It is FO 2 its happpend twice no papper work for it?
  • 3,051 Answers
Hello there and thank you for choosing fixya
Depending upon the type of washing machine, you may notice an "F21" or "F02" error code. An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
Please feel free to post me a comment back if you need help with the dissasembly of this ok?
best regards Mike
Posted on Mar 28, 2011
TOSHIBA 455 MECHINE HANGS ON COPYING
Clean the 2 registration sensors and the registration clutch. Mostly this is caused by paper dust to the 2 registration sensors. This sensors is easily removed by opening the side cover , you'll see the registration sensors at the lower part of the drum unit. There is only 1 screw holding this. Remove that screw and slide it to remove.
Oct 27, 2014 | Toshiba OEM ESTUDIO455SE 45 PPM...
Entanglement papper
Sir/Madam
I suggest You Watch You Tube Video For HP Printer Entanglement Papper http://www.youtube.com/watch?v=9cCC0cCmBs8 or
Go To official HP Printer Website For Your HP Printer Problem Below Link On:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=us&dlc=en&lc=en&product=441125
In case You Still Having Hp Printer Problem and Need Online assistant Then follow Us On:
HP Printer Support
Feb 11, 2014 | HP Officejet 5610 All-In-One InkJet...
Incomming fax same page printing contenusly and wasting paper
put machine oil on papper roller let run a few pappers intell it gets worked in then see if paper is sticking if this doesnt work blow it out with air in can there has to be papper jamming the papper side.
Feb 13, 2011 | Ricoh 3310Le Fax Machine, FAX3310Le...
Paper getting jammed in printer
1.take out the tray of the pappers
and look inside if some piece of pappers is
2. clean with ajax the feed rollers
Nov 19, 2010 | Lexmark X3550 All-In-One Printer
I can't write to CD-RW discs with multiburner.
1.type regedit on run option press enter then GO TO mycomputer\hkey_local_machine\system\currentcontrolset\contro\class\{4D36E965-E325-11CE-BFC1-08002BE10318 BY CLICKING RESPECTIVE ITEMS AFTER EXPANDING.
2.on the right hand side if there is any lower or upper filters remove them.
3.In run option type devmgmt.msc and enter then fo to dvd cd rom drive option and after expanding whatever the value comes right click and uninstall.
4.restart the system twice then check
5.if not working drive is faulty.
Thanks.
Aug 10, 2009 | Lenovo Thinkpad T60 Notebook
How to rip off papper?
Doesn't the Form Feed button work?
Mar 25, 2009 | Brother HL-2040 Laser Printer
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Problem withColour Cartridge 854 for HP Photomart c4188
it could be the cartridge wasnt properly in place.
turn off unit and manually remove the cartridge again ensure that you install correctly.
Aug 06, 2008 | HP Photosmart C4180 All-In-One InkJet...
Wont Turn On
Try moving the power supply connector around.
Jul 10, 2007 | Radio Shack Pro-2018 Scanner
Washing Machines Logo
178 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
