Question about Senco Air Tools & Compressors
I cannot get the pin out of the old driver - Senco Air Tools & Compressors
    President:
  • Senco Master
  • 1,388 Answers
I use an arbor press set up for removing these small pins. It looks very much like a press used for removing drive links on chainsaw chain, but you need a jig to hold driver piston at proper point. Some drivers pins are tapered so try pressing in both directions. I have not been able to remove these pins using a vice and punch. You have a big chance of breaking piston. On occasion, I will break the piston anyway and end up purchasing driver/piston. Parts are at www.toolpartsdirect.com. Good luck
Posted on Apr 01, 2011
Card reader won't work
Hello did you install the driver for the card reader ???
If not you can find the driver here at HP:
http://www8.hp.com/us/en/support-drivers.html
Seach by model and number, and select your windows system.
Check also the bios settings.
Try also to find the manual.
Good luck
Jan 24, 2013 | Computers & Internet
How to unjam a paslode f350s nailgun
I use an old driver blade of same model (or close fit). However I grind the back side of the old driver to allow for the metal wedged in the nose. Hold old driver steady with vicegrips. You will need to use large brass or copper hammer (prevent metal splinter ) and strike direct blow so not to break anything (miss and hit gun). Remove the head and cylinder so that you can place the body of the gun against plywood. Place the plywood on concrete floor or solid workbench. May take several hard blows. If you try to use too soft metal to drive down the stuck blade, you risk wedging more metal and making repair impossible for service center. Good luck with your repair.
Sep 14, 2012 | Air Tools & Compressors
How do I remove old pins and bushings in a 99 chevy silerado
put a jack under door to hold up take a big screw driver pull spring out the use screw driver to drive both pins out thenpull door away from truck replace bushings then put door back put pins back in hinges
Jan 21, 2011 | 1999 Chevrolet Silverado 1500
Driver door has dropped about 1/2". I see a torx
Before attempting to adjust the door, you need to check the wear on the hinge pins. Open the door fully and look at the middle of the hinge. See the pin there? Lift up on the latch side of the door as you watch the hinge pin. If you see the hinge moving around the pin or see the pin shifting back and forth then the metal grommet the pin goes through is worn and needs replacing. Motormite makes a replacement pin set that comes with new grommets ( or bushings to some). It's not so hard to change, but it can be a little tricky. Jack up the door to relieve the pressure on the pin.Start with the top pin. Watch the pin as you jack and keep going until the pin is in the middle of the movement range. Tap the old pin out and then inspect the grommet to see if it's worn past the outer edge of the metal. If it is worn past the edge then you'll need to replace that hinge. Otherwise, you can use that old pin to tap out the old grommet, and replace with the new one, then the new pin. slowly release the pressure on the jack and watch the new pin for excessive movement, then do the bottom pin and grommet.. Test door swing and alignment. If the door still hits low on the catch post, loosen those torq bolts after lifting the door slightly and now lift the door the distance it was low plus 1/8 inch. retighten torq bolts and release jack, then retest the door alignment to the catch post. Don't let the door strike the catch post hard - just let it slowly come into contact as you watch for alignment. Repeat procedure until door lines up centered on taht catch post.
Good luck!!
Nov 07, 2010 | 2001 Dodge Durango
How do I remove the old pads. thy're held on by a pin. i need to remove that pin?
Without more information as to the year and model of BMW, I can't give you exact and helpful information.
Most of the rear pad retainer pins need to be driven out with a small pin punch and hammer. Some of the newer front pins unscrew with a hex or torx driver.
Oct 03, 2010 | BMW G 650 Xcountry Motorcycles
How install wiper blades on 96 chevy corsica. i can't get the old ones off. so more preciesly, how do you get the old ones off?
you should have "pin" type wiper arms on it. that means there are short, maybe 3/16 inch diameter pins that the wiper blades mount and pivot on. get a screw driver and where the pin goes through the wiper blade there will be a little plastic tab or lever that needs to be depressed and held down while you slide the wiper off of the pin on the wiper arm. pivoting back and forth with the wiper will help in removing it.
Nov 06, 2009 | 1996 Chevrolet Corsica
How do you change hinge pins in drivers door
The repair kit that you purchase should have recommended steps for replacement. With the kit that I purchased, I had to grind the bottom of the upper & lower pins off. Since this was a quick fix, my brother assisted by holding the door steady on the blocks that we set the door on. I removed the old pins. The new pins were threaded and were pulled into place as the retaining nuts were tightened. We set the door back in place and were done. I purchased the pin kits from my buddy at a local body shop.
Sep 29, 2009 | 1999 Chevrolet Silverado 1500
I am trying to change my PIN2 and PUK codes and to unlock the SIM APP...how do i do this on my own?
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
Sep 22, 2009 | Cell Phones
How to take out old pins on front driver side
The orginal pins were stamped so that they wouldn't move. Your best bet is if you have air tools, use a cut off wheel to cut the pin in half. that way you can use either an air punch or a punch and hammer to push the bottom half down and out and the top half up and out. The door is heavy and this is not a fun job! Make sure you help and watch out for the spring behind the hinge! It is under pressure!
Aug 03, 2009 | 2002 Chevrolet Silverado 1500HD
Same
Make sure to install the ADVANCED drivers from Epson. I have the same printer in my store on the POS system. Go to pos.epson.com and register then download the driver. You MUST download driver removal tool and use it to remove the old drivers first though.
Jun 13, 2009 | Epson TM-T88III Thermal Printer
Air Tools & Compressors Logo
46 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Trippy Tripp
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
