Question about ASUS UX50VRMSX05 Notebook
My ASUS UX50 laptop has problems starting windows. Every time I turn it on it says "windows failed to start" and gives me the option of choosing safe mode, safe mode w/ command prompt, last known good config., and start normally. No matter which one I choose, the windows load bar comes up but it never gets past that. Either it just stays on that or it freezes up.
  • dallasn_08 Mar 28, 2011
    now the blue screen comes up saying unmountable boot volume
    Novelist:
  • 107 Answers
Seems like there are Operating System files that got corrupted. Try to boot the PC into the Windows OS setup disk. Run the setup, choose the currently installed Operating System then select Repair. For more details please check this link - click here
Hope this help. Goodluck!
Posted on Mar 28, 2011
  • 1 more comment
  • Lester Mar 28, 2011
    The solution I posted should fix this issue, you can also refer to this documenthttp://support.microsoft.com/kb/555302. What a stupid guy. Pathetic.
    thanks for calling me stupid I really appreciate it
Asus x83v won't boot up
Unplug the machine, remove battery, leave the battery out, plug in the machine, try to boot normally. If the fails unplug, plug in, push the on/off button and IMMEDIATLY start tapping the F-11 REPEATEDLY. Enter restore/recovery section select a date before this problem started and restore. If that fails do a system recovery to factory settings. Or if you have a Windows Vista repair disk, Windows Vista Install disk that you can use to repair
Nov 12, 2012 | ASUS Computers & Internet
Asus k53E sx 194 ov start up wont repair cant do nothink useing my sons dell
Julie, start your laptop and before it gives the start up windows logo, press F8 a few times. If you pressed it at the right time than you shall see a bunch of options:
First, try to boot your computer using "LAST KNOWN GOOD CONFIGURATION" and see if it works. If it works than its all fine and smooth sailing. Login to your windows and then as a precautionary measure, Re-install your Windows from the Asus Recovery Manager.
Second, if the first option fails, then select, "SAFE MODE" option and it shall login windows Safe Mode. From there go to Asus Recovery Manager and re-install your windows to be certain that it shall work fine now.
Nov 01, 2012 | Computers & Internet
I read that the WD Scorpio Blue Drives have an "Advanced Format." If this is true, then, my primary question is, "Is buying a new Asus laptop the most effective time/cost option to retrieve data from
Your drive is probably toast. Back up early and back up often. If you reformat you will lose everything. This sounds crazy, but please bear with me. Remove the drive and place it in your freezer and get it as cold as possible. A deep freeze is best. Let it sit overnight. Be prepared to reinstall it and fire up the laptop as quickly as possible. You may get it to fire up and boot properly. If so, have a brand new drive that you can clone. Clone the new drive and replace the old one. It is no good. note: After you replace the drive, you might get away with a reformat and use it as an additional storage drive, but it will always be suspect. don't store anything you want to see again. Backup, backup, backup!!!
Sep 08, 2012 | ASUS Computers & Internet
How to Replace Bios? Boot & Reformat Attempts Hang (on every HDD) - I guess BIOS is Corrupted
You can go to the manufacturer web site and go to support then to drivers and downloads there should be a BIOS flash software utility at their site. Click Here to go there. Select your model and make sure it is the correct one. I would also go for the automatic driver update, this will find and seek any drivers for your laptop that are needed, missing, or upgrade them.
If that does not provide the info you need their is also a support number as well as live chat at the link above. I hope this assisted you in some way. John
May 02, 2012 | MSI Computers & Internet
While using my Asus Eee PC netbook on battery mode, I lost all power. When I plug it in for ac mode, the power comes back up and the screen gives choices of "safe mode", or "start windows...
Obviously there is a problem with either with you battery or charging section of your laptop, first you check your battery is charging or not, also check by replacing a new battery,,,,
rate me if found usefull
Aug 27, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Have a newish toshiba satellite c655 laptop. we lost our internet feed for a little while (1 hour) and when it came back on, i tried to turn on the laptop and had to reboot. After reboot I got the start up...
When you boot up the laptop press F8 several times then you will get a Windows Advance Options Menu. Then select Last Known Good Configuration and then press Enter.
With luck Windows will start up normally.
Jun 11, 2011 | Computers & Internet
Problem with my ASUS W3J also with BIOS.
Sounds like your hard drive is toast. Replace your hard drive and try again. If it continues, it may be time to replace your laptop.
Also check your recovery disks for heavy or concentrate scratches.
Nov 25, 2009 | ASUS W3J PC Notebook
When i switch my asus G1 laptop on it brings up a webpage giving me two options 1) launch startup repair 2) start windows normally the problem is that whatever option i press it comes back onto the same...
Try booting into SAFE MODE by pressing F8 after you turn on computer and before Windows logo appears. If you are able to start Windows in safe mode, you may be able to ROLL BACK your system to an earlier date. In the START menu search box, type RESTORE. This should bring up the SYSTEM RESTORE menu. Choose the RECOMMENDED RESTORE option first and see if that fixes the problem. If not, go back and select CHOOSE DIFFERENT RESTORE POINT and select an earlier date.
Jun 17, 2009 | ASUS G1 Notebook
Windows Error Recovery...can't start up!
hello friends...
It seems that your window is corrupted ..may be some system file is missing in your computer...the best way to insert Windows CD and try to repair your window..
Thnaks
May 09, 2009 | Computers & Internet
Emachine m5310 laptop
This generally is the indication that the hard drive has failed and needs replaced. You can try reloading the system, but 99% of the time when I see this the hard drive is shot.
Jul 17, 2008 | Toshiba Satellite A105-S2716 Notebook
ASUS UX50VRMSX05 Notebook Logo
237 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
