Question about Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522
Rattling AFTER water use, while heating - Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522
1) Rattling or clunking sound in pipes when water is shut off can be caused by lack of air chamber at the faucet. When moving water is suddenly stopped by faucet turning off, the forward energy of water suddenly stopping will cause pipes to shake. This is because water cannot be compressed. To stop this problem, each faucet has air chamber connected to pipes behind the wall. The air chamber is a simple pipe sticking up with a cap on it. The air chamber never fills with water, so a 'pocket' of air is contained inside the pipe. When water shuts off, the forward motion of water moves up the air chamber where it compresses the air which absorbs the energy, so pipes don't rattle or clunk.
http://www.crsupport.us/images/7b_build_const.jpg
2) Gurgling, popping sound inside tank is caused by sediment build up.
http://waterheatertimer.org/How-to-clean-sediment-out-of-water-heater.html
3) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 28, 2011
I have takagi TK3 tankless water heater humming and rattling noise issue at start up.
Sounds kinda lame, but check every nut, bolt and screw on the heater and where it fastens to the wall. something may simply be loose!
Apr 01, 2017 | Water Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Want to shut off my hotwater heater and still run my boilerhave base board heat
Turn off water but leave heat on - Possible? - Handyman WIRE ...
handymanwire.com > ... > Heating and Air Conditioning
Jan 14, 2003 - 10 posts
My hot water baseboard heating system is a closed system. ... Could I shut off the main water and leave the boiler and heat going for ... If one is not installed, install one and rely on that to save the boiler from the damage of running out of ... I do not wantto have city water push my antifreeze out of the system ...
What's the best temperature to set my hot water baseboard ...
greenhomeguide.com/.../whats-the-best-temperature-to-set-my-hot-water...
Nov 21, 2010 - With hot water baseboard heating, is it better to keep the heat at 60+ degrees ... a hot water heating system where water is heated in a hot water boiler and then ... by setting the thermostat to lower the heat when you don't need it on. ... Not only do I turn my heat down when I leave for work in the am but also ...
Jan 17, 2016 | Water Heaters
Premier plus
Sounds like ITS kettleing this means its nearing boiling point potentially very dangerous, u need to check out pump, also over heat thermostat i wouldnt use till its safe
Oct 17, 2013 | Water Heaters
We have pulsation in the pipes which is rattling the pipes noisily and has shaken so badly pipes sprang a leak. Could this be caused by the expansion tan kmafunctioning
yes ,if your tank is under pressure or water logged then when your water expands when heated it has nowhere to go, i'm assuming by the model you described that you are referring to your heating system. you need to drain the pressure down on your boiler to 0 than take an tire guage and check it on the sniffter valve underneath the blue cap. it should be about 15 pounds. if not pump it up with bike pump or compresser.wait for about an hour and recheck if not holding air then discard, you need to save the water you drain and pump it back in somehow, as it could be glycol, or have rust inhiters in it. if you take a reading without draining it will give you a false reading
Oct 23, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Rheem glas fury water heater rattling
Thermostat may be heating element hotter than normal causing a change in temperature causing the noise. You could try adjusting temp down a little on thermostat. It sounds like it's getting the water very hot and thermostat may not be working correctly.
May 21, 2010 | Rheem 81VP6S/430126 Water Heater
We just installed a Rheem 50 gallon water heater. When you use any hot water, a low pitched vibrations occurs that you can hear in the bathroom and bedroom. When the water heater completes the heating...
Listen close near any check valve that may be in the piping system, as well as the pressure relief valve on tank. It may be a check valve rattling, but you normally will only experience that when water is flowing in and out of the system.
Mar 19, 2010 | Rheem 81VP6S/430126 Water Heater
Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522 Logo
197 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
