Question about Makita Garden
I havebeen using a makita 9527 pb 4.5" angle grinder and all the sudden the grinder had troubles working all the time at first it took a little shaking to start up then hitting against a hard surface then would not start at all? Any ideas what could be the problem ?
    Guru:
  • 479 Answers
There are various causes of failure but the checks should be carried out in this order, you will need a continuity meter or multimeter to trace continuity from the plug to the switch in the grinder:
If plug is rewireable check for loose screws at plug pin terminals, loose fuses etc.
Wires in power flex breaking, usually at plug or where flex enters machine.Check the continuity from each pin of the plug to the switch in the grinder
Faulty on / off switch or loose spade terminals on switches.
Worn out brushes.
Armature or field coils of motor going open circuit.
Posted on Mar 28, 2011
How can i replacethe carbon brushes on my angle grinder as they are totally and completely worn off
Buy the new brushes from the manufacturer. You already have the old ones out - put the new ones in the same way you took the old ones out.
Jul 27, 2014 | Makita 9005B 5" Electric Angle Grinder
I have a Makita 100mm Disc grinder what attachments are available for this older tool...model M952
as its a grinder...there are not many attachments available....just your common grinding and cutting discs.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 06, 2010 | Makita 9553NB 4" Angle Grinder
Makita Angle Grinder not working
check inside for any loose connections plus check the brushes. if like you say it is smoking it could be a trip to the wheelie bin for that one.
Jul 29, 2010 | Makita Angle Grinder 4.5" 9524NBX
Angle grinder eats carbon brushes
Yes, the rock dust is what's destroying your brushes and armatures. It gets sucked into the rear vent slots and gets to those parts and eats them away quickly. I don't know of any vacuum systems make by Makita but there are some companies that make them for their systems. Blastrac is one that comes to mind but they can be real expensive systems. I don't know of any grinders with sealed brush/armature systems, they have too much heat to disipate. To make your Makita grinders last longer make sure you are cutting with the side of the blade that directs the dust away from the case and try to have a strong airflow blowing the dust away from the grinder to minimize the dust taken in at the back of the grinder.
Jul 15, 2010 | Makita 9005B 5" Electric Angle Grinder
Breaks support rings in all blades
are you using the proper inner blade flange?? that is the only thing that I can think of that would cause your problem
Jun 12, 2010 | Makita 9553NB 4" Angle Grinder
New 4" angle grinder does not come with sanding disc pad
You need the 4" rubber pad, Makita Part #743009-6. It can be found on websites like www.ereplacementparts.com.
May 23, 2010 | Makita 9553NB 4" Angle Grinder
New grinder cannot release lock nut to get blade on
i have trouble breaking makita parts loose. you will probably have to hit it. tap the bottom with a hammer to break rust or whatever loose. don't damage the shaft or nut. you may have to have someone help hold it while you put some muscle on it. good luck
Apr 26, 2010 | Makita 4 inch Angle Grinder (GA4030K)
Where can I find brushes for MAKITA 9557PBX 4
The brushes for that grinder are Makita Part #194074-2. They can be found on sites like www.ereplacementparts.com.
Mar 31, 2010 | Makita 9557PBX 4 1/2" Angle Grinder with...
Garden Logo
91 people viewed this question
Top Makita Garden Experts
Jim Parker
Jim Parker
JOHN LAPIER
Tim Venetis
Are you a Makita Garden Expert? Answer questions, earn points and help others
