Question about Pioneer KEH-P1010 Cassette Player
03 vectra c 2.2 sri
My left hand rear foglight isn't working ive checked the bulb and its fine there doesnt appear to be power coming to it. Can u tell me the wiring colours so i can be sure im testing the correct wire?
Ha Ha, you fell for the old Vauxhall / GM dead bulb trick didn't you !!!
You're thinking "hold on though the 'Bulb off indicator' on the dash isn't lit but the foglight bulb doesn't come on ???
There is something posted elsewhere on the net about this problem as I had this problem too and I didn't believe either?
The thing is whilst all of the necessary hardware is there for the rear foglight on that side ie: lampholder, bulb, wiring etc! it isn't actually connected to the harness. Therefore you will never get the light to work because there is no power going to that particular light.
Vauxhall say that the bulb may be used as a spare for the other side though ??? handy that eh ?
Posted on Mar 17, 2009
Front left turn signal doesnt work
The turn signal circuit is different from the parking lights. So the headlights would not be involved.
You should have power on one side of the bulb for parking lights and the other for turn signals.
If you have no power for the turn signal circuit, I would look at the turn signal switch. It powers each bulb separately.
Aug 21, 2012 | 2005 Saturn Ion 2
My right side turn signal cuircut works but my left side doesnt ive checked the light bulbs but they're all good.
if hazard lights are ok and you can see all are working, you can tell that your signal lever switch is broken.
Nov 18, 2011 | Cars & Trucks
I have a 99 buick century my drivers front blinker bulb doesnt work, the rear works fine my dash indicator doesnt work either ive tried the wiring diagram but didnt get anywhere any ideas?
change bulb in front if indicator doesnt blink or blinks fast if new bulb check socket connectors may have corrosion or damaged wiring
Oct 30, 2009 | 1999 Buick Century
Left and right brake light doesn't work but center lights does
check behind the brake peadle for a little button that pushes in and out when the peadle is pressed(this is your brake light switch) some cars have more than one of theese. manualy let the button out if the light works the switch is good if it does not disconect the harness from the switch and take a small piece of wire and jump the two prongs on the harness if the brake lights come on then you need a brake light switch. if this doesnt work check for power at the switch. if no power you have a bad fuse if there is power and you already jumped the wires to the switch then you have a broken wire between the switch and the tail lights.
Dec 25, 2008 | 2001 Oldsmobile Alero
Vauxhall vectra sri 03 plate
I just cant believe that mechanic has looked at it does not know . My first thought is the flasher located in or around your fuse box they cost under $10.00 dollars. And you can do it yourself .
Sep 29, 2008 | 1997 Acura CL
I have a UK registed, Feb 2000 AUDI A6 2.7T QUATTRO AUTO ESTATE, Is it right that these are fitted with just one rear fog light that operates and the other is just for show.
Yes it's true. What I did on my US-spec A4 is to pull back the trunk lining on the passenger (right) side, where there is no functional foglight (my rear fog from the factory is on the left side). What I found was that the "bulb tree" has a fully powered socket for a bulb that would fit into a rear foglight on that side, but no bulb was installed. The part of the taillamp that would have a hole for such a fog bulb had a **** instead. I used a drill to widen the **** into a hole large enough for a bulb, and installed a bulb in the bulb tree, and voila - dual rear fogs:)
Jul 21, 2008 | Audi A6 Cars & Trucks
Pioneer KEH-P1010 Cassette Player Logo
247 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
