Question about Husqvarna Garden
Will this saw be able to cut steel on truck and trailer frames? the steel may be 2-3 inches thick in some places. other places only about a half inch thick. is this a good tool for cutting heavy metal?
  • 46 Answers
Never heard of cutting steel with a chain saw. What works best for me has been a sawzall with a good quality steel cutting blade. The real thin metal cutting blade on a circular saw works pretty good also.
Posted on Mar 28, 2011
Need a repair manual for the poulan pp4218AVHD PRO 42CC CHAIN SAW
http://r.search.yahoo.com/_ylt=A0LEVihRiHpTpRoAn.UPxQt.;_ylu=X3oDMTBybnV2cXQwBHNlYwNzcgRwb3MDMgRjb2xvA2JmMQR2dGlkAw--/RV=2/RE=1400568018/RO=10/RU=http%3a%2f%
May 19, 2014 | Poulan Refurbished Pro PP4218AVX 18" 42CC...
I was changing the fuel line on my partner 950 and when i pulled the line out of the tank a round steel bushing fell out of somewhere in the tank . the reason i was changing the fuel line was because
This is the fuel filter weight, push the fuel line through the center flat side facing out, push the fuel filter onto the pipe, now pull the weight down on top of the filter this also crimps the pipe to stop the filter falling off
Apr 08, 2013 | Husqvarna Partner Gas Powered Cut Off Saw...
I bent the depth of cut scale on a Craftsman 7-1/4 in. Circular Saw. How to true it so I can again set correct depths?
With the saw unplugged, lay it upside down on a bench or table. Put a small scrap of 2x4 against the blade and adjust until the depth of the blade matches the thickness of the 2x4. Lock it in place, Then bend or adjust the depth scale so that it reads 1-1/2 inches. Good luck.
Dec 10, 2012 | Sears Craftsman 7-1/4 in. Circular Saw...
Working on a plank 5' long 10"depth a thickness of 1.5" will a scroll cut into this hollow plank to a depth of 5"then go across 1.5"then return 5"
Cole, The cut you are describing is challenging, but possible on a 20" scroll saw. First the blade--- you call this a hollow plank. If this is something like a hollow-core door, then the 1.5" thickness will be no problem. If you have to cut through a solid 1.5" (as you would at the edge) then you have a slow go of it unless you can find a pretty coarse pitch blade (big teeth). Second, making the turn----- assuming you are making this cut somewhere near the center of the 5' lenghth, then you won't be able to simply make a 90 degree turn after you cut the initial 5 inches. But you can make an approximately 60 degree turn, then stop the saw, leave the workpiece in place with the blade still in the cut, and reset the blade to cut sideways (so that the teeth of the blade are facing to your left or right rather than pointing toward you.) Before you make this blade turn, however, you should make the other 5 inch cut, so that you don't have to make the blade turn twice. Alternatively, if the 5 x 1.5 piece you are removing is just scrap, then you can make your two 5 inch cuts just converge to a point at the middle of the 1.5 inch line so that you can remove most of the scrap without moving the blade. Then you can reset the blade more easily with the workpiece removed from the saw. I hope you found this helpful.---- Oh, one more thing! The 1.5 inch part of the cut would be a lot easier simply by using a coping saw - they are about $15. Actually, you could do the whole cut with a coping saw. Good luck! Al K
Jul 29, 2011 | Dewalt DW788 Heavy Duty 20" Variable Speed...
I jsut bought a used Delta 28-682 18" bandsaw. I am shocked by the poor quality of the blade guides. They are gapped so far apart that they hardly touch the blade unless it is twisted at a 45 degree...
It sounds as though the friction pads that go on the guides are missing. If you cannot buy a new set, try glueing some teflon blocks of the desired thickness to the guides.
Apr 06, 2010 | Delta 28 682 18" Steel Frame Band Saw
My husband is out of town and I want to use the reciprocating saw to cut a wooden curtain rod (1-2 inches thick. The owner's manual is MIA. How do I use this thing? Where's the blade?
the blades are usually in the case.its simple just place what you want to cut in front of the blade with the metal bottom of saw touching the object to be cut and pull the trigger.
Jan 29, 2010 | Hand Tools
I want to drill a 89mm hole through the top of a 2.5m diameter vessel wall thickness 10mm stainless steel , with a hole saw but i can't risk dropping the piece of steel in the vessel do you have a centre i...
This is posted in the chainsasw catagory, probably not the correct forum. That said if it falls into the vessel will it contaminate the contents? If no and you are just concerned about getting it back out; you are going to make a hole about 3.5 inches in diameter if my math is correct. Attach a couple of strips of steel can with double sided tape (between drill bit and cutter teeth). A magnet can then be used to remove the the plug if it falls into the vessel. HTH Lou
Not recatagorized - closed 09/25
Sep 21, 2009 | Starrett Ct218 2 1/8"carb Tip Hole Saws
Water leak in travel lite truck camper has caused over cab bed area plywood to decay. Need diagram or schematic to determine best method of repair.
Hi brad, I had the same problem with a camper. I do not know of any available schematic, but would recommend dis-assembly of ceiling area to fix. It's not any easy job, but the only way to fix it properly. Remove all water damage section, make sure water is not pooling on the exterior roof. If it is collecting on the roof, you must brace it from underneath to raise any 'dips' so it sheds water, and make sure you apply a sealing coat (available at trailer stores, or on line) on the exterior. Also, if you park the camper when not in use, make sure you tilt it to help shed water more quickly. You have to use your carpenter and auto body skills to fix this. Don't put it off, I did and the roof deteriorates very quickly once you notice you have a problem. To remove plywood that is damaged, use a skill saw set at the minimum depth (thickness of the plywood) so you don't cut thru anything else. Use a drill to determine the thickness. To install new plywood, cut to fit the opening(s). Next get 3" wide by 3/4" thickness boards, place above cut out area, half on existing ceiling, half hanging over cut out, screw in thru existing ceiling into boards, attach replacement piece, screw into overhanging boards. You can putty over the joints, sand sand and paint, or just glue some sort of fabric to cover the area and make it look finished. Good luck!
Sep 14, 2009 | 1999 Chevrolet C2500
Cut off question
Here a few examples: * 5 inch trim saws, usually with a fine-toothed blade and often with the blade located on the left side of the motor, for easy viewing of the blade path. These are available in 120V, AC models, and rechargeable battery models in various DC voltages. * 6 1/2 inch saws, as shown in the illustration above, used for cutting to length nominal lumber for construction, as well as ripping lumber, and cutting plywood or composite material. * 7 1/4 inch saws, often call skillsaws, from the name of a major circular saw manufacturer, Skill. These are the backbone of the construction industry, used for cutting lumber up to 2 1/4 inch thick. They are used for cutting framing lumber to length, and ripping lumber. They also have a number of optional blades which can be used for cutting composite materials, concrete, ferrous and nonferrous metal sheeting, pipe, tubing, and even cold-rolled steel bar stock. * 8 and 10 inch saws, used for cutting to length larger lumber or timbers, up to 4 inches thick. These are heavier, more cumbersome tools used mostly in industrial work. * Worm-drive saws have a gearbox with a worm-geardrive, and are found in 7 1/4 inch models which are most commonly used for ripping lumber or cutting plywood decking or sheathing. They typically have the blade on the left side of the machine, to make watching the blade path easier when cutting parallel to the edge of a wide sheet of plywood.
Aug 27, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Garden Logo
77 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
