Pls send a video on how to refill hp121 coloured cartridge for F2000 series. the right spot to inject each of the refill ink so as not to mix up the ink
    Guru:
  • 89 Answers
What is the specific model number?
I have here example for HP Deskjet F2488 All-in-One Printer
Replacing the Cartridges Video
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01761015&lc=en&dlc=en&cc=us&product=3964429
Posted on Mar 28, 2011
Had refill at Costco for hp 4620 printer 564 cartridge and now printer will not print in color. What do I do to make it print?u
That's means you didn't refill the colour ink properly.
Try this method, use the injection to draw any of the colour of about 2mm of the refill you bought, inject it into one of the tiny holes of the cartridge and draw a little back so as to remove the dirt in the foam inside the cartridge.. That's all
Aug 09, 2014 | HP Office Equipment & Supplies
What ink can i refil my my series 11 ink cartrige ??? or another cartrige thats a hp or cannon or epson that will fit in my dell 948 printer
Hello. You can refill the existing cartridge without a problem. Other brand cartridges will not work as they are all programmed only to use DELL model cartridges.
To Refill the cartridge you simply need to pull the label off, Drill the Air holes out, test what colour is behind the hole by sticking a toothpick into it and inject the correct colour.
If the cartridge leaks from the print head then the cartridge has been overfilled and you need to **** out ink (half ml at a time) until the dripping stops.
The only issue with this is that the printer may not accept a cartridge that it thinks is empty, and even though you fill it, the in-built counter in the cartridge will still read "0"
Some models will print with a empty cartridge, constantly reminding you that it is empty. if you simply ignore or click continue you can keep on printing, but some models will not print at all if it thinks the cartridge is empty.
I hope this helps Regards GM
Jun 06, 2011 | Dell 948 All-In-One InkJet Printer
Can you refill dell series 21 ink cartridges?
Any ink or toner cartridge is refillable, For ink cartridge, check for the small pin hole at the top of the cartridge to inject the ink refill. But remember that the ink should be compatible with your ink cartridge model. Good luck
Jan 05, 2011 | Office Equipment & Supplies
Pinkish tint in photo color copies ....... Is there a way to adjust the color ?
The "secondary" colours are produced by mixing the "primary" colours. One of the "primary" colours inside your inkjet cartridge is out of ink, and the resulting "actual" mix is not the "theoretical" mix.
Refill or replace the ink-cartridge.
Apr 05, 2010 | HP PSC 1315 All-In-One InkJet Printer
Which are the fill holes in the colour HP121 cartridge
What printer?
If you read Danish, try this
http://www.fyldselv.dk/index.php?
Mar 05, 2010 | HP Easy Refill Kit for (HP) Black Inkjet...
Do I need to mix 2ml of each colour in siringe and mix
HI,
Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
thank you,
vijay (vote for me)
Sep 24, 2009 | Canon Office Equipment & Supplies
I refilled a 33 colour cartridge still says low
I would like to inform you that Lexmark printers does not support refilled cartridges. Please note that #33 cartridge is know as a rushmore cartridge and in this cartridge it has memory chip on it to identifiy the ink estimation. hence it is not possible to change the low ink indication.
Please note: using refilled cartridge may void ur printer warranty.
Apr 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Cartridge
did you do a clean cartridge and re alignment first?
http://tinyurl.com/6qcpgy
Aug 08, 2008 | HP PSC 1410 All-In-One InkJet Printer
Refilling a printer cartridge
Some cartridges have a natural hole in the top to screw into and make bigger, and you inject the ink here. Others you have to actually physically gently cut the top off (using a very sharp and very thin blade, i use a craft exchangeable blade kit like a pen knife) adn some just lift off. My lexmark 27 has to be sliced apart then lifts off after seal is broken. Then the ink is injected directly into the sponge areas inside as pamphlet instructs. Can you please tell me exactly what the cd said in short, to further help. Some cartridges have a ruber bung to refil into as well.
Jun 13, 2007 | Lexmark X1290 All-In-One InkJet Printer
jasbo
jasbo
