Question about Toshiba 32AF53 32" TV
Hello I have a tv toshiba 32af53 and one remote control ct 90158 which I cannot programme it with the code that gives me the manual 057 and not which could be the problem please need help
cammykins
  • 149 Answers
SOURCE: remote help
What is the model# for your set? Find your TV set below: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Posted on Sep 24, 2007
SOURCE: 30HF85 TV with CT-877 remote, which doesn't work.
I had the same problem with my remote...over time it slowly stopped working. (sorry for poor terminology) I noticed that one of the battery terminals was corroded and that the metal connecting the battery to the board was completely gone. I simply swapped this out with one from another remote and now its working fine. Seems the only issue is that the battery was not connected.
I hope this helps.
Posted on Apr 05, 2008
  • 89 Answers
SOURCE: toshiba that uses CT-90040 remote
if this is a time warner cable remote. the toshiba code is 015. sometimes a tv has several codes but only one controls everything. dont understand tuning video into tv. sounds like u need to plug rca wire into input plugs on the front or rear and then move switch to video but dont know what wires u r using.
Posted on Dec 27, 2008
cactus bob
  • 267 Answers
SOURCE: Toshiba 36HF73 tv with remote (CT-90047). Remote doesn't work.
you just may have a bad remote . remotes go bad in strange ways sometimes messing up a program for just the tv and all other things iits programed for are fine . the recever in the tv is rock solid i have NEVER had one go bad on a modern tv (tv made in the last 20 years) try a new remote and enjoy............. Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 26, 2009
  • 360 Answers
SOURCE: NEED HELP LOCATING INSTRUCTION MANUAL FOR T.V.
ct841 is the model of the remote. The model of the TV will most likely be on the back. Once you have the TV model, -->click here<--, this is the site to download the info you seek.
please take the time to give this solution a fix ya rating.
clarkco
Posted on Apr 11, 2009
Can Toshiba remote CT-90158 be programmed to control a Digital Stream converter? If so, how?
If there is set-up code to digital-stream with this remote control; you can. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Apr 19, 2015 | Toshiba Televison & Video
Como programar control remoto ct-90302 a televicion samsung lcd
If your Toshiba remote is programmable, you can use its code search feature to find a code that will control some or all functions of your Samsung TV. If a search through all codes stored in the remote fails, you may have to try another programmable remote.
Jan 25, 2015 | Toshiba Ct-90302 Remote Control
I need the code list for a Universal remote Toshiba CT-90158
Try to enter code 664 it is the only code in my book for a JVC dvd player
Aug 15, 2012 | One For All Televison & Video
How do I get a manual for Toshiba remote controller model CT 90302
Hello
This remote control is for use with Toshiba 22AV500U TV. It is originally coded to use with this TV, yet other TVs also can be programmed with this remote contorl. There si no specific user manual for this remote control itself. All codes and proceedings are with the user manual for the above mentioned model Toshiba Tv. If you haven't that manual, send your email address to me by Fixya. I'll send a copy of that manual to you by return mail. Or go tho this link from where you can download the above said TVs manual for as PDF format. OK
a248.e.akamai.net/pix.crutchfield.com/Manuals/052/05222AV500.PDF
Sep 01, 2011 | Toshiba Ct-90302 Remote Control
I need codes so i can program my remote
Program your remote to do what?
You don't need to program this remote if you're using it with the TV it was supplied with. If you're trying to program it to work other devices - TV / DVD / VCR - then you're out of luck. The CT-847 isn't a programmable remote!
You need to buy a universal remote to control multiple devices. They are usually supplied with codes.
Please rate my solution if you find this helpful. Thanks.
Oct 14, 2010 | Toshiba CT-847 Remote Control
Need codes for ct 90157 remote for phillips dvd player.
I'm not sure if you can use it for a DVD player, every place I look says it's TV only. Odd, since it has a TV/Video button?!?!?
But here are the newest Philips codes:
Philips 006,007,010,011
,013,016,033,035
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Toshiba CT-90157 Remote Control
Toshiba CT-877 Remote
http://remotes.com/remotes/documents/Toshiba/CT-877.pdf
Jan 06, 2009 | Toshiba CT-90157 Remote Control
Need Toshiba codes for Directv "RCA" box
try to program this code for your direct tv onto your remote: code is 057
Jan 01, 2009 | Toshiba MR120 Remote Control
Toshiba ct-90233
Here is a link to your manual:
http://remotes.com/remotes/documents/Toshiba/CT-90233.pdf
Oct 02, 2007 | Toshiba CT-90157 Remote Control
Toshiba 32AF53 32" TV Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
