Question about Plantronics Supra H51-M10 Consumer Headset
I recently bought a 2nd hand plantronics H51 that plugs directly into my corded phone. I can hear perfectly, but no one can hear me. HELP! I am needed in a conference call tomorrow morning. My corded telephone is an oricom. I have also ordered an M12 amplifer hoping that this will help me be heard. I hear no no trouble, just cannot talk. HELP ME PLEASE.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
One of the specifications for this product is that the microphone has volume controls on it. Try increasing your volume using those controls. They should be located on the receiver. If that doesn't solve the problem, you stated in your request that it was hooked up to your corded phone. Try increasing the volume on your phone and make sure all wired connections on the phone are hooked in properly and are properly secured in their terminals/ports. If that fails, try your amplifier. There could be a wire shortage or bad connection internally within the headset and microphone. I hope increasing the volume or correcting your wire connections will solve your problem. Thanks for choosing FixYa to be your one-stop place for finding solutions. Thank you have a good day!
Posted on Mar 28, 2011
I have Nortel T7316E phones and Plantronics HW251N headsets. Is there a way to increase the volume for the mic so that the caller can hear us better?
The A10 direct connect cord used on the Nortel T7316E primarily will increase the speaker volume. If the problem is that your microphone is too low, you will need to use an amplifier, the M22. Remember that the amplifier needs to be connected through the HANDSET jack not the headset jack. Here is the link for the Plantronics M22.
Good luck from Headsets Direct!
Aug 05, 2011 | NorStar T7316E Corded Phone
I have plantronics t10, i have been able to use it in the past, but tried to plug it in today and the base red light (on/off) lights up red, but no dial tone. none of the buttons work.
It might be that you have a cord plugged into the headset jack. Try looking at that, if that is not it, it may be the cords are not plugged into the correct spot. I am sending you the Plantronics user guide for the T10 headset.
Jul 18, 2011 | Plantronics T10 Corded Phone (0031-t10)
Plantronics M175 headset makes crackling noises when speaking with it on and is not loud and clear.
The 2.5mm jack on your phone, that the M175C plugs into, is more than likely causing you the problem. The phone manufacturers do not dedicate a lot of power to the 2.5mm jack, so sometimes people have a hard time hearing you or you hearing them. If you are using a cordless phone, you could use a Plantronics CS55H wireless headset. This headset is intended for only one phone line, not multiple lines. The CS55H's TR1 plugs directly into the wall jack instead of your cordless phone. This eliminates using the 2.5mm jack on the handset that is causing you problems. The headset come with a one year warranty.
Plantronics CS55H Wireless Headset
Good Luck from Headsets Direct!
Jun 22, 2011 | Plantronics M175 Headset
I HAVE A KX-T7633 AND IM TRYING TOGET MY PLANTRONICS CS55 TO WORK WITHOUT UN-HOOKING THE HAND SET
You can use the cord part number 78333-01. (I have included the link.) This will replace the cord that is plugged in between your CS55 charging base and the handset jack on your phone. It will plug into the base of the CS55 and the round headset jack on your phone. You will not have remote answer. Push the headset button on your phone and then press the headset button on the CS55 headset.
May 31, 2011 | Panasonic KX-T7633 Corded Phone
Hello. I recently bought a Plantronics Gamecom 367 Gaming Headset and found a big problem: My Microphone is not working. Please Help.
There is no information on the Plantronics Game-com 367; no manual. If it is still under warranty get it exchanged as soon as possible. You might want to look at the place where you purchased it for warranty information. Make sure the cords are plugged in correctly, and make sure that your computer recognizes the new device. You might have to look at the control panel to see if the mic is turned on.
Apr 21, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
I am trying to use a plantronics headset system and cannot get a dial tone. Is this Norstar phone compatible?
You don't say what headset it is, but I will to help you.
If this is a Plantronics corded "H" series headset you will need to use an A10 adapter cord, which plugs into the headset jack on the phone.
If this is what you are using and you don't hear anything then you need to probably need to switch to an M22 amplifier box, which is then plugged into the jack where the telephone handset was plugged in.
If you are using a wireless headset it plugs into the handset jack where the handset cord was plugged into.
Mar 03, 2011 | NorStar M7324 Telephone
I can hear patients and a dial tone if i pick up the phone but noone can hear me
Please pay special attention to where the handset cord is plugged in. Then, check where the cord is that comes from the S11, it should be plugged into where the handset cord was. Once that is done check the compatibility slide switch. Adjust the volume on the amplifier. The handset must remain off the of the cradle when making a call. If the cords are not in the correct place it will not work correctly.
Sep 02, 2010 | Plantronics S11 Headset
Encore/polaris h51 headset, compatible with avaya 4610sw phn
for best practice they might have asked you to do that but you can use any brand you want with avaya phones .
May 28, 2010 | Plantronics Supra Polaris P61 Headset
Headset not working
The fine wires in the cord casing do break easily. If your RJ9 connection is loose, then the brass contacts are not making good contact inside the T10 base. Not many options, unless you can get the RJ9 clip repaired, but to get a new system.
Dec 16, 2007 | Plantronics (45647-04) for S10, T10, T20...
Radio Communications Logo
82 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
