Question about Dell Dimension 3100 PC Desktop
I have a Dell DImension PC. It suddenly shutdown during i surf the net and when i restart the PC, it doesn't boot-up and the 3 & 4 diagnostic light lit-up.
  • gcvillanda Mar 28, 2011
    HI Dave,
    Thanks for the quick feedback. My PC has 1GB RAM. I think i lost my PC manual already. Would cleaning the RAM connector help?
    Thanks for the feedback Walter. Appreciated!
  • Dell Master
  • 998 Answers
Memory modules are detected, but a memory failure has occurred.
Posted on Mar 28, 2011
  • Walter H Boehm Mar 28, 2011
    If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • 961 Answers
I'd have to look at a manual but i'd say you have a ram problem. I will look at he manual and if you have one you should look as well. How much ram do you have?
  • David Petry Mar 28, 2011
    You can try> it's possible but unlikely that it came loose or is dislodged unless you knocked it over or something but by all means i'd try it. If you only have one stick you can't really test your system. You'll ahve ot get anither one and, pull the old one out and restart. If it boots you found your problem. You may want to add the second one anyway. More ram is better and faster.I did look at the manual and it's definately the ram.
    Dave
Dell error code 0142. Status 72
This is sounding like a hardware problem--possibly memory.
A Dell has a built-in diagnostic program that you can access when you first start your computer.
When you first turn it on, you'll see a message at the bottom of the screen that tells you to press (F12, I think) for boot options. Once you press that you'll get a menu that will allow you to select a boot device. Another option just below the devices is the diagnostics option. Select that and run a system diagnostics. It will pick up any hardware problems you have.
Mar 22, 2012 | Dell Dimension XPS Gen 4 PC Desktop
Hi, I have a dell dimension 5100. I inserted a 1gb ram but it was the wrong one. I took it out and replaced it with the old ones. Now the computer doesn't boot properly - turns on but doesn't load...
Remove all the memories and insert them again, make sure you insert them in the proper way as the slot is keyed.
Memory issues can be identified by the beep sounds.
If you have more than one memory, remove one and insert only one of them and try to boot.
Hope this will help.
Aug 19, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Dell 4700 wont boot up
to boot up:
1.Restart Your computer Press Delete until BIOS setup appears.
2.Go to Advance BIOS setup then Boot sequence.
3.First Boot Your CD-Rom, 2nd Boot the HDD-0.
4.Save The Settings Then restart.
5)when appear "press any key to boot" then click ENTER button of your keyboard it will automatically boot.
Aug 17, 2011 | Dell Dimension 4700 PC Desktop
How Can I boot my Dell Dimension 4700 to a windows XP SP1 Bootable installation disk, I've tried changing the boot sequence and everything:( It just won't work, I don't know where to begin with this...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
hope this helps
Dec 15, 2010 | Dell Dimension 4700 PC Desktop
No Sound Dell Dimension 3000
1)Check whether sound is enabled in bios.
2)Install Latest drivers from support.dell.com
3) Boot From the ResourceCD to Run Dell Diagnostics
1. Insert the ResourceCD in the optical drive, and restart the computer.
2. Tap the <F12> key during startup until the One Time Boot menu appears.
Note: If the One Time Boot menu does not appear, restart the computer and try again.
3. Press the <Down Arrow> to highlight Boot from CD, and press <Enter>.
4. In the ResourceCD menu, select Run the 32 Bit Dell Diagnostics, and press <Enter>.
5. The Dell Diagnostics screen appears.
Run sound test
Jan 10, 2010 | Dell Dimension 3000 PC Desktop
My dell dimension C521 has number 3 & 4
http://support.dell.com/support/edocs/systems/dimc521/en/SM_EN/tshoot.htm#wp1064555
This gives you a list of every possible fault on this machine! It looks like you will have to contact DELL directly on this one!
Oct 19, 2009 | Dell Dimension C521 PC Desktop
Dvd r/rw on Dell E1705 laptop computer quit playing cds and dvds. Makes grinding start up noise but does not play
Your system comes with on-board diagnostics. Run the diagnostics to check if the problem is with the drive or windows.
To run the diagnostics follow the steps below
1. Shutdown the system
2. Press the Fn+Power button together
3. The screen will display color screens
4. Follow the prompts until it takes you to advanced diagnostics
5. Do a custom test on the optical drive.
If you are unable to run the diagnostics
1. Find the dell resource cd that came with the system
2. Insert the cd in and restart the computer
3. At the Dell logo screen press the f12 slowly 5 times
4. Select boot from cd/dvd drive
5. Press any key to boot from cd .... message appears press enter
6. If the system starts from the cd .. this would mean the drive is ok
pOst back what were the diagnosis
Thanks
proton
Apr 11, 2009 | Dell Inspiron E1705 Notebook
Dell Dimension 9200 keeps shutting down and won't start up
the key issue on the uncommanded shutdown is the POWER LED. If upon shutdown, the power LED Flashes AMBER, then the power supply is suspect.
If no flashing amber indication, then the next think I check is the heatsink (Processor overheating) remove, clean and apply arctic Silver heat transfer paste, see if the issuje goes away
Last but not least if the system is failing to boot, and displays a 3 4 diag LED code, then you may have a RAM module that is bad or may just need reseating. Running diags off of the Rersoujrce CD is something to look at too
Mar 28, 2009 | Dell Dimension 9200 PC Desktop
Blue error screen and system shutdown on Dell Dimension C521
Rule of thumb test ram out first usally that is the cause what does the code say on the blue screen
Feb 13, 2009 | Dell Dimension C521 PC Desktop
Dell Dimension 3100 PC Desktop Logo
239 people viewed this question
Alun Cox
