Question about Ingersoll Rand Air Tools & Compressors
What the maximum working torque for a Ingersoll Rand 1/2 2705P1?
  • 1,940 Answers
Ingersoll Rand 2705P1 1/2 inch 40-200 ft lb Industrial Duty Impact Wrench
Max Torque 400 Ft-Lb
Pneumatic Impact Wrench, Industrial Duty
Pistol Grip Style
Standard Anvil
Square Drive Size 1/2 In
Torque Range 40-200 Ft-Lb
Average CFM @ 15 Second Run Time 4.2
CFM @ Full Load 23
Max Bolt Capacity 5/8 In
Free Speed 8500 RPM
Pin Retainer Type
Required Pressure 90 PSI
Air Inlet 1/4 In
Min Hose 3/8 In
Overall Length 6 3/4 In
Weight 2.55 Lbs
Country of Origin: USA
CR 4Z942
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Mar 28, 2011
Head bolt torque for ir. ss5 air compressor?
It's not that critical, use a torque wrench and make sure they are all evenly tightened like you would do with the head of a car engine. Use basic torque specs for the size bolt. That can be googled. Start with a lower setting on the torque wrench. Tighten the bolts in a pattern, then increase the torque setting and torque the bolts again.
May 20, 2016 | Ingersoll Rand Air Tools & Compressors
Testors Blue Mini Modelers Airbrush Compressor
Air compressors are rated for a maximum pressure and maximum output flow. Your description implies more air is going out of the compressor than it's designed flow rate. Check for a major leak at hose fittings or around the compressor. If this is an old unit, a compressor gasket could be cracked or broken.
May 31, 2014 | Ingersoll Rand - Rand Type - 30...
Impact wrench manual
You can download manuals and parts lists from Ingersoll Rand.
Follow this link:
Ingersoll Rand Industrial Technologies On line Publications
Feb 23, 2014 | Ingersoll Rand Air Impact Wrench 1in Dr...
Torque on ahead bolt
the torque must use is 75ftlbs. that is for the air head.
hope can help.
Jan 30, 2014 | Ingersoll Rand - Rand Type - 30...
Ingersoll Rand 2530KE Power Loss
sometimes the vanes get stuck take it apart and clean and lube it
Apr 24, 2012 | Air Tools & Compressors
What is the maximum operating air pressure fir the IR2190DTi-6
Most I.R. impacts are recommended for 90PSI with the exception for the 285B which is 120PSI.
If you need manuals or parts lists follow this link:
Jan 12, 2011 | Ingersoll Rand Ingersoll - Rand IR2190DTi...
What is the torque for head bolts on my ingersoll rand ss3 compressor?
I can't say from their manual, but I've never rebuilt a compressor (and I check every one with the mfg) for which the head bolt torque isn't in the range of 25 ft. lbs. to 40 ft lbs. If you can't find it, torque to 30 or 35 and you've got it knocked.
Nov 25, 2009 | Ingersoll Rand SS3J5.5GB Wb Ir Portable...
I have a ingersoll rand air compressor rand 4000 60 gl vertical 230v model #ra5e6va serial #dc90177-0025 i am wanting to know what cylinder head torqe is for the compressor.the head gasket leaks oil and...
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Oct 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Air Tools & Compressors Logo
242 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Eddie Tucker
Level 1 Expert
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
