Question about Kenmore Dryers
Needs new belt. Is the belt a common item? - Kenmore Dryers
What size of belt do i need for indesit is70c condensor dryer 7kg
Posted on Jan 12, 2013
    Guru:
  • 257 Answers
Hello Stevenand266,
I understand that you are having a problem with your dryer, you need a belt. Almost all dryers are belt driven so yes they are common items to a dryer. However, all belts for dryers are not the same size, shape or length. I would be glad to help assist you in your endeavor of replacing the belt if you can post a make and model of the dryer in question.
Thank you for choosing FixYa.com
Justin
Posted on Mar 28, 2011
Noise near pully area every so often after new timing belt on 2000 ford escort zx2
The pulley bearing could be failing - a common failure item.
May 16, 2017 | 2000 Ford Escort
How to put on new belt
https://www.partstree.com/parts/troy-bilt/edgers/tb516ec-25a-516-966-troy-bilt-edger-2011/general-assembly/
Zoom into the diagram, remove (item 45) belt cover to expose the belt and pulleys. Take note of how the belt is routed.! you will need to follow the same route with the new belt. You may need to remove the Blade guard (item 40) if the belt doesn't fit over the head of the guard. There may also be a sprung idle tension pulley, which will take up the slack in the belt once replaced. Looks pretty straight forward.
Apr 19, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
My hotpoint aquarius just got new belt fitted but can only put 3 items in to dry otherwise wont turn
perhaps the belt is slipping and needs adjusting on the tension-er so that the pulleys can the belt more securely
Jan 23, 2016 | Hotpoint Washing Machines
My little toy pu has 219K. Besides tune ups, oil changes, transmission fluid, differential, new radiator hoses (once), new shocks, new brakes, new battery, tires and new starter connectors....nothing. I...
common sense tells you that things do wear out...yes it is very important to replace those items before one goes out and maybe damage an otherwise incredible little engine!!
Aug 24, 2011 | 1998 Toyota Tacoma
The drive belt broke
Hello there and thanks for cfhoosing fixya
Here is a listing of the belt diagrams and a part number for you ok?
Belt, Drive
Item # 529597
img-descriptiontab-on.png img-repairgurutiptab-off.png Dryer belt. This is the most common belt used on Whirlpool, AMANA Kenmore, Kitchenaid, Roper, Estate and other dryer brands. The belt is flat, 92-1/4 inches long, 1/4 inch wide and has 4 ribs and 3 grooves. It replaces many other belts, including some with 5 ribs and 4 grooves.
img-descriptiontab-off.png img-repairgurutiptab-on.png See our dryer belt diagram to see how this belt should be installed around the motor and idler pulleys.
Watch Video
Order now and choose FedEx 2Day or FedEx Overnight shipping and this item will ship out today - or it's FREE!
$11.20 Quantity:
In Stock
Feb 05, 2011 | Amana NGD5400TQ Dryer
How to adjust a tensioner on a 2001 chrysler voyager
You mean your belt tentioner, serpentine belt, it is not adjustable if your belt is coming off you have a bad tentioner, bad pulley or your power stering pump is leaken and your belt is soaked, if oilly firts found your leak (most common is a hose from reservoir to pump) then replace belt with a cheap belt (had lost of trouble with Life time or hi dollar belts), in the mean time also inspect your tentioner if ani play side ways replace it, also remove idle pulley and spun it close to your ear, if any noise replace it, you may get away with a single item changed, but for trouble free time, replace all items: belt tentioner ($38) idle pulley($25) serpentine belt ($25)
Oct 17, 2010 | 2001 Chrysler Voyager
Belt replacment
Here is a diagram from kenmore corp. that should help you out
Maytag Dryer Belt Routing
This is the most common belt routing found on most Maytag brands clothes dryers.
Since you will have everything disassembled to change the belt, this is an excellent opportunity to vacuum out the cabinet to remove dust and lint and perform preventative maintenance on your dryer. When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Dec 04, 2009 | Kenmore 66862 Dryer
Timing chain broke and I was CURIOUS IF THIS IS A NORMAL MAINTENANCE ITEM THAT WASS NEGLECTED LIKE REPLACEMENT OF A TIMING BELT?
Timing chain broke on v8, 3.2 2001, will the piston hit the valves,and damage the pistons?
May 27, 2009 | 2000 Jaguar XJ
Loose belt sound
Replace the weak automatic belt tensioner. This is a known common failure item. My solution is guaranteed to rectify your situation.
Dec 29, 2008 | 2002 Toyota RAV4
Loose belt noise
Replace the weak serpentine belt tensioner. This is a common wear/failure item. My solution is guaranteed to rectify your situation.
Dryers Logo
82 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
