Question about Uniden Cordless phone EXS9950
Uniden cordless phone Power Max5.8 GHz.
I have a subject system installed in my house with a base and two extensions. I also have another like system with a base and extensions. I just got TMobile at home which requirew the base to be near a cable connection. Can I somehow connect the extensions from the second to the first system, thus having 5 phones and 1 base. If possible, can you tell me how to do it?
  • dadplas Aug 04, 2008
    I don't want to have 2 systems on one telephone line. I want to add 2 phones to the first system. Is there a limit to the number of extensions. If not, can you buy a system with 4 or 5 phones?
  • 2,071 Answers
Click below;
http://www.uniden.com.au/RESOURCES_MAIN/pdfs/ELITE8805_OM.pdf
http://www.uniden.com/pdf/EXS9950om.pdf
Click on Menu on the base
click on the forward >> or backward << keys until it says the dayof the week
click on set/ringer soft key
use forward >> or backward << to adjust the time and AM/PM
when you are done either click menu or wait and it automatically goes back tonormal.
hope this may help;
Posted on Aug 04, 2008
  • Uniden Master
  • 19,396 Answers
You cannot have both system working on same telephone line.
SOURCE:
Phone ring tone in house cannot hear it do not know house to fix as instructions are in greek
must be sure handset ringer volume is NOT set TO off
2) THE Telephone line cord and power adapter are plugged in properly.
3)the handset may be too far from the telephone base. Move it close to the telephone base.
4) many extension phone on the telephone line to allow all of them to ring simultaneously.
5) if other telephones in your home are having the same problem , the problem will e in service provider
6) other electronic products such as HAM radio detect the phones cause interferences.
7)test a working phone at the wall jack.
8)remove and install the battery again and place the handset in the telephone base
9) wait for the handset to synchronize.
God bless you
Sep 27, 2012 | Lands Phones
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
The main board in my Haier HDN455 is dead. I have power to it, then none of the power lines leaving are hot. We had a power outage and it went after that. Any luck in finding a new one?
The applaince parts companies that I work with do not provide a replacement main board. You can write or call the manufacturer to try to get a replacement main board.
These problems occur because of voltage spikes that occur during power outages and lightening storms. You should consider installing whole house surge protection.
All of your electronic equipment is subject to damage; investing a couple hundred dollars for a good surge protector may save you $1000s of dollars in the future.
I am a licensed Master Electrician, and I provide fee-based DIY assistance. The fee is based upon the scope of work. The fee for assistance in installing a house surge protector is $25. Please go to http://taeckertindustries.com/serv01.htm to obtain DIY assistance
Sep 19, 2009 | Haier HDN455 45 Pint Dehumidifier...
Base no longer working. Unit is plugged in.
go to your neighbour"s house and check it there.
Jul 21, 2009 | Lands Phones
After a storm and the power went out, but don't think I was hit
Cordless phones are notorious for taking a hit from lightning storms. Your main base is more than likely the trouble. This leaves the remainer of the phone system ophans, unless you can find the same model of base system to replace it. The only testing you can do is unplug the every other phone in the home, and only leave the main base plugged in lto see if the line clears...it just may be one of the other, with a little luck. You may also want to try just plugging in a single corded phone to verify that line coming into home is good also.
Apr 16, 2009 | Uniden 2.4 GHz Cordless Phone System
Loud mum with dial tone on Uniden portable phones
Try moving the main base to a different part of the house, if that doesnt work, change the telephone line cord.
Mar 11, 2009 | Uniden 2.4 GHz Cordless Phone System
Uniden Cordless phone EXS9950 Logo
196 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
