Question about Jwin iLuv i702BLK FM Transmitter for Apple iPod
The iluv i702 transmitter has stopped transmitting - the light does not come and there is no transmission. Is this a common problem and how can I fix it?
I put new batteries in Transmitter and never got any temp reading.The unit is less than 2 years old and is not working. Is there anything I can do?
  • Remove all batteries
  • Install new batteries in transmitter
  • Wait for transmitter to initialize and begin transmitting temperature data
  • Install known-good batteries in receiver
  • Observe outdoor temperature reading
If this doesn't work, the transmitter or receiver or both may be defective. I find in very cold weather the transmitter stops sending the temperature.
Dec 08, 2016 | Measuring Tools & Sensors
Why does my kenwood TH-K2 fm transceiver will not transmit
Users Manual (download if you don't have it)
TX I
NHIBIT
You can inhibit the transmission to prevent unauthorized
individuals from transmitting, or to eliminate accidental
transmissions while carrying the transceiver.
1 Press [MENU].
2 Turn the Tuning control to select Menu No. 25 (TXI).
3 Press [MENU].
4 Turn the Tuning control to select "ON".
5 Press [MENU] to store the setting or [PTT] to cancel.
"TX INH" appears and an error beep sounds if the
transceiver tries to transmit while TX Inhibit is ON
May 11, 2014 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
2002 Chevrolet Cavalier Remotes not working. door locks works in side but not with remote. batterys ok and they are transmiting. just stop work one day.
If you know for sure that the transmitters are transmitting (tested on a key fob tester), and the remotes are the correct ones for your vehicle (haven't been recently replaced with a different part number), then you may need to simply re-synchronize your transmitters to the vehicle. This is different than reprogramming the transmitters, but uses the same method on the remotes.
To resynchronize, Stand within 5 feet of the car, with the remotes. Press and hold the LOCK and UNLOCK buttons on the REMOTE for about 7-10 seconds. If the transmitter was out of sync with the car, the horn will chirp to confirm it is now synchronized. If this method does not work, then the transmitters will have to be programmed to the vehicle, which requires a scan tool to do. Good luck :)
Oct 12, 2013 | Chevrolet Cavalier Cars & Trucks
FT-890AT yaesu transceiver has distorted transmit audio
Hi Ronald,
Could the problem be related by having the mike to close to your mouth? This is the most common cause of over-modulation/ distortion from the transmission end.
If you have the mike 3-6 inches from the mouth and speak in an even non loud tone, that would help sort that out. If this is not the source of the over modulation/distortion, then you may have a transmitter issue, which would require the unit to be serviced by a qualified radio technician or ham radio operator, if you know one willing to look at it for you.
I hope that this has helped you.
Cheers,
Peter
Dec 01, 2012 | Radio Communications
AKG PT 80 transmitter stopped transmitting.
Still sounds like battery. Are you using alkaline batteries. Theres mic transmitters need a fair discharge rate whilst transmitting and maybe your current battery in not giving enough current.
Mar 31, 2010 | AKG WMS81/535 Professional Microphone
Failure to sync
hi, there maybe interference with the signals try in a differnt area.
Aug 04, 2009 | Jwin iLuv i903 Consumer Headphones
Does my durango look ok?
i think it would look pretty kool on 22's
May 26, 2009 | 2000 Dodge Durango
Jwin iLuv i702BLK  FM Transmitter for Apple iPod Logo
119 people viewed this question
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Oloyede Monsuru
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
