is white and it has something to do with loading
  • Vernon Johnson
    Vernon Johnson Apr 01, 2011
    you have done a great job. i truly appreciate your help. now i must put my electro-mechanical skills to work thank you and have a nice day.
  • Vernon Johnson
    jdvillanueva was very professional and very helpful.
  • Vernon Johnson
  • 2,098 Answers
Hi John,
Does the disc stuck in the player(didn't eject). Let me know to assist you further.
Jdvillanueva
Posted on Mar 28, 2011
  • 10 more comments
  • Jdvillanueva
    Jdvillanueva Mar 28, 2011
    It is a mechanical problem, if you can take it apart, clean the mechanical, also clean the optical lens with soft cotton buds...check also the spindle motor(spinning the disc) with an ohmeter set in X1, good spindle motor will read fairly low resistance and it will spin while testing. Bad spindle motor will read fairly high resistance and will not spin while testing. Test it without the disc loaded.
  • Jdvillanueva
    does the disc spin?
  • Jdvillanueva
    the switch didn't touch by the mechanical when the tray loaded in the assembly. Check this mini switch, the mechanical will hit this switch to give the command to the processor...most problem is the tray didn't sit in properly which will not get the switch on...
  • Jdvillanueva
    it is hidden under the tray...
  • Jdvillanueva
    when the tray closed the lens will go up at the same time the switch will be pushed on by the slider, when you eject the tray the lens will go down and the slider will release the contact to the switch. Observe it while loading and ejecting the tray.
  • Jdvillanueva
    don't load disc to see the movement of the lens, if the lens didn't go up while loading the tray it means the switch didn't touch also by the slider, mechanical problem....
  • Jdvillanueva
    Hmmm, yes you've got it... check the connectors for loose connections but the problem is that like what you've said the unit was dropped... Note that the main board is quite sensitive to static and also this cenario will caused it for malfunction...
  • Jdvillanueva
    ok bro I will go to work for now, have a nice day!
  • Jdvillanueva
    Jdvillanueva Mar 30, 2011
    If the unit encountered a hard time for loading the tray it will automatically eject. Ensure that you set it back in the right way...
  • Jdvillanueva
    If you've took it apart, I've suspected that you didn't got it back in the right way. Try to dis-assemble again and this time double check the tray and the slider plate(touches the switch) in the right slot.
  • Jdvillanueva
    I can't figure it out what is that piece, but of course you need to get it back in. Check also if there was another piece blocking the tray. Much better if you can dis-assemble the mechanical to check where that piece came from.
  • Jdvillanueva
    Jdvillanueva Apr 01, 2011
    I've appreciated your comments so much, thanks a lot bro and good luck. Have a nice day!
I need a manual & remote for a emerson model ld195emx,serial ds1ao933256936 tv
Hello, Steve -
You can find retailers selling replacement remote controls for your Emerson TV model ld195emx by using your favorite search engine (Google, Bing, Yahoo Search, etc.) and the following search phrase with quotation marks as shown:
Emerson ld195emx "replacement remote"
Choose the retailer from which you want to order and purchase a remote control or visit the local bricks and mortar retailer in your area.
Best wishes.
Apr 02, 2018 | Emerson Televison & Video
I need an Insight remote (yes, it's an old remote) TV code for an Emerson LD195EMX...any clue?
There are difference types of Insight remotes. Each might have slightly different codes for your TV. I found the following site that might help you. It will help you step through the programming of your remote. I picked one of the remotes at random and searched for the Emerson LD195EMX and it was there.
This should do the trick for you. The link is: http://www.myinsight.com/Help-cable-digital-remotecodes.asp
Nov 19, 2013 | Emerson LD195EM8 19 in. LCD TV
Test mode fix for LD195EMX
Call the manufacturer for the procedure. I checked the manual and it's not in there.
Dec 29, 2012 | Emerson LD195EM8 19 in. LCD TV
Dvd stuck inside
un plug the tv open the back by unscrewing it take the cd out and put the tv back together
Nov 22, 2012 | Emerson LD195EMX 19-inch LCD HDTV/ DVD...
Need remote control for LD195EMX
This is what I could find. Unless a universal remote will work. http://remotes.com/store/emerson/ld195emx.html
Jan 04, 2012 | Emerson LC195EMX 19 in. TV
My tv losses the signal. Emerson DVD Video compact disc digital audio Model #LD195EMX September 2009 Serial #DS1A0940323332 What should I do?
open the t.v look rca input in the board if have looses of solder and the rca cord in your emerson dvd check if have problem.. or replace rca cord that all thanks
Jul 15, 2011 | Emerson Televison & Video
My Emerson 19 with DVD player won't read the DVD wht?
The reason your emerson wont read the DVD is either the because the lens is weak or bad.
Tyr to use a lens cleaner to clean the lens and if that does not work, then it simply means that the lens is bad and needs a replacement. As soon as you replace the lens, then it will be able to read DVDs.
Take care
Oct 11, 2010 | Sylvania LD195EMX 19 in. TV
Emerson ld195emx tv/dvd remote code????
Enter 4737 and the password will be cleared
Jan 02, 2010 | Emerson EWC20D3 20 in. TV/DVD Combo
Televison & Video Logo
202 people viewed this question
Top Televison & Video Experts
