Question about Garmin GPS
Garmin etrex (basic version) - display suddenly changes to single vertical line, after a few minutes indoors and immediately outdoors when satellite signal available
  • 1 more comment
  • Anonymous Sep 24, 2008
    I have the same problem - vertical line as soon as a satellite locks on.
  • Anonymous Sep 27, 2008
    I have a similar problem with my etrex legend. A single vertical line which seems to appear randomly, sometimes in a couple of minutes, sometimes after 10 or more minutes. Not related to satellite acquisition. Must remove battery to clear and restart.
  • helmet77 Mar 25, 2009
    I have the same problem. I will try a software update
I had the same problem with the eTrex Legend (monochrome) and tried the solution of taking it apart, cleaning the connections and putting it back together. This did not work for me. I then updated the firmware to version 3.9 and that solved the vertical line problem, at least for the time being.
Posted on Oct 14, 2008
I started having the same problems today. Try going to the Garmin site and downloading a software update for your model gps (it's under the "support" tab). This has seemed to solve the issue on my etrex legend.
Posted on Sep 24, 2008
My Garmin Etrex Legend starts up and finds the satellites, but then screen goes blank except for vertical line on the screen.Stays that way until batteries wear out. Fixable?
I have the same Garmin product. It had a problem displaying anything. I went to the Garmin web site and got tech support. They fixed the problem by telling me what to do. Try them befor you throw it away. But it sounds un-repairable
Aug 11, 2009 | Garmin Etrex Legend Handheld Gps
Same problem
Update the unit software via the Garmin.com website. There was a new satellite launched in 08 which is causing this problem, and the update corrects the problem. Come back and tell us if this solved your problem. Thanks.
Aug 08, 2009 | Garmin eTrex GPS Receiver
LCD screen display is broken up
Try updating your unit's internal software via the Garmin.com website. There was a new satellite launched which has caused problems such as this, and the update fixes it.
If this solves your problem, please come back and tell us, and rate our solution. Thank you.
Jul 08, 2009 | Garmin eTrex Legend GPS Receiver
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
ETREX LEGEND HAS 1 VERTICAL LINE ON SCREEN AND WONT SHUT OFF UNLESS YOU PULL BATTERYS
Have you updated your unit's software from the Garmin site? There was a new satellite launched in 2008 which has been causing problems, and the new update fixes this.
Mar 03, 2009 | Garmin eTrex Legend GPS Receiver
Blank screen with a black line down the middle.
Due to a new satellite launched this year, the WAAS is affected. Disable the WAAS, go to Garmin and download the latest software version FOR THIS UNIT. Install, enable WAAS and you should be good to go.
Nov 23, 2008 | Garmin eTrex Legend GPS Receiver
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
Garmin Vista Shutting down and freezing up
People! The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
May 27, 2008 | Garmin eTrex Vista GPS Receiver
Garmin Etrex display problem
Have you updated your Garmin unit software recently?
Mar 21, 2008 | Garmin eTrex GPS Receiver
Screen Blanks
11-08-07
I had the same problem with an etrex Vista. I spoke with Garmin, they said that a recently launched WAAS satellite is interferring with some models (he mentioned it is the models with a black and white screen). Garmin tech support said that they're working on a software patch but for the meantime switch WAAS off.
Call Garmin tech support with any questions or to find out about the software patch, 1-800-800-1020
Nov 04, 2007 | Garmin eTrex Vista Cx GPS Receiver
GPS Logo
427 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
