Question about Refrigerators
Frezzer motor or fan seems to be vibrating - Refrigerators
    Scholar:
  • 116 Answers
Hi depending on the brand, if the mounts to the motor is ok, then you will need a new motor it probably has a bearing going bad, but first check the mounts make sure they rae all tight and not broken.
Sean
Posted on Mar 28, 2011
Unit vibrates bad and is not fan or fan motor on roof top
need to check squirrel cage on evaporator end of fan motor shaft.
Aug 19, 2015 | Heating & Cooling
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Jul 04, 2011 | Fisher and Paykel Active Smart E522B...
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Jan 19, 2011 | Beverage-Air CFG24 Freezer
No idea how old this blower is, but we recently replaced the spark plug to get it working and it seems to be working fine, except the vibration is so much that it causes the cylinder to come loose from the...
The vibration is almost certainly an imbalance of the fan rotor. The device is very simple, the only thing attached to the motor shaft (and the only thing that moves besides the motor itself) is the fan. See if you can remove the cover over the fan. You will probably find that the fan rotor has some pieces broken off.
Dec 01, 2010 | McCulloch 26cc Backpack Blower with Dual...
A/C and heater raddle/vibration when fan control turned on
That vibration is caused by something lying in the fan. This causes an imbalance in the fan that gives off the vibration. You will have to remove the blower motor in order to get to the fan and clear the fan of whatever is stuck in the fan.
Oct 06, 2009 | 2004 Chevrolet TrailBlazer
Fridge not staying cold
First make sure that ur frig.is level. Then checx the cooling coils in the back. Make sure that all the vents,frig. and frezzer, are clear. Ur moisture control could be another factor.
Sep 13, 2009 | Refrigerators
Ge fridge makes a clicking noise fan in frezzer
Main control board bad . The board controls the fan opperation and the clicking , sounds like a relay on the board . Replacing the board should solve the problem(s) .
Aug 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Blower fan in the freezer is making a vibrating
only if the fan noise is driving you crazy. the noise is probaly the motor starting to go out. you can replace it. it might save you money in the long run to replace it, if it goes out you could run into bad food in your fridge.
Jun 26, 2009 | GE GSS20IEM Side by Side Refrigerator
Frigerator doesn't get cold but frezzer works frezzer gets way to cold have to defrost every now and then and fridge is warm? dont know what's wrong it's a kemore model # 10675929400 frezzer is on...
Check to see if interior fan motor is running and blades are forcing cold air down to the lower section. New fan motors can be ordered from repairclinic.com or local parts house. Also look for blocked air ducts at back of cabinet.
Jun 09, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
