Question about Canon Pixma MP480 All-In-One InkJet Printer
Mr printer won't turn on. It is plugged in and hooked in to my computer. It has been working before today.
    Guru:
  • 89 Answers
Check power cable
Try connecting it to directwal outlet not power strip
check the power cables if it has power adapter with green ligh on it if it has then check the power cord connected directly on wall outlet try to use it in some devices compatible to it
lastly take advantage to you canon support if you printer is covered with warranty they can find better solutions even replacement too!
Hope I gave you even a bit of idea.
Thanks
Posted on Mar 28, 2011
Printer is offline, will not connect
Hook up USB cord to computer and reset it.
Apr 13, 2014 | Dell 1160w Mono Laser Printer
Hook up to home pc
Today's laptops and desktop computers are more user-friendly. As more people start use computers, operating systems, software and hardware accessories are coming with better instruction manuals and streamlined interfaces. Here are a few basic steps to hook up your computer no matter which brand you bought.
Connect the power cable to the back of the computer tower. The male end of this plug is often on the computer, but it is recessed into the casing. Once this power plug is connected, you don't want to plug it into an outlet until the entire computer is set up. Attach the monitor cables to the back of the monitor and then to the back of the computer tower. This cable will probably be the VGA type, which has a wide set of prongs in the middle and two screws on the outside. Be sure to twist the screws in to ensure the cable has a solid connection. Secure the monitor's power cable to the back of the monitor and then plug it into an outlet or power strip. Attach the mouse to the USB port on the back of your keyboard. The keyboard then plugs into another USB port on the back of the computer tower. Turn on the computer and the monitor.
If the computer powers up but the monitor doesn't display anything, make sure the VGA monitor cable is secured. If the status light on your monitor doesn't turn on, check the power cable connection. Check that the mouse and keyboard work once the computer turns on. Now you can hook up other devices, such as a printer or a web cam. A printer often can connect to a USB port and also may have its own power cable; a web cam usually just plugs into a USB or firewire port.
b>
Jan 21, 2013 | Acer Aspire 5535-5050 Notebook
My 3250 printer has a blank screen and my computer cannot detect my printer
it would help if you post what operating system you are running,
With some printers, you have to start installing the driver / software before you plug the printer in. happened to me one time where i plugged the printer in first and it wouldn't work properly. after reading the instructions (because i can be a mr. know it all sometimes),and running the software BEFORE plugging the printer in, it worked. Hope that helps, good luck
May 31, 2012 | Kodak Esp 3250 Allinone Multifunction ( ...
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Was trying to hook up hp printer. when i plugged
HP Printer driver problem. Disconnect Printer and see if the computer boots up properly now.
Mar 09, 2010 | HP Compaq Presario 6320US (DA202A#ABA) PC...
Won't turn on
If you do not have a volt meter, there are some things to try. The first couple of things sound silly at first, but we have to check it.
1. Plug something else in the outlet you use for your printer...verify the outlet has power. You probably use a surge protector (power strip) and we need to verify it has power.
2. Remove the power cord from the printer (if it is the type you can take out) and swap it with the power cord for the computer. A cord we know works! The cord may be loose where it connects to the printer...and snug in the wall.
3. If this fails to get the printer going, we'll need to take a look inside and make sure no fuse or overload switch is tripped or blown.
Good Luck!
Apr 07, 2009 | HP Photosmart 8250 InkJet Printer
Cord needed to work with our new Dell computer
i have a g85xi my self and you will need to use a cable to connect from the g85 to your usb port on the dell i have a hp wich is basicly the same one end of the cable be square and the other end is a usb end
Jun 01, 2008 | HP G85xi All-Color InkJet Printer
Canon Pixma MP480 All-In-One InkJet Printer Logo
117 people viewed this question
old marine
old marine
