Question about Denon AVR-881 5.1 Channels Receiver
I use the Denon avr 881 receiver I just realized that it loses sound for jus a second or two then returns like nothing happend also when the sound leaves the signal: lock light blinks thanks please help.
    Sniper:
  • 54 Answers
Lock light blink looks like input signal gone intermittently, I guess it maybe HDMI version compailable problem, suggest to manage to find new firmware to improve it.
Posted on Mar 28, 2011
Dish HD-DVR connected to a Denon 3808ci via an HDMI cable. Problem is periodically, the screen goes black for a split second and then comes back. Rewind and play again the blackout doesn't repeat. When...
Your'e losing digital data from Dish or the DVR. Since even live TV is through the DVR it is always a potential problem when anything glitches. That it doesn't repeat on immediate rewind/playback says the data made it to the hard drive ok.
The Denon is only defaulting back to an analog audio feed upon loss of the digital (preferred) one.
If it affects the video AND audio simultaneously the cause is something common to them.
I'd look at HDMI cabling into the Denon from the DVR.
Don't blame the Denon just yet.
My $.02:
I'd skip the video right past the Denon to the TV/Monitor even if it means using component cables instead of HDMI, but keep digital audio coming in from the DVR. Added cabling and connections never improve anything. Plus, HDMI cables are expensive.
It would be interesting to see if the problem comes back and affects only the audio or the video.
If you use optical cable make sure it has smooth flowing curves and no small-radius bends that would lose light power.
http://www.retrevo.com/support/Denon-AVR-3808CI-Receivers-manual/id/3124dj391/t/2/
Feb 06, 2011 | Denon AVR 3808Ci Receiver
No sound when on internet radio, playtime is running, volume is not muted, internet ok
It was solved by turning the receiver off with the power button (not stand-by). After turning on the netradio did have its sound back. Apparantly it must be running some sort of Windows os.
May 16, 2009 | Denon AVR 3808Ci Receiver
Denon AVR881 Turns on for few seconds then shuts OFF
(Probably too late to help you, but I'll post so others can see)
I had the same thing happen to my trust AVR-881 two weeks ago. Even re-initializing the processor was no help.
I took it to the repair shop. They replaced three transistors on the board, and charged about $175 for the job.
Apr 25, 2009 | Denon AVR-881 5.1 Channels Receiver
Subwoofer Connection Problem
why don't you both return these units and call Denon for replacements without these problems?  Sqeaky hinges get the oil.
Nov 12, 2008 | Denon AVR 2808Ci Receiver
Denon AVR-588 Sound Delay
FIRST, IF YOUR USING HDMI CONNECTIONS IN THE DENON HDMI SETUP YOU HAVE TO TURN THE AUDIO DELAY ADJ. ON
SECOND, THE DELAY TIME ADJ, FOR OTHER SOURCES IS LOCATED ON PG 27 IN THE MANUAL, HERE IS THE LINK TO DENON SITE WITH MANUAL
http://www.ca.denon.com/AVR-588-OM-E_102.pdf
Jul 12, 2008 | Denon AVR588 Receiver
Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Denon AVR-3802 Receiver
Denon 1508
sterio wireing touching each other putting it in protect mode retrace all your wireing and redo this should clear up the protect mode if not return denon as manufacture malfunction to get replacement
May 30, 2008 | Denon AVR-2105 Receiver
Denon AVR 883 Audio glitch
More than likely the protector circuit is getting activated... You can't go below 6 ohms on the surround back which means you need 12 ohm or higher speakers for outside (since the two outputs for surround back/zone2 are in parallel). As a simple diagnostic test, disconnect one speaker and see if the sound survives longer than 2 seconds.
Mar 26, 2008 | Denon AVR-883 Receiver
Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Jan 06, 2008 | Denon AVR-2807 Receiver
Intermittent audio output
It's quite possible one of the relays is failing that is part of the switch between audio output choices.  Do you notice any output difference between a certain output (i.e. dvd, tape etc)or is that point arbitrary?
Sep 10, 2007 | Denon AVR-3300 Receiver
Denon AVR-881 5.1 Channels Receiver Logo
122 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
