Question about Vizio P2 42 in. HD-Ready Plasma Television
Remote Sensor on TV Doesn't Work and Can't Manually Adjust Menu
I bought this TV from Craigslist for cheap. I knew the remote didn't work when I bought it, but figured I could either use the cable box remote or manually adjust the TV using the keys on the front panel. Imagine my surprise when I find out the remote DOES work, but the TV remote sensor does not! Not only that, I cannot scroll thru the menu using the front panel buttons. Not sure why, btu they do not seem to work. I have no idea what to do. The captions to the TV are stuck on, and I do not have a cable box yet, so who knows if I can access the menu with a cable box remote. My dilemma: How do you remove the cover of the TV?? Is there any way to fix the buttons on the front panel so I can get to the menu? And is there any way to fix/replace a remote sensor without paying a technician hundreds in repair fees? Oh and I am sure it isn't the remote. It programmed my DVD player just fine. Thanks! I have the same problem. I bought a new remote control and it seems to work fine (as far as responds by lighting up when any button is touched) but no response from the TV. I confirmed this by buying a universal and it worked fine on my other TV but not this one, so I'm pretty sure the remote sensor on the TV is dead. How can I change it?
  • 2 more comments
  • dzag436 Aug 13, 2008
    I tried reprogramming my verizon remote, then tried the remote that came with the set. Tried new batteries on both, neither worked. Tried going directly up to the sensor on the TV and it worked once or twice, then stopped. I wonder if you can buy an infrared port to connect to the usb port to replace the one con the TV. Don't want to send a 42 in TV back. I can imagine the shipping costs.
  • PETECH Oct 30, 2008
    I HAVE THE SAME PROBLEM, I BOUGHT THIS TV AT A SWAPMEET, FOR CHEAP, IT WAS BRAND NEW, BUT AFTER 4 DAYS, I COULDN'T DO ANYTHING WITH MY REMOTE CONTROL, I THOUGHT IT WAS THE CONTROL ITSELF, BUT I DID A RF TEST ON THE REMOTE AND PASSED SUCCESSFULLYT, SO I THINK THE RF CIRCUIT INSIDE THE TV HAS GONE BAD. I WILL TRY TO REPLACE THE RF SENSOR AND LET U GUYS KNOW IF IT WORKED.
  • Anonymous Feb 20, 2009
    I also have the issue where i can program this remote to other devices and they work. Has anyone replaced the RF sensor, if so how hard was this?
  • pars_ss Feb 20, 2009
    I have the exact problem, can you guys assist
I just realized that there is no usb port on this tv. Called tech support at vizio since I'm still under warranty. They're sending a new remote. I know it's not the remote because neither the verizon nor the vizio remote works, although the vizio remote will intermittently work if I'm one foot away from the sensor on the tv and holding the remote on a downward angle. Tech support says they will send a new remote to rule that out before they send a tech over. I'll check the posts to see if you find a solution when I finally get the tech guy out here. If not, I'll let you know what he does.
Good luck.
Posted on Aug 13, 2008
I bought a sharp TV LC-37G4U off craigslist. I don't have the original remote & i need to get to the menu.
Many universal remotes can be purchased and programmed to get the menu to work on the TV. Many can be bought right down the street at a CVS or Walgreens. Also try Walmart.
Nov 22, 2014 | Televison & Video
DnCan't change channels using the remote or buttons on TV. The channel scan will not work either. I
Just a few ideas for you -
Go to some cheap box store and buy a universal remote, they can be real cheap. More than likely, your remote died. Make sure you know your make and model number so you can get the right one.
You didn't say if you have cable, but if you do, reset that connection and let your satellite reboot, see if that works.
Doesn't that tv have controls on it, so you can manually input the channels and adjust sound?
Good luck, Curt
Jan 22, 2014 | Vizio L32 32 in. LCD HDTV
Remote does not work
Infrared sensor inside the TV is damaged. Replace it.
May 17, 2013 | Televison & Video
KP-46WT500 46 in. Rear Projection HDTV-Ready Television convergance adjustment
Try using the MENU button on your remote control to go into the TV picture settings menu. Change the mode to NATURAL, You can also try to manually adjust the color in the COLOR SETTINGS mode.
If that doesn't work, check out the handy troubleshooting chart in TV color problems and see if another solution will work. I hope this helps!
Sep 13, 2012 | Sony KP-46WT500 46" Rear Projection...
Remote to tv doesn't work
Hello
Check the remote first for its infrared emission. If it is OK, the infrared sensor inside your tV is faulty. It should be replaced with same type and number. It can be located just behind the infrared window at the front panel of your Tv. You ahve to open your TV ot access it. It will have three solder terminals, and will look somehat brownish black in colour. Will look like this.
Nov 14, 2011 | Televison & Video
I cant figure out how to put the tv on video 1
With the remote in TV mode, the input button on the remote should change the source (TV, AV1, etc. depending on the TV).
If the input button doesn't work, try a different code for your TV manufacturer. A code that controls the basic functions of the remote may not control the full set of functions of the TV. For some TVs, you can change the source from within the Menu. (It depends on the TV. I didn't notice if there was a Menu button that will open the TV menu on the RCA RCU600M.)
If none of the codes work, check if your TV has a Source or Input button on the unit. See if that button works.
If you have a different remote, please indicate the model.
I hope this helps.
Oct 13, 2011 | RCA RCU600M Remote Control
My original remote is not working. I bought a universal remote and it doesn't work either. Can't get a remote to work on the tv
Hello
The remote sensor inside the circuit board of your TV is faulty. It is the component that receives the infrared signals of the remote control. If this component go faulty, no remote control will go with the TV. This component can be located on the front panel board of the TV just behind the infrared sensor window at the front. You have to open your TV to locate this component. It is a three terminal component, look brownish black in colour. The sample picture of it has attached here. It is very cheap to buy, and can be bought from most of the electronic sparepart shops at your town. If you have a concept of soldering and resoldering, you can replace this component yourself at home OK.
Oct 02, 2011 | Symphonic ST420FF 20" TV
The "menu" on my remote control is not working - unable to retune
You can re-tune manually or purchase a universal remote. I'd recommend any kind of harmony remote. If you buy a cheap one, nobody will guarantee that it's compatible... in other words, you'll be wasting money little by little. Save yourself the heartache and buy a harmony remote... cheapest is a 525 and they work brilliantly.
Oct 06, 2009 | RCA 3-Device Universal Remote with...
Where is the eye for the remote on the TV????
Hi, remote sensor is located behind the front screen, if the remote doesn`t work as well (you didn`t say so I`m assuming it doesn`t) then you either have bad tact switches on the control board (the buttons on the front of the set) or the 5 volt line to the control board is missing, video-tek
Feb 03, 2009 | RCA P52937 52" Rear Projection Television
i bought tv ,just week ago and tv sensor on tv want wwork, that why we cant use remote.
Aug 19, 2006 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Vizio P2 42 in. HD-Ready Plasma Television Logo
1,655 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
