Question about Jura Capresso ENA 4 (13421)
Display reads fill beans, but bean are filled. I also took them all out thinking something was lodged in there, Turned machine on and off, switched settings and still says fill beans.
  • 29 Answers
This sounds like the grinder is not strong enough to grind properly. Try adjust the grind to a bit coarser, if this makes no difference then the bearings inside the grinder may gone. Try only fill a small amount of beans in the container and see if it works. It may be that when there is too much of a load on it it will not spin the blades.
Posted on Mar 29, 2011
    Master:
  • 412 Answers
Some models, such as C60 and C65, have a plastic disc about the size of a silver dollar as a guard above the grinder, with very little clearance for the beans to feed below the guard. Oily beans can stick together and hang up on the guard. I noticed when the Fill Beans problem happened, that the grinder didn't sound like there was anything in it, just a whirring sound of the motor.
My field modification to solve this problem was to remove the guard (1 screw), add a 1/4" spacer (made from a 10-24 nut) beneath the guard, giving more clearance. Beans fed great, and the screw was just long enough to re-mount the guard with the spacer below it.
To do this:
1. Unplug the machine.
2. Open the top of the machine. On C60 and C65, there are two OVAL head screws on the back. If you don't have an oval head driver, you can grab them with small vice grips and work them loose. At the top front under the side lids there are two torx screws - much easier to find a driver. Remove the lid, being careful with the wiring to the power switch. The lid can be moved aside with the wiring still connected, just enough to access the guard.
3. Remove enough beans to expose the guard, and remove the torx head screw and guard
4. Put your spacer in place (anything metal or plastic about 1/4" thick with a hole in it will do), and replace the screw, being careful not to over-tighten and strip the threads. You may need to find a similar self-tapping screw 1/4" longer.
5. Replace the top and the 4 screws that secure it. Plug it in and try it.
This turned out to be a bulletproof fix for my machine. I thought about discarding the guard entirely, but seemed like a better idea to leave it in place. You can watch the beans happily feeding into the grinder, and no more Fill Beans light until you actually run out of beans!
Posted on Mar 13, 2017
Why won't it brew?
Think the grinding mechanism is jammed with something. Disassemble unit and look for same.
Sep 03, 2017 | Saeco Vienna Plus Black Super-Automatic
I need a description for how to open and clean the grinder. I keep getting fill beans message and it has beans.
I have not done it, but I believe you simply remove the two screws you can seen when you look into the coffee bin.
I used to get "fill beans" messages when there were beans in the hopper. Eventually I determined this was due to my choice of beans: oily (ie. shiny) beans seem to clog up frequently, "dry" beans (beams without a sheen) rarely clog up.
Since the beans are gravity fed, oily ones tend to stick to one another
May 01, 2015 | Jura Capresso Impressa S9 Coffee...
Why fill bean message shows on display when machine is full of beans?
Difficult to say without the machine in front of me. Normally you get this response if no beans fall into the grinder. Are your beans oily, sticking together and not falling in?
Normally freshly roasted beans esp dark roasts are a bit oily. If so then you can change roasts, brands or mix with another type.
You might try to adjust your grind per the manual. (turn knob inside the bin while the grinder is grinding) see #8 page 12.
If the beans are falling in and grinding and you still get this msg I would say you have a grinder problem.
http://capresso.125west.com/e8_manual.pdf
Mar 02, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
How to brew
Read the manual fill up the brewer with coffee beans and get enough watet in the flask place the beans and turn on the switch and wait for it to display next steps. Hope this helps
Apr 22, 2013 | Coffee Makers & Espresso Machines
My Jura Ena 5 gives a 'fill beans' message even though the hopper is full and it won't grind the beans even though it seems to be operating. Help.
Same thing happening to me right now. I think this has something to do with having used flavored beans (which I was warned not to do). Supposedly they gum up the machine.
Nov 27, 2009 | Jura Capresso Impressa S9 Coffee...
Beans stick in hopper
Bob,
Thanks for the help but I was well past that stage. After cleaning half a dozen times, changing beans three or four times, soldering the contacts on the switch, changing it, replacing the whole doser flap sled and anything else I could think to do I finally fixed it. It took me months but in the end it was the doser trap door not allowing the dozer flap to move back and hit the switch when the grounds came down. A simple light bending out fixed it. So...we had a rare mechanical issue. The machine does have a design flaw in that it has a long three inch shoot for the grounds which makes it susceptible to clogs. Do not use oily beans!
Feb 20, 2008 | Gaggia Titanium Espresso Machine
Jura Capresso ENA 4 (13421) Logo
1,387 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
