Question about Intermatic 24hr Outdoor Timer
I followed the directions but the lights don't turn on when I programed the requested time.
Add a comment and say specifically what timer you have so I can look at manual alongside you and help.
Posted on Mar 28, 2011
Step by step
What steps are you looking for? Also what is the problem? Also this may solve your issue
Copied from: voxrightnow
Programming the Remote:
Your universal remote can operate a variety of brands of components. In order for your universal remote to control your components, you need to program the remote with the codes that match the components (See Code List below). These codes enable the remote to communicate with your components. Each brand and each component has its own "language," and, by programming the correct codes into your remote, you tell the remote to "speak the same language" as your components.
There are two methods you can use to program your remote control to operate your components: Direct Code Entry and Manual Code Search and Entry. Most components can be programmed in one of these ways. Try them in the order listed.
In order to control combo TV/VCR or TV/DVD units, you must program both the TV key and the VCR•DVD key. Once programmed successfully, the TV key controls the TV functions on your unit, and the VCR•DVD key controls the VCR or DVD functions. There is a specific section in the Code List for combo units. The codes in this section should be tried first, using Direct Code Entry on the TV and VCR•DVD keys. If this is unsuccessful, follow the normal programming methods for both the TV and the VCR•DVD keys
Direct Code Entry:
To program your universal remote to control your components using the Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box).
2. Find the Code List below. Find the list for the component you wish to program. Find your component's brand. You will see a listing of four-digit codes for each brand. If your brand isn't listed, use the Manual Code Search method to program the remote control. (Refer to page 5 in the User Manual for Manual Code Search method, or scroll down in this Answer to the next section.)
3. Press and hold the component key (TV, VCR•DVD, SAT•CBL) you wish to program. The LED indicator light turns on and remains on. If you release the component key any time during the Direct Code Entry procedure, the LED indicator light blinks four times, and the process is exited.
4. While holding down the component key, consult the Code Lists for the four-digit code that corresponds to your component's brand and use the number keys (0-9) on the keypad to enter it. While you are pressing the numbers, the LED indicator light turns off.
5. After the fourth number is entered, the LED indicator light turns on. At this time, release the component key. If the LED indicator light turns off, you have entered a valid code and have followed the correct procedure
for Direct Code Entry. If you enter a code number that is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the LED indicator light blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 3 and try the next code listed. The last programmed code under that component key is retained. Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality.
Manual Code Search and Entry:
If your component's brand isn't listed in the Code Lists, or if you have tried all of the codes for your brand and the remote does not operate your component, try the Manual Code Search. This Code Search method cycles through all of the codes in the Code Lists in the event that your component's code is listed under another brand. The Manual Code Search method may take a long time because the remote searches through all of the codes in its memory for the code that operates your component. Therefore, if your brand is listed in the Code Lists, first try the Direct Code Entry method described on page 4 in the User's Manual also described above.
NOTE: To exit without saving any point in the Manual Code Search, press and release the GO BACK key.
Note: If you press an invalid key during the Manual Code Search, the remote does not respond and the LED indicator light does not blink. If you do not press a valid Manual Code Search key (TV, VCR•DVD, SAT•CBL, ON•OFF, GO BACK), the search times out after two minutes. When the search times out, the LED indicator light blinks four times and turns off. The last programmed code under that component key is retained.
2. If you are programming the remote to control your TV or satellite receiver, go directly to step 3. To program the remote to control a VCR or DVD follow the preprogramming method listed below.
Preprogramming the VCR/DVD Key
The VCR•DVD key can control only one component, either your VCR or your DVD. To program your remote to control either your DVD or your VCR, you must first put the remote in the proper programming mode. Follow these directions before proceeding to step 3.
a. Press and hold the VCR•DVD key. The LED indicator light turns on.
b. While holding down the VCR•DVD key, press and release the number 2 key on the keypad to control a VCR or the number 3 key to control a DVD. The LED indicator light turns off.
c. Release the VCR•DVD key. The LED indicator light blinks four times and then turns off. Your remote is now either in VCR or DVD Programming Mode, depending on which you chose. Proceed to step 3.
4. While holding the component key down, press and hold the ON•OFF key. The LED indicator light turns off.
5. After holding down both keys for three seconds, the LED indicator light turns back on.
6. Release both keys. The LED indicator light remains on. Throughout the programming of each key, be sure to keep the remote pointed at the
7. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component
turns off, you have found the correct code. (If it cycles through and the LED indicator light blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.) Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
8. Once you have found the correct code, you must save the new
code by pressing and releasing the STOP key. The LED indicator
light turns off. You must press the STOP key to save the code or the correct code will not be stored!
9. Once you press the STOP key, the code is stored.
Testing the Code for Maximum Functionality:
1. Once the code has been stored (see Manual Code Search and Entry Method above), use the remote to attempt to control a variety of the component's functions. If the code that has been stored controls the majority of the component's functions, programming is complete. If the
code stored does not give maximum functionality, you will want to try another code.
2. In that case, repeat the Manual Code Search and Entry Method from step 1. When the component turns off for the first time, do not press the STOP key, which would store the code. Instead, with the unit now off, continue to press the ON•OFF key repeatedly until the unit turns back on. Once the unit turns back on, you have found another code that operates the component. Press the STOP key.
3. Test the functionality again by attempting to control a variety of the component's functions. If the code that has been stored controls the majority of the component's functions, programming is complete. If the code stored does not give maximum functionality, you will want to try another code.
4. Repeat the Manual Code Search and Entry Method from step 1. Each time a code turns the component on or off, you have found a code that operates the remote and needs to be tested for maximum functionality. Continue through the code lists, cycling through the codes you have already tried, until you find one that offers maximum functionality.
Nov 10, 2012 | RCA RCR350 Remote Control
UR 2 Universal controller - don't work!
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 22, 2012 | Televison & Video
I'm tryna program my universal rca remote control to my sanyo television but I don't have the manua. Only the code paper
Hello
Codes for Sanyo TV with RCA RCR312W remote are:
10054, 10154, 10159, 11142
control.
2. Locate the enclosed Code Lists. Find the list for the
brand. If your brand isn't listed, use one of the Code Search
methods to program the remote control. (Refer to pages 3
and 4 for Manual and Auto Code Search methods.)
Note: You can also use the online code finder at
www.rca.com/codefinder to find the best code for your component
program. The illuminated ON•OFF key
the component key at any time during the Direct Code
Entry procedure, the illuminated ON•OFF key blinks four
illuminated ON•OFF key turns off.
5. After the fourth number is entered, the illuminated ON•OFF
key turns on. At this time, release the component key. If the
illuminated ON•OFF key turns off, you have entered a valid
code and have followed the correct procedure for Direct
Code Entry.
the illuminated ON•OFF key blinks four times when the
Direct Code Entry process from step 3.
Tip: Throughout the programming of each key, be sure to keep the
functionality
OK.
Sep 13, 2011 | RCA RCR312W Remote Control
We've lost the instruction manual for our light switch timer so don't know how to reprogram it. Directions, please!! We've just replaced the battery.What buttons do we press in what order to...
Question posted under Intermatic timer:
Open following link to identify timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
IF Intermatic timer stopped working because battery failed, then all that's needed is to reprogram current time, because the original timer programs you set are stored inside timer forever until timer is manually reset using reset button.
If you have Intermatic ST01C timer, then open following page for ez instructions:
http://waterheatertimer.org/ST01C-program.html
If you need help programming specific timer, then get as far along in manual as possible, and then add a comment.
If you have different brand timer, than each brand has link that shows on Intermatic page.
Aug 10, 2011 | Intermatic Hardware & Accessories
Have a BA TVee 25 Soundbar. Only able to program Volume Up on my remote. Cannot program Volume Down or Mute. Nothing happens except to turn the Soundbar off and on. Don't tell me to follow...
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Jul 26, 2011 | Boston Acoustics TVee Model Two TV...
I need the RCA Blue Ray rtb1203 Remote Control code for a Direct tv Remote
You don't need a code when programming a Direct TV remote. Try following these steps. The process take a few minutes but it works -
  • Turn on your Blue-Ray and put in a disk.
  • Switch the mode to which ever input the Blue-Ray is using.
  • Hold down the "mute" and "select" button at the same time until the green light begins to flash then release.
  • On the keypad enter the numbers 9-9-1 followed by Satellite, TV, VCR/DVD, Aux,
  • Press the power button or which ever function you wish to use for you Blue_Ray such as play for the VCR.
  • Point the remote at you Blue-Ray and slowly press the "channel" and "key" button together until the remote turns off. Do this slow enough so as not to pass up the right code.
  • Once the remote turns off then you have found the correct code.
  • Press and release the select key to lock that code in.
Please note that if you cycle through all the codes and your remote does not turn off and the red light flashes three times then the code you need for your Blue-Ray is not available with that remote. At that point another remote would need to be used.
Regards, Tony
Apr 23, 2011 | Audio Players & Recorders
I bought my Midland WR-100 Weather Radio in 2008, from Walmart {Midwest City, OK}. They programmed it there, for Oklahoma County, and surounding Countys as well. It worked the 1st year, continuely as many...
Good morning, afternoon, evening or night, depending on the time of day you are reading this. From what you are requesting here, you want weather alerts for only for Oklahoma County? Here are the steps for doing this.
  1. If you need the S.A.M.E code for Oklahoma County, type this URL address into your URL box (http://www.weather.gov/nwr/CntyCov/nwrOK.htm).
  2. Scroll down and find your county name and the S.A.M.E code will be located right beside it.
  3. Obtain your Weather Radio and press the MENU button.
  4. Use the directional up or down buttons until you see the word "SAME SET" on your screen. Once this is seen, press SELECT.
  5. You will either see the words "SINGLE", "MULTIPLE", or "ANY" on your screen. When this is seen, press SELECT if you see "SINGLE". Use the directional up or down buttons (if "SINGLE" does not appear on your screen) until "SINGLE" is displayed on the screen. Once this is seen, press SELECT.
  6. You will see the words SAME 01 on your screen. Once this is seen, press SELECT.
  7. Using the directional up or down buttons, program the first number of the code in the blinking column. When finished, press the > (directional right) button as this will automatically save the number and advance you to the next column.
  8. Continue Step 7 until all numbers are programmed in the radio.
  9. When finished, press SELECT as this will store and automatically save your code.
  10. Press MENU to exit.
If you followed these steps correctly, your radio should now be programmed to respond to only one county. To set it to respond to multiple counties again, follow these steps, only this time instead of choosing "SINGLE" you will choose "MULTIPLE". The "alarm not stopping until it's turned off", is a normal function and should not be tampered with. Hope this will come in handy in the future, especially during Tornado Season, as you state is in the region known as "Tornado Alley". This radio will keep you notified, informed on what's happening weather-wise and could possibly save your life from Mother Nature's threats. Thank you for taking the time to request your problem, read and perform this solution. Thank you for choosing FixYa as your one-stop spot for finding solutions to your problems! Be safe this Tornado Season and have a good day, afternoon, evening or night; whatever time you are reading this.
Feb 23, 2011 | Midland WR-100 Weather/RDS Radio
I put the Voyager pro headset in the car and is turn on, after work, I back to my car and the headset light is out and I go home put in the charger that headset no light on and can turn on again, I try to...
What you probably need to do is turn off, then on, the headset. In today's push button happy society, sometimes we don't always follow the instructions the manufacturer provides. Please follow the instructions carefully in the link below for the Plantronics Voyager Pro+, paying particular attention to "Listen to the Voice" and "Tips." You should be up and running in no time.
Plantronics Voyager Pro+ User's Guide
Good luck from Headsets Direct!
Oct 27, 2010 | Plantronics Voyager PRO Bluetooth Headset
How to program a rca rcr451 remote
or cable box).
component’s brand. You will see a
brand. If your brand isn’t listed,
control. (Refer to page 6 for
Manual Code Search method.)
(TV, VCR, DVD, SAT·CBL) you
your component’s brand and use the
light turns off.
component’s functions with the
your component’s functions.
DOWNLOAD the full manual with codes for free at: http://www.replacementremotes.com/RCA-Manuals/Download-FREE-RCR450C-MANUAL-OPERATING-MANUAL.html
Aug 11, 2010 | RCA Universal Remote Control
I need a code for a rca and a coby remote controle
Sanyo. 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180
2. Press and hold the component key (TV, VCR·DVD, SAT·CBL) you
is exited.
3. While holding down the component key, enter the four-digit code that corresponds to your component’s brand. While you are pressing the numbers, the LED indicator light turns off.
5. After the fourth number is entered, the LED indicator light turns on. At this time, release the component key.If the LED indicator light turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry. If you enter a code number that
is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the LED indicator light blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2 and try the next code listed.
Dec 01, 2009 | RCA Universal Remote Control
Intermatic 24hr Outdoor Timer Logo
32 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
