Question about DeLonghi Heating & Cooling
I have a Delonghi Radiator Heater type 5307. I removed the screw and the panel comes off. I squeezed the 5 tabs and the black plate comes off revealing the two red switches. The red switches control the 600 and 900 watt options. The 600 watt one works. The 900 watt one is loose. Can I easily fix or replace this? How do I remove it? Thanks.
  • 33 Answers
SOURCE: DeLonghi 5108 Oil Filled Radiator no longer works?
The DeLonghi 5108 has no thermal fuse. There was a problem with the control panels and DeLonghi was to offer free repair. Details on http://www.cpsc.gov/cpscpub/prerel/prhtml91/91108.html
which includes a toll free number.
Posted on Jan 11, 2008
  • 126 Answers
SOURCE: Bissell 7950 ProHeat Self Propelled Carpet cleaner Replacement Pump Belt part 215-0628
Normally, there is a post sticking out of the retainer to remove it. If the post is broken off, then you will have to lift the black arm and wiggle it at the same time and the retainer will pop up so you can remove it. On the belt side, the retainer is fairly large and you can usually get a hold of it with a pair of needle nose pliers. On the other side, the retainer is small and you can lift it out with the pliers by griping it gently using the hole that the screw goes through.
Posted on Jan 27, 2008
  • 45 Answers
SOURCE: Delonghi DR18T Timer Replacement
before you replace the timer, check and see if the timer has a battery in it. if it has, then change the battery. it will work fine.
SOURCE: caution light comes on,rarely used heater. any thoughts?
Try calling 1-866-876-4332 ext 224 for tech help, it worked for me.  I only needed a temp
setting/off switch to fix mine.
Posted on Oct 23, 2008
Toyota Corrolla 1995. The heater does not work, I replaced the thermostat and have put a lot of antifreeze.
bleed cooling system, probably there is air trapped in the heater core preventing warm coolant to circulate into the heater core. try this
1 open radiator cap fill coolant and put heater in hi heat
2 start engine and wait until you see the coolant start to circulate
3 squeeze hose several times watching if coolant volume decrease
4 add more coolant and repeat 3 until coolant volume stays same or start overflowing.
5 check if heater giving off warm air or repeat 3 and 4 until warm air blows on heater.
or find the coolant bleeder screw, do 1 and 2
open bleeder screw until coolant come out, do this several times until no air comes out when opening bleeder screw, fill coolant in radiator.
Dec 11, 2013 | Cars & Trucks
Delonghi trdo715t worked last year now will not turn on
Check to see if the timer is running. If not, remove the three silver screws on the bottom of the heater, then lift off the front panel and look for burned or loose wires. On mine the A/C line burned off at the timer. Timers are available thru Fox International for $11.66
Nov 24, 2012 | DeLonghi TRD0715T Oil Filled Radiator...
Need diagram for replacing heater core
    Detach the heater core hoses at the firewall. The two black hoses attach near the firewall on the passenger's side of the engine compartment. Squeeze the hose clamps on the end of the hoses with pliers and slide the hoses from the heater core tubes.
    • 4Remove the lower passenger's-side and driver's-side dashboard panels. The two panels are held in with push-pins. Raise the center of the push-pins with a small, standard screwdriver and pull the pins from the panels. Pull the panels away from the dashboard to separate them from the dashboard.
    • 5Remove the center console. Separate the gear select trim piece from the center console, using a small standard screwdriver to pry the trim piece from the center console. Lift it over the shift knob and rotate it to clear the knob. Remove the retaining screws holding the center console in place with a Phillips screwdriver. Lift the console up over the shift knob and remove it from the interior.
    • 6Remove the glove box. Open the door to the glove box. Squeeze the two retaining tabs on the ends of the glove box and pull the glove box away from the dashboard. Remove it from the interior.
    • 7Detach the drain tube from the heater core cover, which is located behind the glove box. The tube can be pulled from the heater core cover by hand. Detach the air intake duct from the bottom of the heater core cover. The air intake duct runs from the bottom of the cover to the center of the dashboard. Remove the duct by hand.
    • 8Remove the retaining screws on the black heater core cover with a Phillips screwdriver. Pull the cover from the heater core and remove it from the interior. Remove the heater core clamp screw with a Phillips screwdriver, pull the clamp away from the heater core, then pull the heater core from the housing.
    • 9Place the replacement heater core against the housing. Place the clamp over the heater core and install the clamp retaining screw with a Phillips screwdriver. Position the heater core cover over the heater core and install the retaining screws with a Phillips screwdriver.
    • 10Attach the drain tube and the air intake duct to the heater core cover.
    • 11Install the glove box. Squeeze the retaining tabs on the sides of the glove box and push it into position against the dashboard. Release the tabs when the glove box is in position.
    • 12Install the center console. Guide the console over the shift knob and install the retaining screws with a Phillips screwdriver. Slip the shift selector trim piece over the shift knob and push it into the center console.
    • 13Place the lower passenger's-side and driver's-side dashboard panel in position. Install the push-pins into the retaining holes, pushing the in center of the pin to engage the pins.
    • 14Fill the radiator with coolant. Most climates require a 50/50 mix of DEXCOOL coolant and water. 2.2L engines require 8.6 qts., 2.4L
Nov 22, 2012 | 2000 Oldsmobile Alero
How do I remove the cover of a delonghi ec270
Prise the back cover off with a flat head screw driver. Sides first, then ease top and bottom off. Remove two push in caps by gently squeezing out with a plier, align the groove to the same direction as plier. Locate two screws holding cover, unscrew, and off it comes.
Aug 25, 2012 | DeLonghi EC270 Espresso Espresso Machine
I need an advice on how to replace the heater coil on my 1990 honda accord
( heater core) disconnect the cable from negative battery terminal, from engine compartment disconnect the temperature control cable from the temperature blend door and the mounting bracket from the top of the heater case. Disconnect wires from blower motor resistor and the blower motor. Drain the coolant from the radiator into some type of container. Disconnect the heater hoses from the heater core tubes on the engine side of the firewall. Now working in the passenger compartment, remove the nuts retaining the left end of the heater case and the right end of the plenum to the dash panel. Working in the engine compartment, remove the screw retaining the top center of the heater case to the dash panel. Remove the screws retaining the right end of the heater case to the dash panel and remove the heater case assembly from the car. Remove the screws, nuts and bolts retaining the heater housing plate to the heater case, then remove the heater housing plate. If so equipped, remove the screws attaching the heater core frame to the heater case and remove the frame. Remove the heater core and seal from the heater case.
Dec 25, 2011 | Cars & Trucks
It stopped working
If its like the TRN0812T, I had to reset the small circuit breaker under the control panel/cover, had to remove the 2 torx screws under the leg on the control panel side.
Feb 02, 2011 | DeLonghi TRN1015T Solaris Oil-Filled...
How do I remove the driver side door panel to replace window motor
1. Remove 2 small screws at bottom of the door panel (6mm)
2. Remove small black cover from inset for door handle (pry it out carefully with a small flat head screw driver or panel removal tool) and remove bolt behind it (8mm)
3. Pop window/door lock control panel out with the same flat head screw driver and disconnect all connectors. Remove small screw from behind it (6mm)
4. Lift straight up on door panel and then tilt toward you.
5. Disconnect mirror control connector.
6. Squeeze two tabs on the door latch assembly and it can be removed along with the cable. DONE.
Jul 02, 2010 | 1999 Ford F150 Regular Cab
How do I replace a delonghi typ 3107 dual rocker
Remove one phillips head screw that is located approximately 4 inches above the switch you are about to replace. The complete face of the heater can now be removed, then compress the four tabs on the back side of the switch to remove the switch through the cover.
Dec 02, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Heating & Cooling Logo
110 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
