Question about Compaq Presario CQ50-139NR PC Notebook
I, have a Compaq , my power pack had a short and when,I plug it into the wall jack, it short my whole system out and burn the power pack out,I can not get any power to my computer. can you help.
  • 31 Answers
Unfortunately there is no fix for this. it shorted out the system and you will need a new computer. Seeing that a electric shock from a human hand to the motherboad can destroy a computer then the shorting out from an outlet will definitely destroy the computer.
Posted on Mar 28, 2011
When I plug in the charger into HP pavilion dv 2000 it charges but when I press on the power button then the power button light stays for some seconds and go off with the charging light too off.
TAKE OUT THE BATTERY!!
JACK POWER PACK IN TO THE WALL
WORK NOW
DOES BIOS SCREEN GLOW , ON DEMAND.
SEE THIS, F1, F9,F10 KEY WITH POWER
ON YES, THEN POWER IS GOOD
IF THE POWER WILL NOT WORK, WITH NEW POWER PACK, AND BATTERY OUT,
THERE ARE SHORTED PARTS INSIDE THE LT
MY GUESSING Would be silly,
Mar 01, 2017 | HP Computers & Internet
How do I charge my Motomaster Mobile Power Pack Model 11-1540-2?
It should have a small 120V to DC wall adapter charger with a DC wire / connector jack that plugs into the back of the power pack. Plug the wall adapter into 120V outlet and plug the DC connector jack into the back of the Power Pack. Leave on charge until the unit indicates it is charged fully (several Hours if it was fully discharged).
Nov 20, 2016 | Electronics - Others
Compaq has flashing lightning bolt when I turn it on and never reaches POST. Fans come on randomly for a second and machine turns off and back on. Any ideas?
this is a power issue.Chasing down the cause is a little more hard. For instance it could be a short in the wall power supply, such as a kinked cord or fray. It can also be a DC jack on the port of the computer where you plug the wall jack into. if the wall jack is getting power, then that means that the AC to DC is going good. or wall to brick, however it does not mean that the power supply is good.
here is a link that will help you determine if the DC jack is bad. you will need a volt meeter and know how to use it.
http://www.fixya.com/support/r4470659-laptop_dc_jack_know_its_bad
If it is the DC jack its self then it falls into a couple of categories. The first is you can solder it back to the board if it is loose. However if it is broken internally on the jack then the jack will need replaced. A service shop will generally do these for $55-135 depending on your location. But online tutorials will help you if you want to task it on your own. since you did not list the model number I cant tell you a specific site.
Jul 24, 2011 | Computers & Internet
I lost the small clip that is inserted into the timer at the time yo want the lights to come on,.
Trippers for low voltage timers are not available at Malibulights.com or Intermatic, or ebay.
That explains why folks ask power pack questions on fixya instead of finding results at the manufacturer's website.
New Malibu power packs are electronic and not mechanical
'Harry' wrote me about a work-around for lost trippers.
He bought ordinary 3-prong wall timer, and then set malibu power pack override to ON, and then plugged power pack into wall timer. 3-prong timers sell for $10 at Walmart and Target.
http://www.amazon.com/Woods-59204-Weather-Outdoor-Repeats/dp/B0014WRNNK
http://www.smarthome.com/56006/Woods-13571-Indoor-and-Outdoor-24-Hour-Mechanical-Timers-2-Pack/p.aspx
I put my busted power pack on a remote timer, but I like timers.
http://www.amazon.com/Woods-32555-Weatherproof-Outdoor-Converter/dp/B001Q9EFUK
My research into power pack issues resulted in tips for maintaining and setting up power packs.
The reason I add these tips now, before your power pack needs replacement is some fella wrote-in.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Dec 10, 2010 | Intermatic Inc. ML121RT Malibu Low Voltage...
How to troulbe shoot my 300-Watt Power Pack/Timer. it doesnt turn on but it does turn off on time. had this product for 4 years and just now started having problems with the timer.
'Harry' wrote to me yesterday with handy malibu information.
1) Power packs come with 5 year limited warranty.
He is contacting Malibulights.com for a refund of some type.
Hope he writes back and says how that comes out.
2) He was having problem and plugged power pack into wall timer, then set timer.
Heh heh, pretty clever: Malibu transformer works, but timer doesn't, so plug power pack into a wall timer!!
That being said, I had same problem with my power pack.
I used blower to remove dirt and sprayed wd-40 and tried to take it apart.
My power pack was getting electricity.
Connections were good where lights tie into wire.
My lights never turned off.
Power pack doesn't come apart.
I turned it upside down thinking water got into timer.
I took it inside and let it warm up.
It still wouldn't work so bought another one.
Then I searched Intermatic and Malibulights.com for answer, but they have no troubleshooting or repair other than check electricity and check bulbs.
Conclusion: when power pack doesn't work, it is broken.
Unless you buy a separate timer and plug power pack into that timer as Harry suggests.
After researching power packs at Intermatic, Malubulights.com, ebay etc, the best I found were tips for next power pack that might save money:
Dec 03, 2010 | Malibu ML300RTW - Low Voltage Power Pack...
Left computer running with charger connected. Screen went blank and light showing power connected was no longer lit. New charger did not solve it. New battery (with some charge) worked. Still no charge so...
If your charger is working properly and the laptop is as well, then the laptop should work without a battery in it at all. If your new battery worked and laptop worked with it until the battery died, then the charger or charge port is damaged.
If it does not work with charger plugged in without a battery, then your charger(s) or the laptop charge port itself may be damage or broken. Or worse, the laptop may be dead.
If the laptop does nothing even with a good battery with charge (no fans, no boot, nothing on-screen, no noises) you're laptop could be dead; likely a burned motherboard or processor. It may have overheated or something along those lines.
Jun 13, 2017 | HP Compaq 6730s Notebook
HP Compaq NX9420 Laptop Power supply shorted out replaced new Power supply purchased but Laptop will not power up suspect mother board shorted out also. Any suggestions
The DC Jack Will Need To Be Visibly Inspected, and Tested ..
Most Likely Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into.....
Though, if you experienced a power surge/dip or similar, You could have shorted out the motherboard....
Dec 01, 2009 | HP Computers & Internet
My GE phone 27958 just stopped working. I originally thought the cordless handset needed a new battery, but upon replacement that did not help. I found that the base which is plugged into the land line...
check power ?
Is Ac - DC converter pack plugged into power point ?
Is the DC plug plugged into the phone ?
does power point work ?
Check correct dc voltage being produced from the AC - DC power pack converter ?
Isolate other phones on other extensinos to see if uniden is cause or not of no dial tone.
You may have another phone off hook and phone line has timed out .
Jun 11, 2017 | Uniden Cordless Phone
Ac power pack keeps failing, wont charge battery
get the whole laptop checked by the service center
as if the batteries and the power pack are ok there might be the problem with the mother board
Aug 22, 2008 | Compaq Presario M2000 Notebook
Power
You may need to have the DC Jack replaced. It appears to be shorted. Should only run about $50-75. Ask the cost estimate before leaving it. You may be able to shop around. Use the smaller MOM&POP shops rather than the STORES or GEEKS.
Jul 18, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario CQ50-139NR  PC Notebook Logo
64 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
