Question about Frigidaire Refrigerators
Frigidaire Model PLHS69EESS control part 5303918340 seems to have failed. The fridge runs constantly and has frozen food in the cool side as well. Is the control part a difficult part to replace? Should I contact a service center for repairs?
SOURCE: looking for a frs22zrf service
Hi there!
You should be able to identify various parts Here
It sounds like a problem with defrost timer control, but may also be the control board for the thermostats.
Just click the link , put in Electrolux, fridges, then electronic parts in the box at the bottom.
(shop around before you buy, and try removing/ testing items before purchase)
Posted on Jun 28, 2008
rpbuice
  • 161 Answers
SOURCE: Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Posted on Dec 22, 2008
  • 111 Answers
SOURCE: /gss22wgpjbb Ge side by side fridge Keeps freezing
automatic defrost its not coming on check the heather or hi limit
Posted on Jun 17, 2009
joecoolvette
  • 5660 Answers
SOURCE: Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
Posted on Jul 05, 2009
Sea Breeze
  • 4655 Answers
SOURCE: refrigerator not cooling
You model if the ARB1950C has a defrost timer inside the fresh food compartment and behind the temperature control panel. Need to see if you can manualy turn the timer clockwise until the compressor stops. During that time of 25 minutes the freezer should be in defrost. I believe your timer needs replaced based on how you explained what is happening. The part number for your timer is 67001036 and can be found at the links below. If it stays longer that 25 minutes then it's sticking in the defrost section of the defrost timer and will need to be replaced. If your refrigerator does not restart after about 25 minutes then slowly turn the timer through the opening in the plastic cover. There may be a plug covering the hole to make the hole not so visible. If you should have problems fell free to let me know, Thanks Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Posted on Aug 17, 2009
Frigidaire model #plrs267zab8 food in the freezer seems to be defrosting and appliance seems to be constantly running
check seal on freezer door for cracks or splits-replace if needed-check to see if water is going to pan at the bottom of fridge-hose may be plugged-clear blockage-is there water in fridge? remove goods from freezer-remove cover at back-may be frozen on element-defrost-if none of this works it can get more complicated and costly-may need a pro-if old replace.
Jan 28, 2017 | Frigidaire Refrigerators
Fridge is freezing food fan seems to be running all the time
sounds like you may have a stuck freezer control.try bumping that knob with the back of your fist,if it stops,that is it.if not it still may be the problem.let cool down in freezer for 10 min. open freezer door and turn knob back to off very slow,if it kicks off just at off ,control most likley bad.
Apr 16, 2014 | Frigidaire Refrigerators
Lg lbc22518ww bottom freezer not keeping food frozen
door seals may be bad. check for cold air leaking especially on the corners and the hinge side.
Feb 28, 2014 | LG LBC22518 Bottom Freezer Refrigerator
Our 2004 GE gsl251grb bs refrigerator is freezing food.
1st try cleaning the condenser core cooling fins
Aug 23, 2017 | GE Refrigerators
The fridge and freezer stopped cooling. we defrosted it. There was frost in the freezer. Before that the ice on the door had stopped and now it works too.
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me,the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signaled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week).Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bought a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Fan runs constantly and does not keep temp cool enough
forst on the back wall means you have a defrost problem or a air leak aroudh the door gasket-mike
Mar 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
May 22, 2008 | Frigidaire Refrigerators
Kitchen Aid Fridge
no ice in freezer section??? not able to keep meat frozen , is it making ice??? sounds like a compressor issuew and not covered by manufacture warr is generally not a worthwhile repair
Mar 02, 2008 | Frigidaire FRT21HS6D Top Freezer...
Refrigerators Logo
143 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
