Question about Kenwood Car Audio & Video
Each time i turn the ignition off the cd receiver loses all the pre set channels and you have to re enter the stations each time
  • Jeffrey Turcotte
    Jeffrey Turcotte Mar 28, 2011
    Hi, the yellow wire of the head unit must be connected to a hot wire to maintain the presets when the key is off. there should be a hot wire in your car. go to modifiedlife.com and look up your car to see which wire color is the hot lead.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
It sounds like you need to make sure the yellow wire is going to a constant power source. That is a source that is still hot with the key off.
Posted on Mar 28, 2011
IDC 248u. Why does it lose station memory?
Review the installation instructions. Connections may have been reversed.
Nov 06, 2015 | Kenwood Car Audio & Video
Hi, my problem is that each time I turn off the ignition I lose all my radio settings (i.e. the station pre-sets). My Sony is a CDX-L400X. I was wondering if there is an internal battery (like a button...
Hi, the problem is likely in the wiring or possibly a burned fuse. There is a separate wire to the radio that is always hot and keeps the station and clock settings while the key is off. If you tell me the car model and year, I may be able to tell you which wire and fuse to check. Was this working originally or has it never worked?
Aug 19, 2011 | Sony CDX-L400X CD Player
I have bought a JVC-R322 CD Receiver for my daughters Renault Clio and it connected to the existing cabling with no problems. However everytime I turn off the ignition and turn it back on again, the unit...
The vehicle has a constant power source that needs to be connected to the radio. If a fuse has disconected the circuit then you will lose your "memory" for your radio. Look in the owners manual for the fuse box locations. Use a light to find the fuse that has disconnected the circuit.
Jul 26, 2011 | JVC Car Audio & Video
Hi i have just wired it into the car, but everytime i switch the ignition off i lose the pre set radio stations. any help?
one wire is power on is acc which is memory cant have both hooked up to one power wire it has to be one on power thats on all the time and one on a wire that only has power when ignition is on if this is what you have already done then switch the two wires that will solve your problem
Jul 10, 2011 | Alpine CDA-9847 CD Player
Do not have manual. Need to program tuner channels and clock.
For clock turn key on and stereo off. Press and hold the function button for 3-5 seconds. the clock should appear with the hours flashing. Use the up-down buttons to set hours. Push the right button to set the minutes. Now turn on the stereo with the source (or power) button and your done!
Remember key on stereo off. hold function, the rest will become second nature once you've done it a few times.
Tuner pre-sets are super easy. Tune to the station you want and then just hold the # button (1-6) that you want that station on for about 3 seconds. The channel your on, (e.i 104.9) will flash a couple of times and then stop flashing. When it stops flashing it's in the memory. Tune your next channel and hold # 2,3,4,5,6, If 6 isn't enough push BAND and your on FM-2 with 6 more pre-sets, Push it again for FM-3 with 6 more presets. Push it a 3rd time for the AM band with 6 pre-sets and one more time to get back to FM-1.
Apr 07, 2010 | Pioneer DEH-P3100 CD Player
Does not stay set.
your deck has two power sources a main for when your car is turned on so the radio kicks on and a remote which is always on keeping stations and clock powered passively so whoever installed it did it improperly or do to road wear and tear it was jossled lose and can simply tightened after pulling the deck out
Mar 29, 2010 | Sony MEX-BT2500 CD Player
Wont save pre-set stations
you need to make sure the red wire is connected to the battery via a fuse(normally inline or in the back of the unit) and the yellow is connected to ignition live(ignition needs to be on to give power). if the red wire is not permanantly live then the pre-program function will be reset every time you turn the ignition off.
Oct 06, 2009 | JVC KD-S6060 CD Player
Preset channels on Panasonic car radio out of tune
this is simple enough to do, just find the channel you want to save, then press and hold a number u want to save it to!
i.e No. 1 - 96.9Fm
hope this helps
Feb 15, 2009 | Panasonic Car radio CD CQ-C1110GN CD...
How to program pre-sets on a Sony tuner ST-S100L
Tune in the correct station with the big +/- buttons. Then press "memory" then type in a number with the pad (it will do double digits, but normally a single digit is preferable) then press "enter"
Now typing in that number then pressing enter will take you to that station.
Good luck.
Dec 12, 2008 | Sony ST-SA50ES 2 Channels Tuner
Pioneer DEH-1700R - Storing Radio Stations permanently
your constant power wire is not hooked up or it has come loose that is why nothing will stay saved on the unit have it looked at and see if they wont fix your problem cheap...... its a easy fix
Sep 16, 2008 | Pioneer DEH-1700 CD Player
Car Audio & Video Logo
18 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
