Question about Keurig B60 Coffee Maker
The coffee maker will no longer turn on. It shut off one morning and now I cannot get it to turn back on. Tried different outlets and know it is coffeemaker.
  • 6,771 Answers
If you have no power this is often caused by a thermal fuse that opens up when the temperature is exceeded in the coffee maker. The unit will need to be dis-assembled to assess the situation, some use a power transformer with a built in thermal fuse.
Posted on Mar 28, 2011
  • 1 more comment
  • Craig S May 06, 2012
    How do I locate the thermal fuse? I can't find any diagrams or schematics online.
  • John Cunningham May 06, 2012
    The thermal fuse is located on the heating element, it should have the temperature marked on it and must be replaced with the identical value. The part is silver and pointed at the one end with long leads.
    I forgot to mention the on/off switch should be checked, fails on occassion.
Coffe maker has shut off no power
Pad and Circuit board shorted. Return for replacement.
Jan 22, 2012 | Keurig Platinum B70 Coffee Maker
I have a Keurig B60, it will not turn on. Working in the morning, after work, later in the day, it would not turn on. Tried different outlet and will not come on. Who do I call or is it worth fixing. out...
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Jul 27, 2011 | Keurig B60 Coffee Maker
Brewer was working fine in the morning, now is off and wont turn back on, curcuit breaker is fine, machine is plugged in. Any ideas?
Test your outlet with another appliance first.
Sometimes a safety trip breaker, such as those installed as bathroom outlets, get tripped and need to be reset. Make sure to press the "reset" button on your outlets. On the same circuit but in a different room, it sometimes gets overlooked as a solution.
If problem is still evident I would contact the manufacturer. Often times they will replace the appliance free but leaving you to pay for the shipping, sometimes only being $10.
Apr 20, 2011 | Keurig Platinum B70 Coffee Maker
We have had our Keurig Limited Edition B 66 Keurig brewer for almost a year. Worked fine until now. The Power will not turn on. We tried plugging other things into the same outlet & their is power;...
Sorry to read about your problem, I hope this helps you out.
It sounds like you unit has a major malfunction. and they do break
Keurig does not make repair's or carries replacement parts for their units. you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Keurig B50 Coffee Maker
My new Breville Keurig machine randomly turns off. I noticed a few times it was right after brewing a cup and it's about to uptake more water or it's in the process of taking up water and heating it. Has...
I just tried the solution from comment dated 1/13/10. I took out the water tank and reseated it. As I did that, I noticed a small gap at the top back of the tank, that it wasn't resting completely against the unit well. I pushed it back and it has not shut off since.
Dec 09, 2009 | Breville BKC600XL Coffee Maker
Why is my coffee maker not working
I will assume the outlet is working and there is no timer that is set to turn the coffee maker on later. There are a few possibilities 1- the switch is defective 2 - there is a temperature sensor in contact with the heating element that is defective 3- the element itself is defective. these parts are all internal and may not be easily accessible without proper tools. All the components can be checked with an ohm meter. Also check for loose or broken wiring connections.
Mar 11, 2009 | GE 106591 Coffee Maker
Cuisinart DCC-1000 shuts off on it's own
Unplug it for 20 minutes or longer to fully reset it. At that point, the default shut-off time will be two hours, unlss you use the auto-off to increase this time limit to 3 or 4 hours.
-Tha Mp3 Doctor
Dec 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Jura capresso shuts down
It is possible that the timer unit in the maker is defective and need to be replaced. I would suggest you move the coffee maker to a different outlet and see if you have the same problem. If there is a short in the mechanism or a bad connection in the timer it could be experiencing a thermal shutdown.
Dec 04, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Pot keeps shutting off after coffee completely brewed.
This may be an electrical issue, but I would try holding in the on/off button for a few seconds and see if it still displays 2 hrs as the auto-off time. If 2 hrs does display correctly, unplug the unit for 16 minutes or longer - do not plug it back in a single second shy of 16 minutes. Then reset the clock and reprogram the auto-off Try one more time.
If that fails, it may be replacement time.
-Tha Mp3 Doctor
Nov 28, 2008 | Cuisinart DGB-500 Coffee Maker
Keurig B60 Coffee Maker Logo
533 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
