Question about HP PAVILION ZD8000 SEREIS 100GB (4200 RPM)HARD DRIVE - 374730-001 100 GB
Hp zd 8000 boots in safe mode, but normally it gives me a blank screen. Hard drive error code #1-07error. Reformated and still the same issue.
  • HP Master
  • 27,725 Answers
You should run the chkdsk utility sit back and watch it recover the lost files it might take some time
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
hope this helps
Posted on Mar 28, 2011
My hp 3115m keeps rebooting. a blue screen pops up and says there was an error and my computer will restart. it keeps doing this over and over. what can I do?
chris, did you download an application or driver? If so try uninstalling it in safe mode. Blue screen is not a good sign. Re-start normally after the uninstall.
Nov 20, 2014 | HP Computers & Internet
Hello, It seems I have to re format my HP 1000 Mini. It will not start in Safe or any other mode from the advaced options menu. It just goes to a blank screen when you do select anything on the advanced...
You cannot use another laptop as an external drive.
I would not try a re-install just yet though. The bios will try to boot from your selected device and a failure to boot usually gives an error message of some sort. I would first try to get a boot CD/DVD that will let you boot up and check the hard drive for errors. If you have a bootable windows CD/DVD this may allow you to carry out diagnostics before you resort to full re-install.
Feb 20, 2011 | HP Mini 1000 Netbook
I have a Dell Inspiron 9300 with a blank screen; it only comes up in VGA or safe mode. I received the error message 1000-0146 after running the diagnostics. We have tried looking for the LCD panel switch...
That error code is pointing on your hard drive-it is going in Big Junkyard in Heaven. Try recovery console if you have original installation CD. If not,your need to take out stuff that your need and install another hard drive. Good luck and Happy Holidays!
Dec 27, 2010 | Dell Inspiron 9300 Notebook
I turn on my hp pavilion zd7020us the hp page boots up then goes to safe mode or normal mode page then goes to a very quick blue screen and turns off and starts the whole process over again any ideas
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jun 18, 2010 | Computers & Internet
My Dell Inspiron 6000 won't boot up. It keeps
Hi:
The DST error code 1000-1046 is definitely a failing hard drive. ..I am not sure why your laptop is not recognizing a CD in the drive, but you should go into your BIOS settings, and in boot sequence, make sure that the CD drive is the first boot device. If you can't boot from a CD, you are not going to get very far with installing a new hard drive...
May 02, 2010 | Dell Inspiron 6000 Notebook
Acer extensa 5620 p[owers up to boot stops then reboots three times then stops blank screen through out procedure changed hard drive to no effect.?
You boot files could be damaged. Try booting up in Safe mode. To boot in to Safe Mode. Press the F8 key while booting up and you will get a list of booting options. Choose the Safe mode. If you are able to boot up in Safe mode, then the next normal boot should solve the issue.
Mar 19, 2010 | Acer Extensa 5620-4020 Notebook
Need help please and thank you
For that you need to fix error on harddrive.
For that You can solve this errors with following 2 methods.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then press any key.
Then type "y"
Let me know if you need further assistance.
Feb 05, 2010 | Compaq Presario 5000 PC Desktop
Acer Aspire 3693WMLi -Launch startup repair
Try to boot in safe mode. From a cold boot, hit f8 till it gives you several options including "safe mode". Do that and if you can boot to windows let it do it's stuff before restarting normally. Good luck
Aug 29, 2007 | Acer Aspire 3000 Notebook
HP PAVILION ZD8000 SEREIS 100GB (4200 RPM)HARD DRIVE - 374730-001 100 GB Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
