Question about Jenn-Air Kitchen Ranges
I live in sydney Australia. I have a Jenn Air Fridge Model GT1726PVCB/13 Serial No 130661137WZ it has become defective, tripping the safety switch. The electricity man said there was low insulation resistance on the fridge. Eart to active and neutral was 0.01. Can this be repaired or is it the end. How can I get help from Jenn Air in Sydney
  • 93 Answers
SOURCE: WHIRLPOOL FRIDGE S/S MODEL #ED2FHGXKQ00
Hi Yamanayeemi,
"Dont forget to rate my solution to your STOVE!"- Fixya or helpful?
Before attempting any testing or repairs. unplug your fridge.safety first.! avoiding an electrical shock hazard.
It might likely be your water inlet valve that is bad , corroded or clogged.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink).
Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires.
The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors.
Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting).
Place a probe on each terminal.
The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Does my suggestions help to solve your problem?
Posted on Aug 03, 2008
SOURCE: Jenn-Air S160
What is 15 year old Jenn air stove, model S 160 worth? It is in good shape and has just recently been checked by SEARS and operates fine. New racks, new knobs, and new broiler pan. Completely cleaned up. Looks like new!
Posted on Oct 17, 2008
SOURCE: nokiad 6288 :D
3 will unlock the phone for free
Posted on Apr 15, 2009
jmgldsmth
  • 2005 Answers
SOURCE: have jenn air (not sure of model #) in house built in early 70's.
use at least #12 take a sample with you to the wire supplier (not a hardware store) you must purchase the heat protected plastic special wire (UL hi-heat) and, use porcelain wirenuts to make any wire-to-wire connections
Posted on May 25, 2009
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
What year is this motor. Evenrude 2 hp. Model number. 2602s. Serial number. E0004528.
Hi Jason, I'm an Aussie living in Sydney Australia and like most countries the year your car was made should be on your registration paper like mine mate, Just wondering if it's the same with a boat..........CHEERS..
May 01, 2016 | Boating
Serial # C3824851 WHAT YEAR AND MODEL IS THIS-THANK YOU
Hi Scott, I'm an Aussie living in Sydney Australia and like most countries the year your car was made should be on your registration paper like mine mate, Just wondering if it's the same with a boat..........CHEERS..
Apr 30, 2016 | Boating
Jenn air microwave quits working after 11-13 seconds of heating
open circuit switch when power reaches this switch it will shut down as switch is us
Aug 12, 2012 | Jenn-Air JMC8127DD Microwave Oven
The jenn-air fridge that i have jcd2289ae has stopped working it is tripping the gfi, i have tried plugging it in another plug in but it trips the breaker
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2289AEQ/1266/0165000/M0406284/00012?blt=06&prst=&shdMod= here is a simplified wiring diagram for your unit. It might help you track back the problem.
Before it started tripping the circuit breaker what was your refrigerator doing that was not normal? Usually, before something fails massively it will give you hints it is coming. Did your ice maker or lights stop working? Has the compressor been running an excessively long time?
What trips a breaker is the unit drawing more current that what the breaker is listed at. So something in the unit has shorted to cause this to happen. Although the first thing we check in a situation like this is the compressor circuit it isn't always the cause.
Jun 26, 2011 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
IS THERE A RECALL ON JENN-AIR REFRIGERATOR, MODEL #JCD2389GE ?
MAYBE!  Our Jenn-Air side by side has a similar model number to yours and it was recalled on March 10.  Check on maytag's recall page to see if your fridge has been recalled by entering your model and serial number.
Mar 11, 2009 | Jenn-Air JCD2389G Side by Side...
A/C will not respond to remote control.
The unit has a problem with the safety device, its either defective or have some error. Try to reset the error by disconnecting the power supply for 10sec. then "on" and try. If error still exists may be some of the safety device is defective. You need a qualified technician for this problem.
Check also the air filter if clean and clean if dirty and reset the error.
Jan 28, 2009 | Fujitsu 18C1 Air Conditioner
I have a whirlpool multiflow 380lt fridge i have broken some shelving i need the egg guard and crisper box where could i get these parts i live at st marys sydney nsw
Try contacting Stokes here:
Stokes (Australasia) Limited: Stokes Appliance Parts
24 Palmerston Rd West Ringwood, Victoria 3134 Australia
ACN: 24 004 554 929
Tel: +61-3-9845-8300
Fax: +61-3-9874-1077
E-mail: info@stokes-aus.com.au
Or contact Whirpool:
Whirlpool Service - Parts Price List
call Whirlpool Service on 1300 363344 (Australia) or 0800 442584 (NZ)
Sep 09, 2008 | Whirlpool Refrigerators
Kitchen Ranges Logo
35 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
