Question about Frigidaire FTF2140ES King Size Front-Load Energy Star Washer w/ Tumble Action
My washer drains water, but when it is supposed to spin it makes a terrible noise and is stuck until I turn it off. I have to manually turn the knob to off to be able to open the door. It is a Frigidaire tumble action washer purchased March 2002.
    Sergeant:
    Champion:
  • 202 Answers
Hi...You have a bad door lock ..I'm a tech of 10 years seen it lots of times
Posted on Mar 28, 2011
I have a kenmore 700 series top-loader washing machine. Its about 8 years old but looks pretty new. My knob turns fine but the housing enclosure for the number does not turn with the knob. I have to...
The burnt plastic smell is probably the belt that drives the agitator. There may be something stuck (wrapped) around the shaft under the agitator that tightens the gears so the belt just slips and heats up. Remove the agitator and make sure the shaft is clear. also if it is belt and gear driven, check the gears. This means removing a panel or turning the unit sideways to inspect from below. The hum is the motor either not turning or turning with the belt too tight.
Hope this helps...
Oct 31, 2013 | Kenmore 24032\24036 Top Load Washer
My Estate TAWS800JQ washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin. If knob is manually moved from drain cycle to rinse unit will agitate but not drain or...
Possible that the drain pipe is in a height where the water is struggling to lift.
If not id check for a block. I normally find a sock stuck in the drain hose which causes a problem similar to yours
Sep 24, 2017 | Estate TAWS800JQ Top Load Washer
Washer makes very loud humming noise in spin cycle but does not spin..I removed clothes thinking it was very heavy and it did spin out but when I put clothes back it returned w/no spin and loud noise..now...
Either the control board or the motor has gone bad. Here is the diagnostic mode to run to look for the errors.
The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. • Press Pause/Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Repost the error codes here.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
My GE WCSR2090D top load washer has flooded our house in the past, and when looked at by a repair man he said nothing seemed wrong... so we continued to use it and it now leaks/floods only once in every...
You might have a partially clogged drain past your drain hose
(In the wall etc)
Thats overflowing behind the washer.
Watch the drain for a few washings and see if it overflows
It may be second or third or fifth load. Its hard to catch
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 08, 2010 | General Electric WCSR2090D Top Load Washer
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Open Questions:
See all Frigidaire FTF2140ES King Size Front-Load Energy Questions
Washing Machines Logo
176 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
