Question about Durabrand DWT1304 13" TV
Want to just use in the video mode..Hooked it up to cable tv works great..But now I can't get back to just video mode..Also I bought this TV used and has no remote..Is there a way to get back to only video mode as this is all I use it for,, Thanks for any help on this..
I also have this same problem if anyone would know the answer, called the support phone # on back of TV about 1/2 hr. ago it is 6:50 pm 3/27/11 so. california usa, time.. It is 1-800-605-8379 waiting for reply..If I get a reply and solution I will come back and post it here. If anyone else would have the answer to this problem w/o using the remote it would be much appreciated...Thanks
Posted on Mar 28, 2011
Hi, I just bought a blu ray home theatre system and hooked it up, the surround sound sounds great but it only works when my watching a movie with the blu ray player... I hooked the blu ray player to my tv...
If you want everything to have surroud sound, it all has to run through your system and you select which function to use. Yes it sounds like improper connections.
Sep 03, 2011 | RCA Audio Players & Recorders
We have our cable box hooked up to the tv and get a great picture but no sound. The previous owners had a stereo system hooked up to the tv and we are simply trying to get any sound at all. We went into...
Ok, I need more verifications:
1) Your TV is Fujitsu Siemens PlasmaVision P42VHA40 Monitor which does not have tuner? If not, please provide the make and model of the TV.
2) What kind of cables you are using to hook between the cable box and the TV? HDMI? Component video (Red, Blue, and Green cables withe RCA plugs)? Composite video cable with Yellow RCA plugs?
3) Are you trying to get the sound to come out off the TV speakers or through the stereo system?
Feb 03, 2011 | Fujitsu Siemens PlasmaVision P42VHA40...
Dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
Jan 01, 2010 | Televison & Video
DV1130 hooked up to TV, DVD works great. VHS has
If you are using RCA cables (Red Yellow White) the video (yellow) could be bad or not in the connector all the way. When the VCR mode is selected try pulling the yellow connector out then back in and see if anything changes on the tv.
If you are using another type cable let me know and I will help you diagnose.
Hope this helps
TankMurdock
Apr 25, 2009 | GoVideo DV1130 DVD Player/VCR
Screen just went black
Think your set tuner is bogus. The other tuner that you used should work, but if it is not a cable tuner configured to your system it will not work either via the rf outputs or the audio video outputs. If that cable box works with another set then you have a real head scratcher on your hands.
Mar 24, 2017 | Sanyo AVM-2756 27" TV
Blurry Sanyo TV
Well after playing around with the tv some more, I decided the problem was probably the cable jack, and tried running the video in/out cables thru the VCR to get around this, which I read generally works but in this case nothing. I had tried the tv on various settings, anytime I put the tv in "video" mode I'd get a blue screen and nothing else. Anyway I found a switch in the back of the Direct Tv box for ch. 3 & 4 settings. So I flipped it but still got a snowy picture, only this time it was on ch 4 instead of ch 3. By sheer accident I put the tv back in video mode while I had the satilites setting to ch 4, and the picture came up crystal clear. Since I didn't mess with it further, I'm not sure if it was the channel selector or the fact that hooked the tv up via the video cables, but whatever it was it did the trick.
I just KNEW this could not be a broken tv despite the fact that everhwere I read online suggested it was. I knew pictures can go out, or sound can go out....but to have BOTH go out didn't make sense to me. Anyway, glad its working! :)
Jun 15, 2008 | Televison & Video
Memorex television is not working with my new Phillips DVD/VCR combo
depending on how you hooked it up; if thru coax cable the you have to use channel 3 or 4 on the tv to use Philips. If you are connecting with video and audio cables then you have to select a/v input on tv to use.
May 08, 2008 | Memorex MT2271 27" TV
Orion STV 2763 27in TV
I am assuming that your TV has Video IN source selection.
You need to use the Video/Audio OUTput of the VCR/CD and connect them to the Video/Audio INput of the TV. To do this you would have to use a 3-wire shielded cable with male RCA connectors color yellow, red & white.
c296912.jpg RCA male connectors, yellow is usually video, red/white is audio left/right.
599898c.jpg as shown OUT of VCR/CD to IN of TV.
Pnce done, play the VCR/CD with a good known CD or tape and set TV to Video mode.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 31, 2008 | Orion STV2763 27" TV
TV (Model DS27510) is stuck on Video2 setting, unable to change!!
Ours is doing the same thing except on Video 1. I called Sanyo customer service and they said I need the original remote. They were willing to sell me one for $20. Here is what I did instead. I used a cable box and hooked the cable in to it. Then I took the type of cables that will hook into my video 1 slot and plugged them in there and plugged them into the back of the cable box in the "cable out" positions. It worked ! If you do not have a cable box you might try a DVD/VCR combo or a VCR. Good Luck
Sep 16, 2007 | Sanyo DS27510 27" TV
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Durabrand DWT1304 13" TV Logo
77 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
