Question about HP m7170n PC Desktop
Hard drive replaced. But does not recognize hard drive. Old hard drive but back But does not recognize hard drive.
    Problem Solver:
  • 12 Answers
Open the CPU and check whether it properly connected (both the wires sata cable and power cable)
then check in BIOS. is it detected if it is then change the boot device priority..
if its not detected then try to swap the wires with optical drive..
still not then change the HDD
Posted on Mar 28, 2011
I upgraded my hard drive and cloned my old info onto the Toshiba external hard drive. Now it only recognizes the capacity of the hard drive as 465 gb instead of 2 tb. How do I reset that back to 2 tb?
by up grading do you mean fitting a new hard drive
BY your statement you downloaded all of the data from the old hard drive onto an external 2tb hard drive ( to save everything I imagine )
if that is the case then the computer will only recognize the capacity of the new hard drive which would have been a 500gb unit
there is always a loss of capacity in a hard drive for internal workings and programs so what the computer is reading is most likely the capacity of the new hard drive
if you want to read the capacity of the external hard drive , you will have to click on it separately then go to properties and it will read total capacity and unused capscity
Nov 15, 2016 | Toshiba Computers & Internet
Won't recognize the hard drive
the hard drive will not be recognized because the BIOS has been affected by the battery removal
Jun 04, 2017 | Toshiba Satelite A135-S2286 Notebook
I just bought a new HP pavilion laptop (because the Nvidia graphics chipset on my Dell went belly up). I pulled the Dell hard drive out and placed it into an external case intending to copy the data onto...
Hi Maltomeal
it seems you know your way around notebooks.
My first suggestion is to take the new hard drive out, and put the old one into the new computer to see if it will at least boot up.
Since I don't know the operating system or the type of format that was on your old hard drive, it is possible that the current operating system you are using will not recognize the old one.
If the hard drive boots up, and it may not recognize some of the drivers because its a different computer configuration, you should still be able to backup to a thumb drive.
If the hard drive does not boot up, then your hard drive has lost its information. You might need to take the hard drive to a data recovery company like ontrack.
thanks adi
Jan 11, 2010 | Office Equipment & Supplies
I am using SuperDuper to clone my 160GB MacBook Hard Drive to a 500GB Western Digital Scorpio Blue. My problem is that I cannot determine why neither the SuperDuper program nor the MacBook itself...
The Western Digital Scorpio Blue 500GB hard drive is formatted for PC, not Mac. The simplest way to get your MacBook to recognize this new drive--and therefore copy the files from your old drive--is to plug it in to a PC and format the drive. I was advised to format with FAT 16, as this would be recognized by my MacBook. Fortunately, the process was not that involved, since the Vista-driven PC found the drivers for the WD Scorpio Blue automatically. Once formatted, I safely removed the drive and plugged it into my MacBook via a USB port using a BYTECC Drive Mate. Magically, it now appeared on my MacBook Desktop and was recognized by the cloning software I was using, SuperDuper. Three hours later, the files on my old hard drive were successfully cloned onto the Scorpio Blue--except now I had an additional 364GB of storage space. Swapping out the old drive and replacing it with the new was not a big deal at all--just make sure you have the right screwdriver for the last task--a Torx #6. Mission accomplished.
Oct 24, 2009 | Western Digital Elements powered by WD 320...
Problem It reads press f1 retry boot, press f2 set up? How to do it. I do not have a recovery disc. thanks mits
Sounds like its not seeing your hard drive or you have corrupt system files and windows isn't booting.
Press F2 to go into the setup and make sure the hard drive is being recognized. If it is recognized then that means windows is corrupted and you'll need to reinstall your laptop back to factory defaults. If the hard drive is not being recognized in there then you'll need to reseat the hard drive back into the slot.
Then turn the laptop on and press f2 to go back into the setup. If the hard drive is now being recognized then see it if boots into windows. If it doesn't then you'll need to restore your laptop back to factory defaults.
If the BIOS still doesn't show the hard drive then your hard drive is bad and would need to be replaced.
Jul 11, 2009 | Dell OptiPlex GX240 PC Desktop
I have an old maxtor hard drive 40 gig, nad my PC couldn't recogn
just need to set the jumper so this will work as the slave
Apr 18, 2009 | Maxtor Hard Drive
Hard drive not recognized
hi I am using Hitachi external hard disk with aluminum case. When I connect my hard disk with my PC it is not recognizing my hard disk. I want retrive my data from the hard disk please let me know the solutions.
Thanks,
K.Venki
Jan 07, 2009 | Computers & Internet
Replacement drive for HP DV5000
As per HP, the maximum capacity of Hard Drive shipped with dv5000 series Notebook is 100 GB 5400 RPM SATA Hard Drive.
The Specifications of the Hard Drive compatible with your Notebook are SATA 5,400RPM, 2.5in width, 9.5mm height.
However, you can install a maximum of 160 GB SATA Hard Drive in your Notebook.
You can purchase the reqired Hard Drive for your Notebook from the link below :
http://bixnet.com/12insanohadr.html
Find the requied instructions to remove and replace the Hard Drive in the Notebook from the Manual of the Link below :
http://h10032.www1.hp.com/ctg/Manual/c00700932.pdf
Please go through page number 98 of 260 in the Manual to find the required instructions.
Hope this helps....
Nov 29, 2008 | HP Pavilion dv4000 Notebook
Brand new Seagate Maxtor OneTouch 4 plus 750 Gb isn't recognized
jumpered wrong or its a fake drive (knockoff) but doubtful so the real diagnostics is
start run diskmgmt.msc in it you will find if drive is unalocated or not even detected. if its not detected goto run type eventvwr and check in system for errors ..
im starting to think upper and lower cdrom filters are causing usb issue. i had issues with old zip drive software causing this.
Aug 01, 2008 | Maxtor Hard Drive
Replaced hard drive
try connecting it as slave and after rebooting the system, your harddrive may be recosnise by the system. after copy the data and format this HDD in low level.
Jul 29, 2008 | Dell Dimension 2400 PC Desktop
HP m7170n PC Desktop Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
