Question about Radio Communications
My uho65sx radios r stuck on busy,how do we stop it.
I had my first one repaired and now my second one has failed. Very disappointed. The second unit has been the glove box radio and does not even have a scratch on it!
Choice-
Spend more than what it\'s worth to have it happen again?
Buy another who cares made in China brand
( remember this is also
Made in China now!)
No contest I feel as I have an older pair of " dick smith " made in China hand heads that have had good hard use and still are fine , not even the ink worn off the buttons.
Compared with the uniden with little use and no ink on some buttons.
No contest I think
Posted on Jun 18, 2014
  • 391 Answers
Ajust the squelch
Posted on Mar 30, 2011
Uniden uho65sx Stuck on busy,and when press any key doesn`t emit noise.How to fix?
Turn your coded squelch off and adjust your manual squelch adjustment so that BUSY is not shown.
May 29, 2014 | Radio Communications
How do reset a uniden uho65sx
Manual is availabe from here: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/uh065SX_2_OM.pdf
May 26, 2014 | Radio Communications
CP185 has intermittent static, when pressing button to talk screen displays "channel busy" and battery will not keep a charge.
Could be one of several issues. A few which come to mind are:
1) You have a bad or poorly charged battery. Static is a sign of a bad or poorly charged battery. Try swapping a battery from another radio, with a known good battery and see if the problem is solve. If this resolves the issue check your battery and charger. Tip: Clean all charge contacts with a pencil eraser to ensure good charging. Also, check your 3- or 4-digit date code on the battery. If more than 2 years old, replace the battery. (4-digit date code example 1303 would be 2013 the 3rd week; on 3-digit date codes the first number is the year and the next two the week of the year.)
2) You are trying to use the radio in an area where you are experiences high RF on your frequency. This is the "busy"... someone/something is on or near your radio's frequency and interfering with transmission. Try your radio at a different location and see if the problem persists.
3) Another radio in the workgroup is stuck in transmit, causing static, and the channel busy. Turn off other radios, one at a time, and see if the problem still exists.
4) Or if you have an audio device plugged into the radio, try unplugging it and see if the problem stops. FYI: All audio devices must be plugged or unplugged with the radio shut off. If you plug one in with the radio turned on, you can experience some unexpected intermittent issues.
If none of these seem to be the problem, your radio is likely in need of repair.
Best regards.
Jan 17, 2013 | Motorola CP185 (16 Channels) Two Way Radio
Uniden uho65sx manual
Hi Anthony,
Very simple answer: join yahoo group specific to your radio Make/Model, they have the answers you need, plus you can download manuals and schematics for free.
I hope you find this helpful.
Regards,
Peter
Dec 14, 2011 | Uniden Radio Communications
Uho65sx stuck on busy,how do i get it off.
make sure he Mic is plugged in correctly andd taghat the Mic was wired for a 4 pin cobra Style nd not midland.
Mar 28, 2011 | Uniden Radio Communications
Citroen/Blaupunkt radio unlocked but won't stop beeping
VIN coded radio.
Radio will require coding to your car`s management+security system.
Contact your Citroen Dealer or Radio Decoding Business
May 29, 2010 | Car Audio & Video
What is busy indication on uniden uho65sx-2. The radio appears not to recieve, cant get rid of busy indication.
the uniden was returned to Aucklands "wonderful" service team and it was found the ceramic coil inside had been damaged, after i dropped it I would say!
Nov 17, 2009 | Uniden Radio Communications
Uh049sx." BUSY" light on all the time. wont recieve
Contact a service center in your own country.
turn the squelch button down.
Oct 19, 2008 | Radio Communications
Radio Communications Logo
231 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
