I have a laptop and it has errors and has gone to NOT BOOTING UP, the error pages rushes past so quickly I cannot see what it says let alone read it. I have glimpsed that there are errors but cannot see how to repair the errors, also I dont have the discs, think currys sold me a second-hand machine and the discs and manuels were not in the box, Windows Vista Basic is missing - v2gqb 8m4wk j89j2 q2h6h f6fdm The laptop is: SNID 84600928749 - PN/PB99Q10801 - SN/11924420035 - Model Herco
  • 31 Answers
Sounds like there is a hardware issue that is not passing in POST infortunately to find out what it is a TECH will need to look at it nd hook it up to a USB diagnostic device to see what it is.
Posted on Mar 28, 2011
Dell xp will not boot and has lines across the screen
I would say your Graphics Adapter is gone. Have you removed the HDD and tested it? Has it been Cleaned? Fan? vents? Heatsink? Overheating? If the graphics adapter is gone it's a death sentence in a laptop. You can try replacing the Thermal Paste and cleaning the Laptop out. But it may be to late.
Apr 11, 2013 | Computers & Internet
I'm getting a screen that says "A disk read error
this problem caused by error connection at hard disk, your hard disk can not read by your computer
to fix this problem you need to open your laptop then disconnect your hard disk from laptop, and connect again
and turn on your laptop
the problem like this usually found at computer with sata hard disk connection
i hope this helpful
Apr 04, 2011 | Acer Computers & Internet
I get disk read error when I try to boot it up.
hi there, here are possible solutions to your issue
1. make sure first that your computer would be able to identify your harddrive. you can check this one by going to the setup utility page. upon pushing the power button quickly tap the F1 key or F2 key. then check your Harddrive if motherboard was able to detect it.
2. make sure that there is now usb flash drive or external drive attached to your usb ports when booting up your computer. sometimes if you have this devices attached to your usb this error happens when booting up.
3. Power on the computer and keep on tapping F8 key the moment you push the power button. select safe mode once oyu enter the black screen. if same error occured. then, ou need to use the recovery disk that came with the system and restore the computer back to original factory settings.
Apr 07, 2010 | IBM ThinkPad 600E 2645 Notebook
My pc wont boot up normally, it has a blue screen show up but then it goes away before i can read it
The blue screen of death BSOD is set to auto-restart after an error you can change the registry to prevent this not sure if you can do this in safe mode but its worth a try you will at least be able to see the error.
Its a good idea to use MemTest on a boot CD to check your RAM for errors first then restore from an old image.
Feb 07, 2010 | Acer Aspire One PC Notebook
NTDETECT Failed. Cannot get pasted this when booting system.
Hello
This error means that NTDETECT is missing or is corrupted somehow from your computer,hard disk problem,virus.etc
You can go to that page and follow the instructions exacty as he says and your problem will gone:)
http://www.tinyempire.com/notes/ntldrismissing.htm
Jan 13, 2010 | Dell Inspiron 6000 Notebook
Dell Inspiron 1521 Error Code 2000-0146
It means "DST Log contains previous error(s)."
Dell Support says “If the diagnostic test reports one of the above errors, refer to Dell Troubleshooting Wizard: "Hard Drive Fails the Diagnostics" Wizard ID: 324398”
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?journalid=79E54961218510CBE040AE0AB5E158B6&treeid=324398
Dec 05, 2009 | Dell Inspiron 1521 Notebook
Thinkpad wont get past boot page
Hold down the F1 key, and power on the computer to get into the "Easy Setup".
Change the boot sequence to boot from CD-ROM first, save your settings, then restart the computer and have your Widows CD (or original system restore CD) in the CD player so it will read the CD before the information on the harddrive. If that don't work, replace the harddrive
Nov 04, 2009 | IBM ThinkPad T30 2366 Notebook
Not booting. "disk read error occurred"
This means you HDD is either corrupt or faulty, try downloading a copy of Hirens BCD to try to access the HDD (or use and external HDD enclosure) and if you can, put it back in the laptop, if not reformat it and reinstall windows.
Aug 11, 2009 | Acer TravelMate 4200 Notebook
Bootup error
You have a dodgy memory module in the laptop.
By the sounds of it, and the fact you can get into Windows then you will probably have 2 memory modules installed and it is probably in the second one there is an error.
If there are 2 modules in there, remove the second one and try that, then if it still fails put that one back in and remove the first.
If there is only one module in the laptop, then move it from the slot it is in to the other slot. Besure to push it in properly. There is a notch on the memory modules so they will only go in one way.
Hope that helps =)
Apr 12, 2008 | Dell Latitude C640 Notebook
Lap top hp notebook series
One of 3 things have gone bad, either the hard drive and/or motherboard and/or the drive ribbon cable. First try removing the hard drive and reinstall the drive and try booting the laptop, if it still does the same thing, then it is time to send to the repair center. BPCS
Dec 02, 2007 | HP Pavilion dv1000 Notebook
Open Questions:
Can I hold DHHS accountable for the burden they put upon me? If not, is there someone that can be held accountable? What can I logically and honestly do to remedy this prob. I explained my prob below! I was getting QMB part of Mainecare and my spouse at the time we were dating but living together was getting the QI part of Mainecare. We are both disabled and only get SSDI. However being honest and do our best to always do the right thing we go to DHHS office on Griffin RD in Bangor, ME within a month of us getting married where the worker we saw tells us we don't qualify for anything but the min of FS and both Q1 part of Mainecare and serious voice tells us to divorce. I have made a few trips within last months to same DHHS. One sends us to Eastern Area of Aging to see if there were secondaries we can get. This past Monday hubby and I went to our appt with Eastern Area of Aging & was told they strongly believe I could get spousal exclusion also warning it could mean my hubby loses help but because it was a volunteer a newer one at that she couldn't tell me definitely cause she didn't know the formula as she still learning; tells us to go back to DHHS to ask about spousal exclusion. So I go back to DHHS this past Thurs and got a worker with more smarts, heart with approx 10 yrs working for DHHS tells me I qualify for spousal exclusion and took the time to answer all my questions. I told her I had QMB till hubby and I married June 2016 & shared with her what the DHHS worker told us when hubby and I went in to show marriage certificate to update the change. She looked at me with shocked eyes and dropped jaw in bewilderment. Then says I would of never lost it as I would of qualified for spousal exclusion from the day we married. And had it been her that we got when we were being honest wouldn't have only told me about spousal exclusion but would of applied me as she could see I have major medical problems that is too much a financial burden for my hubby and I. She also told me I was to submit all unpaid bills even if monthly making payments were being made. I thought I was only to submit bills I paid in full or on a payment plan. So started Thurs night on a Medical Bills Tracker to go through all the medical bills and sort things out. I haven't even put a dent in the pile and see I'm responsible for just over 6K I'm predicting once done I could be closer, if not over, 10K. In collections is currently 1K but once done with pile amount in collections could be closer to 2K or more. So the mess has impacted my credit and if things were done by professionals I wouldn't be losing my hair stressing over my medical bills and how it declines my credit. I know I'm in a small group that actually pay their medical bills any and all bills to be honest! I am disabled and get SSDI. Worked 1992-2013 a lot of times working 2 jobs! Dr in 2013 practically dragged me out of work as was just diagnosed with Hep C, CKD Stage 3 & liver disease! I also have depression disorder, panic attacks, anxiety disorder! So even this incompetent DHHS worker putting extra financial burden on me unnecessarily affects those things. I am trying to do the right thing but get kicked down by the very people that are paid to help me. What are my rights and can I fix this at a faster pace then not even fixed it by the day I die?
Jun 23, 2018 | Major Computers & Internet
Computers & Internet Logo
David Payne
David Payne
