Can't print pdf documents- I get a message that I must install printer. I am able to print other word docs, just not pdf.
    Guru:
  • 89 Answers
It could be your adobe acrobat reader responsible for PDF documents
If you can print using other applications definitely it has nothing to do with printer.
Try downloading latest version of acrobat reader from adobe website.
Unintstall the acrobat reader software from your PC in ARP (add remove programs)
reinstall the latest version of adobe acrobat reader
Try links below it may help you too
http://www.adobe.com/products/reader.html
http://get.adobe.com/reader/
Hope I help you a bit
Thanks
Posted on Mar 28, 2011
4 Suggested Answers
crikt1
  • 59 Answers
SOURCE: Trouble with pdf docs
If your pdf's are saved on your pc or mac and they print fine, then it is probably a problem with firewall or av. allowing printing from internet. Check PDF program settings for port number to exclude or accept in firewall or check firewall and add pdf program to list of exceptions.
Posted on Jun 24, 2009
siawolf
  • 749 Answers
SOURCE: Prints PDF documents VERY slowly (4-5) per page
The actual issue you will find that its not so much the actual printing part of the process that is slow, its actually the spooling to the printer that takes the time.
Does your printer support PostScript printing ? (PostScript is a printing & imaging standard used by many printers) To find out if your printer does indeed support this either refer to your manufacturers documentation or perform a test page and look to see if you have a PostScript enabled option.
If your printer does support PostScript, make sure you are using its PostScript printer driver, most of the time we generally use PCL drivers, so simply change this.
Regards....
If you find your printer does not support PostScript there are a few other tweaks we can implement to increase printing speed.
Firstly we can force PDF files to be printed as graphics as opposed to text, to do this launch your chosen PDF viewer, select Print > Advanced > Print as image
Lower the print resolution, if we lower the print resolution most of the time the difference is very small, but it can reduce the actual print size of the document by up to 300%, which can greatly decrease printing times.
Make sure you are using the latest version of any print drivers or your chosen PDF printing program, normally Adobe Acrobat.
If the printer only has a small amount of memory if possible add more, if possible install a PostScript SIMM.
Check the amount of ram your computer currently has, check memory usage from task manager when printing to ascertain usage
Posted on May 19, 2010
SOURCE: cannot print from a downloaded pdf document.
Remove and reinstall Adobe reader ...
Posted on Mar 23, 2011
Print pdf files
Try to print another type of document, i.e : doc, jpg.
If it 's no problem at another type of document, the problem is on PDF file ( not allowed printing, security setting), or on software for opening PDF file.
Oct 01, 2013 | Epson Stylus NX100 InkJet Printer
How i print pdf format on hp1300
go to printers and then select your printer and set as default
that will print your doc, instead of saving it as a pdf
Oct 31, 2011 | HP LaserJet 1300 Printer
I first scanned all the docs into the picture gallery. My professor needs them all in pdf format. How? I've got an HP Pavilion laptop. My professor's waiting for me to call her tonight when...
PDF format means legal form which is handled in Adobe Acrobat. You said you scanned your docs into the picture gallery, and I am hoping that you left them in the default format that your scanner uses instead of changing them to a picture format (like JPEG, or TIFF) or this may be too complicated to assist via email.
If you do not have the latest version of Adobe Acrobat & Adobe Reader, do a search on the internet and download then install them. They are free. Once the programs are installed, open Adobe Acrobat and click on "file" at the top left side of the screen and try and open one of the documents you saved in the picture gallery in the acrobate program. If they are compatible, all you have to do is rename and save the document in Adobe. To save it, after you have opened it in Adobe - click on file and then "save a copy" or "save as" and choose whatever the documents name is and .pdf at the end (save to a pdf format) and then you are done.
If the file format of the documents are not compatible and will not open and easily save in PDF format using the Acrobat, then I would suggest asking your teacher for an extension.
May 07, 2011 | Computers & Internet
Whenever i try to print anything my printer prints the first 5 lines or so and then just stops and moves on to the next page where it print the first 5 lines before giving up again.
What type of document are you trying to print(PDF, MS Word doc, etc)?
Is the printer connected via USB cable, Bluetooth?
First thing I would do is try printing a different document or even a different type of document.
If printing different documents results in the same problem then I would uninstall the current drivers, download the latest drivers from Canon, then install those drivers and try printing again.
Also, if the printer is connected to your computer via USB cable verify the cable has no exposed wiring or try a different USB cable.
Mar 12, 2011 | Canon MP610 Photo All-In-One Printer
Prints .doc won't print .pdf
In order to print both DOC and PDF you need to have both PCL6 and PostScript drivers installed on the PC. One is for Word documents and the other will support PDF printing. You can get the drivers from DELL website. http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Dec 29, 2010 | Dell 3110cn Laser Printer
Regards....
May 19, 2010 | HP Color LaserJet 2600n Printer
My printer won't print ADOBE files, but prints all word documents
I believe you are misunderstanding what you're "telling" the computer to do. You are telling the computer (I assume in Microsoft Word, but perhaps elsewhere) to generate an electronic document in PDF format. (I believe PDF stands for Portable Document Format)
It uses a printing metaphor because like a paper copy, the PDF file is designed for people to read, not edit the document you have created. Also, some PDF-making software methods involve pretending to be a printer, which allows the user to make a PDF file in any program that would normally only output your work to a printer.
Most people, when wanting to print a PDF document onto paper, open it with Adobe's Acrobat Reader (which is free software) and print the document from there. For sharing a document that you want no changes to, this is a superior option to sending people an MS Word .doc (or .docx) file, which does not have its information "locked" onto virtual pages in the file.
I hope this helped!
Jan 18, 2010 | HP DeskJet F380 All-In-One Printer
Printer queue is full
This problem seems to be related to USB printers and print queue issues are very common in Mac OS computers and Windows 2000 PCs.
You don't say if you are using a USB connector, but they're pretty common these days. You also don't say if you're using a Mac or PC, but most people use PCs. I did find a solution for this issue that says it's related to Windows 2000 and a USB printer, but may apply to other operating system platforms:
Print Jobs are Stuck in the Print Queue
The first step to this solution is to download and install an HP diagnostic software utility. There's a separate page at HP that describes the utility and lets you download it:
HP Printing and Diagnostic Utility
I didn't find any information that specifically said that you "can" print a test page but "can't" print a document.
Another reason why you might be able to print a test page but not a document isn't related to the printer but the application that created the document. If you are having trouble with Word or Excel or whatever office application you used to create the doc, it might not print. That's why it is helpful to try to print a variety of different docs, created with different apps.
It could also be the individual document. Occasionally, a document becomes corrupted and while you may be able to open it (and sometimes you can't do even that), it doesn't print. If you haven't tried printing more than one document, you can test this by creating another doc in the same app and seeing if it'll print.
Try doing test prints with different docs and then with docs created in different apps. If those work, it's doc/app related. If they don't, try the links I suggested above.
Good luck.
Sep 21, 2008 | HP Officejet 5610 All-In-One InkJet...
PDF producer
You can use another pdf converter,there are many pdf converter in the market. Compared to other versions of pdf converters,i find Advanced PDF To word more appealing as it more faster to convert a huge PDF file to .doc without any quality lost, it also has more configuration option. http://www.blog.advancedpdfconverter.com
Sep 19, 2008 | Databecker PDF Producer for PC
246 people viewed this question
k24674
jasbo
jasbo
