Question about Dryers
Hi DWSR405EB0WW is my model number for my GE Dryer we bought in 2002. The drum does not turn when we start the dryer but there is a buzzing sound. the belt is still intact and the drum rolls when pushed by hand. What can I do?
    Sergeant:
    Champion:
  • 202 Answers
Hi.... You have a bad motor ... the only way to fix this is to get the motor replaced
Posted on Mar 28, 2011
My dryer motor comes on (you can hear a humming noise) but the drum does not turn.
GE dryer won't start. Makes buzzing noise... - YouTube
? 0:39
www.youtube.com/watch?v=W_og12QJqm8
May 8, 2010 - Uploaded by maxicheong Anyone seen this before? When i tried to turn on the dryer, i get ahumming / buzzing sound and the drum ...
Oct 08, 2015 | GE WE12M22 Dryer
GE dryer model dwsr405eb0ww has intermittent heat problem associated with centrifugal motor switch. Interior drum light goes off with door open when centrifugal switch disengages. This is intermitte
First thing I would do is un-plug the product and remove the line cord access plate and check the terminal block/cord connections, a lot of times the installer of the product does not get the terminal block 'nuts' tight enough and it either burns up or cause erratic operation. If this checks out ok check your home electrical supply system.
Jan 09, 2015 | GE Dryers
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
Ge dryer - buzzes when the start button is pushed but the dryer motor doesn't start or the dryer drum moves. could be a jam or the motor? Motor didn't seem to be a problem before today.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 16, 2011 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Start button buzzes when pressed, dryer doesn't start.
I assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Apr 26, 2011 | GE DVL223EBWW Electric Dryer
Dryer won't start.. has power sounds like something binding. long buzzing sound when starter depressed. try once or twice and then nothing for a while. come back try again ..long buzzing sound again
Hi and welcome to FixYa, I am Kelly.
You did not include a make and model number for your dryer so... this is a GENERIC response. With a make and model number we can better help you.
The long buzzing your hearing is the motor winding trying to start the motor. After 30 - 45 seconds if the motor does not start the thermal overload will cycle and prevent further attempts for around 5 - 6 minutes until the motor winding cools down.
Causes of a dryer motor not starting:
1. Binding.
a. Broken dryer fan blade lodged inside the blower housing
b. Motor start switch failure
c. Motor bearing failure
2. Dryer drum bearing / roller problems
a. The drum can be bound up and dragging on internal components of the dryer
b. The Idler pulley bearing may have failed and it is now a brake.
c. Front or rear drum seals failed / pinched against rear or front of the chassis
d. Drum roller bearing failure and is now a brake.
Reach inside the drum and see if you can turn the drum. If you can not turn it with a little effort, you need to find out where the binding is inside your dryer.
This is the best I can do for the moment without a model number. With a Make and Model number I can provide parts listings and item numbers of where to check.
Thanks for choosing FixYa.
Kelly
Feb 06, 2011 | Dryers
When the start button is pressed there is a slight buzzing noise. Drum turns easilly and the belt appears to be connected.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair ? The dryer will not start
heatman101
Aug 29, 2010 | GE DSXH43EAWW Electric Dryer
I have an electric ge dryer. when i turn the
check the belt, it may not be tight enough around the drum and idler to engage the motor.
Oct 04, 2009 | Dryers
Dryers Logo
80 people viewed this question
Top Dryers Experts
Marvin
Marvin
