Question about Samsung HCN5527W 55" Rear Projection Television
I have a hcn5527w rear projection tv i hafd a bad bowing effect and all colors were off set after reading what many of theexperts said it sounded like a convergiance problem so i order a board not just the chips and replaced most of the bowing went away but some is still there and the colors wont merge on th left of the screen when your looking at the manual adjust screen the reds + are off set left and on the right they are offset right i adjusted the center to perfect i checked my manual focus and got it as close as i can and still can only get 4% on auto tune any suggestions??
  • 11 more comments
  • steveistaken Mar 28, 2011
    i used the focus at back of lenes and the elect focus at front of lens under front cover...then i found another set of adjustments that helped focus a lot below the one on the actual leans assemblies under front panel i tried the manual adjust of the corss hairs with the remote so far thats it
    ohh and i did the auto fine adjust but it only gets to 4%
    i can try if i take a pic with my phone can i send that to you ? i know the phone can but i have never sent to email before
    ok i got a pic will try ans send
    ok sent hope it came through ok
    umm ok so it is the board still?
    ok my soldering skills **** so id rather just replace the board...why i bought that one from samsung in first place unless you want to come do that work for me...lol
    thank you very much i will try and get this replaced you have been a LOT of help
    he was very helpful i would work with him anytime
    actually i found out my son got the part from someplace called partstore i havce orderd a new one thank you very much for all the help
  • steveistaken Mar 29, 2011
    ordered it yesterday and they should have it by end of week
    so once i install it i make sure my focus is crisp manually adjust then do the auto fine tune
  • steveistaken Mar 30, 2011
    sounds good to me
  • 4,889 Answers
Did you try aligning the crosshairs of red blue and green in convergence adjustment? Also what adjustment did you perform? Auto-adjust or 9-point adjustment?
Posted on Mar 28, 2011
  • 7 more comments
  • eagle338
    eagle338 Mar 28, 2011
    Then you have everything that you should have. Can you get me a picture so that I can see the extent of the problem and tell you if it can be anything else?
  • eagle338
    Auto fine adjustment failure. Aha, did you purchase the board new or used? I have a gut feeling that the convergence amplifier ICs on the the replacement board are faulty as well.
  • eagle338
    Yes you can send the pic to goodwise24@gmail.com
  • eagle338
    Woah! THat is terrible. They are not even close to aligning themselves. If I were you I would return the board and just replace the convergence amp ICs and resistors on the older board. I can confirm that they have sent you a faulty replacement
  • eagle338
    Yes it is. I can assure you that. The fact that fine convergence adjustment is not completing confirms this
  • eagle338
    So you got that from Samsung? Thats very bad.on their part. One of the reasons I steer clear of Samsung if I can as I have done while purchasing my LED tv. I have sacrificed better picture quality by buying LG instead of Samsung coz LG tvs have never let me down
  • eagle338
    Ok. Partstore usually sells used parts. Next time you want to buy parts tryhttp://www.samsungparts.com/Default.aspx
    They sell original samsung parts that are brand spanking new. Even though they cost a bit more they will last longer and are covered by a warranty of 1 year
  • eagle338
    eagle338 Mar 29, 2011
    Cool. You will need to perform auto-convergence adjustment after installing the board. So once it arrives install it, perform the adjustment and let me know how it goes
  • eagle338
    Do not use adjust the focus just yet. Be sure to perform the converegence adjustment first. I will give you precise instructions for adjusting the focus block depending on how the convergence adjustment turns out
Tv is yellow orange color what is problem
The model indicated does not have a "bulb" as it uses 3 picture tubes.
Examine the picture with color set at zero---stand back and look= if the screen has a mostly yellow (all or part of the screen) you have bad Glycol in the blue picture tube(if need explanation ask) and a look in the lens of the Blue tube will confirm this.
If able with back off and a small mirror look in each lens--red picture, green picture and blue picture.
If the Blue looks like a floodlight with little or no image--bad glycol in that tube.
Jun 16, 2012 | Samsung HCN5527W 55" Rear Projection...
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Samsung HCN5527W
In what way is the color off? Does it appear like a 3D movie? If so, the convergence circuit has a problem. This could be as simple as a bad solder joint on the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Figure on $40-$60 for parts plus the local labor rate if you need a service center, just the parts cost if you fix it yourself.
Update this if you need further repair details.
Dan
Jun 09, 2008 | Samsung HCN5527W 55" Rear Projection...
Bowed picture and color misalignment
Replace both STKS ICs Ck low ohm resistors 2.7ohms most of the time there will be 2 of them bad.
Jun 11, 2009 | Samsung HCN5527W 55" Rear Projection...
Hitachi projection hdtv has 3d effect and bowed shape
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 15, 2009 | Hitachi 53SWX01W 53" Rear Projection...
BOWED PICTURE AND COLOR CONVERGENCE
You can replace the whole convergance board assy Part #239126 or 239126R and it should take care of problem.
Dec 18, 2008 | RCA P50830BL 50" Rear Projection...
RED
sounds like you have a shorted red crt or a bad drive transistor in the red circuit
Apr 12, 2008 | Samsung HCN5527W 55" Rear Projection...
Help tv is showing double text at bottom and bowing colors
Convergence ICs are bad and need to b replaced there are two of them theyost about 10.00 each.
Jan 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
I need help!
Michael,
the problem you are having is caused by bad convergance amplifiers along with open pico fuses internal to the set. these amps range from $45.00 to $65.00 each and both amps need to be replaced. this is a common problem with rear projection sets. these amps work very hard and are kept cool on large heat sinks. so with that a tech is needed to repair. techs may charge $150.00 to $350.00 for the labor. so shop around. as for the adjustments you made let the tech know because you may have set the settings far out of the range for the set and will cause shut down before it can be reset. the tech will know what to do. to find a factory athorized repair shop call samsung the number is in your manual or on line.
Bob Johnson
Dec 31, 2007 | Samsung HCN5527W 55" Rear Projection...
Samsung projection tv
Elissa, unless you have some basic electronics experience probably not, what your describing is one of the most common projection tv problems there is, but it will require replacing a few components on a circuit board. You will need to solder and possibly check resistance values of a few resistors. I will say there is no need for a samsung servicer, any tv repair place will know how to repair this problem. Probably will cost around 300 if you have somebody to your home. I don't think your looking for the Technical details but if so replace the 2 large STK amplifiers probably (STK392-040) and test all resistors and fuses in input/output ckts, replace accordingly.
Apr 25, 2007 | Samsung HCN5527W 55" Rear Projection...
Samsung HCN5527W 55" Rear Projection Television Logo
119 people viewed this question
Jerry Greenberg
Jerry Greenberg
