Question about Syntax Olevia 537H Television
I can get to the menu settings, go up to the auto channle search,,, but my tv won't do the search,,, what can i do ?
Make sure the TV is NOT set to "Show Room" mode. It must be in "Home" mode, else it will prevent certain actions from being performed. I think it's under "Power Up" setting or somewhere in the setup...
Posted on Sep 06, 2012
I have the same problem. Cable went out, hooked up an antenna and it scanned ok. Hooked up a diff amplified ant, worked the same. So watched videos. Next morning tuner would no longer scan or add channels. Now it will not even factory reset. Get to Auto Scan and it goes no further, cable or air.
Posted on Apr 02, 2011
How do i channl search my tv without a remote?
depends.....whats the type of tv and model? some tvs are fully remote controlled but if ya tv has a menu button press menu then press ok then select the options displayed by using the down arrowed button press ok go to search/tunig select auto tuning/search press ok it will select all channels automatically and store them press menu to exit
Jul 08, 2013 | Televison & Video
My tv comes on but it goes back off unless i keep changing the channles
See if someone set the timer (auto power off) on the menu. Check if the remote is not sending that signal.
But that seems to be a electronic failure.
See you
Jun 24, 2009 | RCA TruFlat 27F520T 27" TV
I can't find UHF channle 36
Turn plasma to analoque tv tuner auto search while xbox is connected and turned on. Auto tune will pick up uhf 36 channel .Flick chanelstill xbox chanel is viewable
Apr 19, 2009 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
Older hitachi TV
Check the menu and check to see if it's setup for cable and not antenna. Also see if there is an auto program function in the menu.
Apr 23, 2008 | Televison & Video
Have a olevia t v lost channle #3 went threw set up and channle search also tried to add channle #3. tunner channle only will pick up channles 26 32 44 56 60
You could try bypassing the tuner and use the rca inputs if you have satellite or cable box that works this way. Hope this helps
Mar 16, 2008 | Televison & Video
Channels won't go past 38
Make sure cable Tv is hook up directly to TV then go to the tuner menu and do an auto scan or auto search for channels that should fix your problem.
Mar 07, 2008 | Proscan 32LA30Q Television
Can't get to main menu
Before auto-programming, select set-up menu or tuning menu..
find selection possibly called tv / catv or normal / cable......
select CATV or cable............and then select auto-program..
If you need more help, I will need Make,model and mo / yr
built off the back of tv............................T.
Dec 23, 2007 | Televison & Video
Syntax Olevia 537H Television Logo
278 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
