Question about Sylvania SYL-WH930GB Wireless Headphones
Syl-wh930 product when i switch to tv green button i pick up fm radio statio. I have replaced batteries, reconnected cable from transmitter on back to tv. and placed headphone to the h position. i then pressed the reset button and scan button. Did not resolve problem. Only had one day. Worked yesterday but not today. Did nothing to unit during that time frame.
  • k a nein Nov 14, 2012
    I have exactly the same problem, except threy never worked at all.
Is there a way to use my WH-930 headphones to watch a DVD?thank you
Posted on Oct 23, 2011
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory ┬╗ FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Jan 17, 2016 | Audio Players & Recorders
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
My fm transmitter is locked and not allowing me to listen to iPod audio books and music on the radio. I plug it into the iphone and it displays 188.8 but is locked on that.
First, 188.8 is not a valid FM frequency. Those digits represent the illumination of every segment of the display; and to me, indicates a processor fault. The fact that other buttons are unresponsive only bolsters my suspicions.
Remove power from the radio - not merely powering off - but remove power from the power leads. You can do this by pulling the fuse for the radio or disconnecting it. Do not remove the battery cable from the battery as some vehicle factory radios will go into anti-theft mode and no longer operate.
Allow the radio to remain unpowered for a several minutes and then reconnect. Try the radio again. If it still does not work, please provide the make and model radio you have.
Oct 19, 2015 | Audio Players & Recorders
Soundlogic XT 5 in 1 wireless headphones will not receive audio from tv; only gets radio stations.
Did you connect the base/transmitter piece to the AUDIO OUT jacks on the back of the TV ? The radio you are listening to is the built-in FM radio/tuner. You need to connect the transmitter to an audio source (TV, PC, CD/DVD player, etc.) to receive sound from that source.
Jan 04, 2015 | Audio Players & Recorders
All i get is radio stations but cant get no tv
HELLO I ALSO HAVE HD238 AND I FIGURED WHY THE ONE SPEAKER PLAYS THATS BECAUSE THE COMPANY WANTS TO MAKE IT EASY TO BREAK-DAMAGE-DESTROYED
IF YOU OPEN THE ONE SPEAKER YOU WILL SEE THAT THE CONNECTION BETWEEN THE TO POLES IS WITH A HAIR OF A CABLE AND BY THAT WITH THE SIMPLEST DROP OF THE HEADPHONES CAN CUT.
NOW I AM TRYING TO PUT NEW WIRE "HAIR" BUT IT IS VERY DIFFICULT BECAUSE I WILL PROBABLY MELT THE PLASTIC OR DESTROY THE SPEAKER AN OPTION I PROPOSE IS TO STICK THE WIRE HAIR WITH GLUE
Aug 24, 2013 | Sylvania Syl-wh930 Wireless Headphones
Connecting mp3 car radio
If you radio has an Aux input then you can connect a audio cable from your MP3 player to the Aux input on your radio.
If your radio does not have an Aux input the you can use a FM transmitter device. Connect the MP3 player to the FM transmitter and tune your FM radio to the radio frequency on this FM adapter to listen to your audio book on your MP3 player.
Check out these WEB sites fro FM transmitters.
http://dx.com/c/car-accessories-799/car-audio-systems-707/fm-transmitters-players-710
http://www.amazon.com/Coby-CA-745-Wireless-Transmitter-Cigarette/dp/B000OTF6G0
http://www.popularmechanics.com/technology/how-to/gadgets/4307160
Feb 05, 2013 | Audio Players & Recorders
I installed the FM transmitter module which came with my samsung LCD TV model LA40C530F 1R. I tried accessing the FM transmitter menu in order to turn the transmitter On and to set the frequency but that...
1. Press the menu button(green)
2. down arrow once - (a picture of a speaker should appear with sound written vertically next to it)
3. Right arrow once (selects the sound menu)
4. Down arrow till you see FM transmitter (down arrow 4 times on my TV. If you don't see the FM transmitter option in the menu then upgrade your TV to the latest software (details at the end of this help file)
5. Right arrow to get into the FM transmitter menu
6. select the "FM transmitter: off" line and turn it on (FM transmitter : on)
7. Change the frequency to to one that is not used by a radio station or has interference noise (get a radio and tune it till you hear the choosh sound with no beeping or clicking from lightning - then set the tv fm transmitter to that frequency using the up and down arrow keys and enter.
8. You should here your tv sound comming through the radio even if the tv sound is off.
If you need to upgrade your tv software then:
1. format a usb stick
2. download firmware.exe from"
http://www.samsung.com/za/consumer/tv-audio-video/television/lcd-tv/LA32C530F1RXXA/index.idx?pagetype=prd_detail&tab=support
3. click on firmware
4. click on "Upgrade File(USB type)" and download it to your usb stick
5. when the download is complete double click on the file and extract it to the usb stick.
6. eject the usb stick.
7. plug it into your TV and slelect software upgrade when prompted - I didn't loose any settings even though it warns you that you will (samsung are just covering themselves)
Sep 03, 2010 | Televison & Video
Super Boss FM HI-FI Wireless Headphone SF878 no sound from the tv
Hi - the tv sound will be picked up like an fm radio signal at 83 mhz. To get there, press the reset button the side of the headphones, then press scan. the first signal to be picked up will be the tv signal. This assumes, of course that you have fresh batteries in the transmitter and headphones, and that the volume is turned up on the headphones and the TV. Worked for me. The signal is not stereo, though.
Dec 30, 2009 | Televison & Video
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Sylvania SYL-WH930GB Wireless Headphones Logo
1,296 people viewed this question
Top Sylvania Audio Players & Recorders Experts
David Payne
David Payne
R Buschy
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
