Question about Sony NEC Optiarc Dvdrom Drive Ddu1678a Int Atapi Black Bulk (4582262913305) Internal DVD Drive
I need the driver for ddu1678a dvd drive - Sony NEC Optiarc Dvdrom Drive Ddu1678a Int Atapi Black Bulk (4582262913305) Internal DVD Drive
  • 31 Answers
Need dvd rom drivers
If you are using Windows OS, most of the CD/DVD Rom drivers are generic you do not need to install any drivers for the devices to function. If it is the firmware that need updating, go to the manufacturer support to download the firmware file to update your DVD Rom firmware.
If your Windows system cannot detect your DVD Rom, it could be your DVD drive had failed. Is the DVD drive settings for set correctly ie. if your DVD drive is of IDE interface. No settings is required for SATA interface.
Hope it helps.
May 17, 2011 | Computers & Internet
Hi we just installed windows 7 and now our dvd player wont play
was you install dvd drive driver??your problem may caused your dvd drive need to install driver
go to device manager to check it, is there any yellow mark at device manager??if yes it mean you need to install driver, insert your motherboard cd driver and install dvd driver
i hope this helpful
thank you for using fixya
Feb 04, 2011 | Toshiba (SDM1222) Internal DVD Drive
Acer dvd driver not reading
If it is not reading you need to check the "Region" setting. If it is set for the right region, your DVD might have a problem. Although you need a DVD driver for Windows 98, which is no longer supported,
you do not a DVD driver for XP, Vista and Windows 7; those Operating Systems automatically install drivers for any DVD drives. Since you did not specify your OS, I am limited to telling you to try another DVD drive on that same computer and see what result you obtain.
Jacques
Jan 31, 2011 | Acer (KV.16X04.007) DVD Drive
Missing drivers
Hello makubi, hi, on windows you don't need the driver. windows already has one installed, if you cannot find the DVD drive on the my computer most likely you have a problematic drive. try using a good DVD drive. or swap the drive to other computers to confirm if the drive is bad. If on other computers the drive is still bad replace the DVD drive.
Oct 27, 2010 | LG 22x8x22x DVD?±RW DL IDE Drive Black...
Lost dvd driver
DVD drives usually don't need drivers to be installed separately. It will work right away as the native driver is already installed. However, if you really need one for the purpose of troubleshooting a problem with your DVD drive, you need to provide the model number of your DVD drive or the model of your computer.
May 18, 2010 | Computers & Internet
I need driver for DVD ram Teac dvd rw dvw28 slc, please
THEN DOWNLOAD FREE DRIVERS FROM WWW.SOFTPEDIA.COM
U CAN FOUND ANY TIME OF DRIVERS FROM HERE.
U HAVE NO NEED TO PAY ANY THING.
THANKS ALOT,
SANJEEV KUMAR
+919876388918
Feb 01, 2010 | Teac DVW28EC093 Super Multi DV-W28EC 8x...
Acer dvd driver missing acer ferrari 400 dvd uj-845-c
CD/DVD drive drivers are Operating System generic drivers and need not to be installed explicitly. The CD/DVD drive drivers are installed along with the Operating System and can be reinstalled automatically at next restart, if missing.
Check in the Device Manager under the "CD/DVD drive" category if there is any device listed there and having exclamation mark. If there is any exclamation mark visible beside the CD/DVD drive name then right click on it and restart the Computer.
Restarting the Computer will reinstall the CD/DVD drive driver thus causing it to work normally.
Nov 25, 2009 | Acer Ferrari 4005WLMi Notebook
Cd rom recognised as cd audio
They will definately need drivers to be able to give out 100% of the performance.
You definately might have receive a disk while purchased the CD/DVD ROM.
Try that driver once and see the difference.
Jun 03, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Bose 321 DVD drive failure
Found another help site similar to FixYa where a person had posted that they successfully replaced their failed DVD ROM drive in their BOSE 3-2-1 Series I unit with a later model Toshiba SD-M1712 drive. There are 2 plastic trim bits and the metal DVD drive unit cover that need to be swapped between the old drive and the new PC type drive to complete the repair. I located and ordered a new drive and spent last evening removing the old drive from the BOSE. To remove the old drive all that is really necessary is to remove the lid from the BOSE unit and pop off a black steel holdown assembly across the top of the failed drive. Once that is done the old just drive lifts out and the replacement is virtually the same as swapping out a drive in your PC. I am awaiting arrival of the replacement OEM drive ($25) from some place in Texas. This just may work. BOSE wants hundreds of bucks and several weeks to repair their crappy unit. I will never purchase BOSE again. I had to also purchase a power supply in years past for this very lightly used unit and that was $300 and a lot of aggravation using the BOSE repair system. I have trouble just throwing this unit away because we spent $1000 hard earned $'s to buy the "best". I was certainly fooled. If this doesn't work I'm only out $25.
Dec 09, 2008 | Bose 3 2 1 GSX System
DRIVERS NEEDED
All optical drives use ATAPI drivers, these drivers are native to Windows. Physically install the DVD player and it will be recognised, depending on what type of CD and DVD burning software you have your drive may not be recognised by them.
OEM burning software will only work with the optical drive it was supplied with, retail burning software should work with any drive.
Aug 31, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Sony NEC Optiarc Dvdrom Drive Ddu1678a Int Atapi Black Bulk (4582262913305) Internal DVD Drive Logo
131 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
