Have a pellet stove that has been working perfect for years, then last night it shut itself off and when I opened door there was this black tar on everything inside and the windows were also black. I had to use a razor blade to get it off. I have cleaned it and within a hour or so it starts to turn black. Any suggestions.?
  • proton2390 Mar 28, 2011
    I have not changed brands of pellets and have cleaned the chimmney reagulary. I am starting ti think it might be the air intake as you suggested. I watch the flame go from big to almost out and then normal for a while
    Brigadier General:
  • 4,736 Answers
Several of things come to mind: Have you changed the type (Brand) of pellets, recently?
Have you had your chimney (stack) cleaned in the past year? Is the fresh air intake functioning properly? Is the auger feeding to much or to little pellets?
Changing brand of pellets - Not all wood pellets are made the same. If you recently changed brands, you will need to tweak your stove to handle this new brand. This will affect how the auger feeds.
If you chimney (stack) hasn't been cleaned in the past 12 months, it may be partially clogged with creosote and not drawing properly and it is liquefying and running back down the chimney and not allowing for a clean burn. And could cause a chimney fire.
Fresh air intake: If that's not functioning properly, you're getting incomplete combustion. Which will cause the black tar looking substance you described. Couple that with changing brands of pellets and you have a problem.
The above are the first things that came to mind. I hope it steers you in the right direction to troubleshoot the problem. Please let me know.
Posted on Mar 28, 2011
  • Rich Landrum Mar 28, 2011
    Proton, I agree with you. You on the right track. If yours operates automatically, the sensor is failing. Also, check the gasket material on the front door. It may be severely worn and pulling air from the interior of the house, which would throw off the fresh air intake. If it needs replace, make sure you get the proper size.
My stove keeps going out on E2 and shuts down why
The E-2 Error code indicates an automatic shutdown because the stove does not detect a fire. Check out Englander's troubleshooting guide to some of the causes.
http://www.heatredefined.com/faq/troubleshooting-guide/pellet-stove/evolution-pellet-stove/evolution-pellet-troubleshooting-guide/e-codes/e-2-failure-to-start
Feb 27, 2015 | Englander Direct Vent: 2,000 sq.ft. Pellet...
Jamming auger onmagnum countrysidepelletstove
The softwood pellets are not the problem. The problem is the quality of those pellets. Make sure you are not using last years fuel and it has not been stored outside. Also check the auger system for junk, gouging and bending of the auger.
Nov 26, 2013 | MagnuM Countryside Pedestal Corn Stove
Pinnacle Pellet stove augre gets stuck
hmm, could be low power to the motor, heavier power cord, or it's possible the auger needs new bushing/bearings, wiggle the auger to see if it has any play in it OR it's fussy about the size of pellets it made to feed. please send pictures and or results.
Jay
Jun 08, 2017 | Pool & Spa
Brand new Propel Keeps shutting off
Take it back and replace if not working properly. Why go crazy. U paid with good money - you are entitled to a good working product.
Aug 24, 2017 | Pool & Spa
Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 17, 2010 | Ovens
We have a harmon p61 pellet stove. last night it turned on by itself and we were unable to shut it off until we unplugged it.
The only thing that will turn it on is the thermostat setting! Check your temperature setting for temp. in the centigrade or farenheit! Tank-you-very-much!
Aug 28, 2008 | Heating & Cooling
Heating & Cooling Logo
356 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
