Question about Panasonic ES8167A Arc Shaver Electric Shaver
What do you use in the cleaning fluid resevoir?
  • Panasonic Master
  • 1,625 Answers
All Panasonic cleaning stations use the same cleaning solution cartridge. You will find these at shaveroutlet.com. See link below
http://shaveroutlet.com/catalogsearch/result/?q=035p+cartridge
Posted on Mar 30, 2011
Washer fluid wont work
Start with basics. check if resevoir is empty. most likely a frozen nozle. Maybe a frozen, blocked or kinked/broken hose. If you are in cold area, warm up car in garage add washer fluid with low freeze temperture. If not froze; look up diagrams online and check hose, filter screen in resevoir, and tip of nozle.
Dec 13, 2013 | 2003 Mercury Mountaineer
Window washer
this tells me the jets are blocking get a needle and clean the hole in the jets
Sep 02, 2012 | 2007 Pontiac G6 GT Convertible
Whinning when you turn the wheel. filled the power steering fluid seems to be leaking
Check your hoses first - if cracking replace
Next check your resevoir is the leak coming from where the hose connects to or is the leak coming from the resevoir/pump. If the hoses are good you will need to replace the pump/resevoir. The wineing noise indicates low fluid. Too much fluid would cause foam at the resevoir
Aug 27, 2011 | 1994 Oldsmobile Cutlass Ciera
How do I change break fluid in an 05 Kawasaki 300klx?
the easiest way i find is to drain the resevoir, refil and drain with a vaccuum bleeder until clean fluid comes through the bleeder (topping up the resevoir as you do so)
this works for front or rear brakes.
hope this helps
Apr 01, 2011 | kawasaki KLX 300 Motorcycles
Ford F-250 Clutch Fluid resevoir location?
There will be a little black resevoir to the right of the brake master cylinder. Its mounted to the firewall. When filling or topping off the fluid, make sure you remove the black rubber boot after the cap is removed. The resevoir itself will only hold a little fluid. Hope this helps you. Please leave response if you could. :)
Mar 04, 2010 | 1992 Ford F250
Brake light on dash
You could either be low on the brake fluid or the pads have worn out..you've got to check em both.
May 12, 2009 | 1995 Nissan Altima
Power steering
NO, DOT 4 fluid is brake fluid, not power steering fluid. The power steering fluid resevoir is black with a green cap.
Apr 20, 2009 | 2003 Audi TT
Peplaced power steering pump and it still makes
Check that the filter at the bottom of the reservoir isn't blocked and restricting fluid to the power steering pump.
Mar 03, 2009 | 1992 Honda Accord
Transmission fluid in antifreeze resevoir?
The heat exchanger in the rad header on the bottom is shot. You need a new rad, flush the coolant, change the tranny oil and filter, clean out the resevoir.
Jul 29, 2008 | 2002 Dodge Neon
Panasonic ES8167A Arc Shaver Electric Shaver Logo
151 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
gautam jha
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
